Einleitung
Remove bottom housing to reveal the inside of the iMac.
Was du brauchst
Unplug all the cables from the computer, including the power cable. Lay the computer face-down, supporting the neck and base with a soft cloth under the screen.
Open the housing plate.
A fixed plug connector between the logic board and upper unit will cause some resistance. Pull gently but firmly.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
