Zum Hauptinhalt wechseln
iMac G5 20" Model A1145 CPU Fan Replacement
Was du brauchst
    1. iMac G5 20" Model A1145 CPU Fan Replacement, Access Door: Schritt 1, Bild 1 von 1
      • Orient the iMac face-side down on a table with the bottom edge facing yourself.
      • Remove the two Phillips screws securing the access door to the bottom grille of your iMac.
      • The screws are captive in the access door.
      • Before beginning the repair, unplug the computer and press and hold the power switch for 20-30 seconds, to discharge internal capacitors.
      Frag FixBot
      Kommentar hinzufügen
    2. iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 2, Bild 1 von 1
      • Remove the access door.
      Frag FixBot
    1. iMac G5 20" Model A1145 CPU Fan Replacement, Front Bezel: Schritt 3, Bild 1 von 1
      • Remove the three T8 Torx screws securing the front bezel to the rear case along the lower edge of the iMac.
      Frag FixBot
    2. iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 4, Bild 1 von 2 iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 4, Bild 2 von 2
      • Turn the computer over.
      • Use your thumbs to press both RAM arms in past the front bezel for enough clearance to lift it off the rear case.
      Frag FixBot
    3. iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 5, Bild 1 von 1
      • While holding the RAM arms in with your thumbs, lift the lower edge of the front bezel enough to clear the rear case.
      Frag FixBot
    4. iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 6, Bild 1 von 3 iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 6, Bild 2 von 3 iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 6, Bild 3 von 3
      In diesem Schritt verwendetes Werkzeug:
      Plastic Cards
      $2.99
      • Re-orient your iMac so it sits upright on the stand.
      • Insert a plastic card up into the corner of the air vent slot near the top of the rear case.
      • Push the card toward the top of the iMac to release the front bezel latch.
      • Pull the front bezel away from the rear case.
      • Repeat this process for the other side of the front bezel.
      • It may be necessary to apply several layers of duct tape to the top of the access card to aid in releasing the latches.
      • If the bezel refuses to release, try pressing the lower edge back onto the rear case and repeat this opening process.
      • Alternatively, you can use a strong magnet by holding it to the front top left/right corner of the display. You will hear a snapping sound when the hatch is released.
      Frag FixBot
    5. iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 7, Bild 1 von 1
      • Lay your iMac stand-side down on a table.
      • Lift the front bezel from its lower edge and rotate it away from the rest of your iMac, minding the RAM arms that may get caught.
      • Lay the front bezel above the rest of the iMac.
      Frag FixBot
    6. iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 8, Bild 1 von 1
      • If necessary, remove the piece of kapton tape wrapped around the microphone and camera connectors.
      Frag FixBot
    7. iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 9, Bild 1 von 2 iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 9, Bild 2 von 2
      • Disconnect both the camera and microphone cables.
      Frag FixBot
    1. iMac G5 20" Model A1145 CPU Fan Replacement, Lower EMI Shield: Schritt 10, Bild 1 von 1
      • Peel the lower EMI shield off the lower edge of the iMac and off the two vertical 4" sections on either side of the iMac.
      • It is not necessary to peel the lower EMI shield off the display.
      Frag FixBot
    2. iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 11, Bild 1 von 1
      • Tape the lower EMI shield up against the face of the display to keep it out of the way while you work.
      Frag FixBot
    1. iMac G5 20" Model A1145 CPU Fan Replacement, Display: Schritt 12, Bild 1 von 1
      • Remove the two T6 Torx screws securing the display data cable connector to the logic board.
      Frag FixBot
    2. iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 13, Bild 1 von 1
      • To disconnect the display data cable, grab its connector's black tab and pull it away from the face of the logic board.
      Frag FixBot
    3. iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 14, Bild 1 von 1
      • Peel back the two EMI tape strips from the left and right edges of the display.
      • During reassembly, it is helpful to use several small strips of tape to hold the EMI shielding along the left and right edges of the display footprint out of the way before lowering the display into the rear case of your iMac.
      Frag FixBot
    4. iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 15, Bild 1 von 2 iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 15, Bild 2 von 2
      • Remove the four recessed T10 Torx screws securing the display to the rear case.
      • Bit drivers tend to be too short to reach these screws. Be sure to have a magnetic thin-shafted T10 Torx screwdriver on hand.
      Frag FixBot
    5. iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 16, Bild 1 von 1
      • Lift the lower edge of the display slightly out of the rear case.
      • Disconnect both inverter cables (shown in red) by pulling their connectors toward the bottom edge of your iMac.
      Frag FixBot
    6. iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 17, Bild 1 von 1
      • Lift the display until it is nearly perpendicular to the rear case.
