Einleitung
Replace your broken optical drive to keep those disks spinning.
Loosen the two Phillips screws securing the access door to your iMac.
Remove the three T8 Torx screws securing the front bezel to the rear panel.
Use your thumbs to press both RAM arms in past the front bezel for enough clearance to lift it off the rear case.
While holding the RAM arms in with your thumbs, lift the lower edge of the front bezel enough to clear the rear case.
Insert a plastic card up into the corner of the air vent slot at the top of the rear case.
Push the card toward the top of the iMac to release the front bezel latch.
Pull the front bezel away from the rear case.
Repeat this process for the other side of the front bezel.
Lay your iMac stand-side down on a table.
Lift the front bezel from its lower edge and rotate it away from the rest of your iMac, minding the RAM arms that may get caught.
Lay the front bezel above the rest of the iMac.
If necessary, remove the piece of kapton tape wrapped around the microphone and camera cables.
Peel back the aluminum EMI shield up off the lower three edges of the rear case.
Remove the two 5 mm T6 Torx screws securing the display data cable to the logic board.
Using its attached black tab, pull the display data cable connector up off the logic board.
Remove the four recessed coarse-thread 7.5 mm T10 Torx screws securing the display to the rear case.
Lift the display from its lower edge and pull it toward yourself to peel it off the EMI shield attached to its top edge.
Remove the T10 Torx screw securing the optical drive flex cable mounting bracket to the logic board.
Remove the flex cable mounting bracket.
Insert the flat end of a spudger into the gap between the optical drive and its bracket until it contacts the chassis.
Grab the spudger as close to the surface of the optical drive as you can, then depress the release tab with your thumb while pulling toward yourself.
Use the flat end of a spudger to press the bottom edge of the lower optical drive bracket release tab toward the lower edge of the iMac.
Maneuver the optical drive out of the rear case, minding the two plastic pins molded into the rear case near the open end of the optical drive that can break off.
Remove the two T10 Torx screws from the side of your optical drive.
Push the two optical drive bracket tabs out of their slots in the top of the optical drive.
Using the tip of a spudger, press the optical drive bracket tab out of its slot on the side of the optical drive.
Use the tip of a spudger to push the optical drive bracket tabs out of their slots on the bottom of the optical drive.
Pull the optical drive bracket toward the open end of the optical drive to free it from the optical drive.
Remove the two T6 Torx screws securing the optical drive flex cable to the optical drive.
Insert the flat end of a spudger into the gap between the optical drive flex cable connector and the optical drive.
Twist the spudger to separate the connector from the optical drive.
Use the flat end of a spudger to remove the small piece of EMI foam from the underside of the optical drive.
7 weitere Nutzer haben diese Anleitung absolviert.
