Einleitung
Removing the logic board assembly to replace it with a new one.
Werkzeuge
Ersatzteile
Kein Ersatzteil erforderlich.
Unplug all the cables from the computer, including the power cable. Lay the computer face-down, supporting the neck and base with a soft cloth under the screen.
Open the housing plate.
A fixed plug connector between the logic board and upper unit will cause some resistance. Pull gently but firmly.
Remove the three metal 10mm T-15 screws.
Remove the one nylon 10mm T-15 screw.
Using thumbs and forefingers, firmly grasp the battery holder in one hand while grasping the metal bar in the other. Gently lift and pull the logic board to release it.
5 weitere Nutzer haben diese Anleitung absolviert.
