Zum Hauptinhalt wechseln
iMac G5 17" Model A1058 Fan Cover Replacement
Was du brauchst
  1. iMac G5 17" Model A1058 Fan Cover Replacement, Rear Panel: Schritt 1, Bild 1 von 1
    • Lay the iMac display-side down on a flat surface.
    • Loosen the three Phillips screws securing the rear panel to the iMac.
    • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
  2. iMac G5 17" Model A1058 Fan Cover Replacement: Schritt 2, Bild 1 von 3 iMac G5 17" Model A1058 Fan Cover Replacement: Schritt 2, Bild 2 von 3 iMac G5 17" Model A1058 Fan Cover Replacement: Schritt 2, Bild 3 von 3
    • Lift the rear panel slightly from the bottom edge of the iMac.
    • Pull the rear panel toward yourself and remove it from the iMac.
  3. iMac G5 17" Model A1058 Fan Cover Replacement, Fan Cover: Schritt 3, Bild 1 von 2 iMac G5 17" Model A1058 Fan Cover Replacement, Fan Cover: Schritt 3, Bild 2 von 2
    • Remove the two Phillips screws securing the fan cover to the midplane.
    • The shouldered screw belongs in the lower left corner of the fan cover.
    • Lift the fan cover up off midplane.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 11
Insgesamt: 8,612
