Zum Hauptinhalt wechseln
iMac G5 20" Model A1076 Left Fan Replacement
Was du brauchst
  1. iMac G5 20" Model A1076 Left Fan Replacement, Rear Panel: Schritt 1, Bild 1 von 1
    • Lay the iMac display-side down on a flat surface (putting a cloth under the screen to protect it from bumps).
    • Loosen the three Phillips screws securing the rear panel to the iMac.
    • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
  2. iMac G5 20" Model A1076 Left Fan Replacement: Schritt 2, Bild 1 von 2 iMac G5 20" Model A1076 Left Fan Replacement: Schritt 2, Bild 2 von 2
    • Lift the rear panel slightly near the bottom of the iMac.
    • Pull the rear panel toward yourself and remove it from the iMac.
  3. iMac G5 20" Model A1076 Left Fan Replacement, Left Fan: Schritt 3, Bild 1 von 1
    • Remove the two 9.7 mm shouldered T8 Torx screws from the left fan.
  4. iMac G5 20" Model A1076 Left Fan Replacement: Schritt 4, Bild 1 von 2 iMac G5 20" Model A1076 Left Fan Replacement: Schritt 4, Bild 2 von 2
    • Disconnect both fans by pulling their connectors straight up off the logic board.
    • The connector for the left fan requires a considerable amount of force to remove. If you bend the pins on the logic board, use the fan connector as a guide to bend them straight.
  5. iMac G5 20" Model A1076 Left Fan Replacement: Schritt 5, Bild 1 von 1
    • Lift the left fan out of the chassis, minding any cables that may get caught.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 6,510