      • Disconnect the remaining two inverter cables (shown in red) by pulling their connectors toward the top edge of your iMac.
      Frag FixBot
    7. iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 18, Bild 1 von 1
      • While holding the display perpendicular to the rear case, pull it upward to peel off the EMI shield stuck to its upper edge.
      Frag FixBot
    1. iMac G5 20" Model A1145 CPU Fan Replacement, Logic board: Schritt 19, Bild 1 von 1
      • Disconnect the IR board cable by pulling its connector away from the socket on the IR board.
      Frag FixBot
    2. iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 20, Bild 1 von 2 iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 20, Bild 2 von 2
      • Remove the two T6 Torx screws securing the IR board bracket to the IR board.
      Frag FixBot
    3. iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 21, Bild 1 von 1
      • De-route the IR cable from under the aluminum heat sink and tuck it behind the optical drive to keep it out of the way.
      Frag FixBot
    4. iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 22, Bild 1 von 2 iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 22, Bild 2 von 2
      • Remove the single T10 Torx screw securing the left speaker to the rear case.
      • The screw for the left speaker has coarse threads.
      • Lift the left speaker out of the rear case and de-route its cable across the logic board.
      Frag FixBot
    5. iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 23, Bild 1 von 2 iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 23, Bild 2 von 2
      • Remove the single T10 Torx screw securing the right speaker to the rear case.
      • The right speaker screw has fine threads.
      • Lift the right speaker out of the rear case, minding the short cable between the speaker and its connector (located slightly above the right speaker).
      Frag FixBot
    6. iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 24, Bild 1 von 1
      • Disconnect the speakers from the logic board by pulling their connector toward the top edge of the iMac.
      Frag FixBot
    7. iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 25, Bild 1 von 1
      • Remove the two Phillips or two T6 Torx screws securing the AirPort/Bluetooth board to the logic board.
      Frag FixBot
    8. iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 26, Bild 1 von 1
      • Use your finger to lift the AirPort/Bluetooth board from its left edge, disconnecting it from the logic board.
      • Lift the board from its left edge only.
      Frag FixBot
    9. iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 27, Bild 1 von 2 iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 27, Bild 2 von 2
      • Use the flat end of a spudger to pry both antenna cable connectors up off the AirPort/Bluetooth board.
      Frag FixBot
    10. iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 28, Bild 1 von 2 iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 28, Bild 2 von 2
      • Disconnect the DC-in cable by simultaneously depressing both locking arms and pulling its connector away from the socket on the logic board toward the top of your iMac.
      • After both locking arms pass their retaining tabs, it is helpful to push the arms toward the top edge of your iMac while wiggling the connector.
      Frag FixBot
    11. iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 29, Bild 1 von 1
      • Disconnect the ambient light sensor by pulling its connector away from the face of the logic board.
      Frag FixBot
    12. iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 30, Bild 1 von 2 iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 30, Bild 2 von 2
      • Disconnect the optical drive fan from the logic board.
      • To aid in removal, it is helpful to use both of your thumbnails to push the ears on either side of the connector toward the top edge of the iMac.
      Frag FixBot
    13. iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 31, Bild 1 von 2 iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 31, Bild 2 von 2
      • Disconnect the IR/camera cable from the logic board.
      • This connector is especially wide and prone to breakage.
      • To aid in removal, it is helpful to use one hand to pinch the cables against a spudger and pull up toward the top edge of the iMac while pulling up gently on the cables with your other hand.
      Frag FixBot
    14. iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 32, Bild 1 von 1
      • Disconnect the optical drive thermal sensor cable from the logic board by pulling its connector toward the left edge of the iMac.
      Frag FixBot
    15. iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 33, Bild 1 von 1
      • Remove the two T6 Torx screws securing the optical drive connector to the logic board.
      Frag FixBot
    16. iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 34, Bild 1 von 1
      • Use the flat end of a spudger to pry the optical drive connector up off the logic board.
      • It is helpful to insert the spudger under the top or bottom edge of the connector and twist to separate the connector from the logic board.
      Frag FixBot
    17. iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 35, Bild 1 von 1
      • Disconnect the CPU fan from the logic board by pulling its connector toward the top edge of the iMac.
      Frag FixBot
    18. iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 36, Bild 1 von 1
      • Disconnect the hard drive thermal sensor from the logic board by pulling its connector toward the top edge of the iMac.
      Frag FixBot
    19. iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 37, Bild 1 von 1
      • Disconnect the hard drive fan by pulling its connector away from the face of the logic board.
      Frag FixBot
    20. iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 38, Bild 1 von 1
      • Disconnect the power button cable by pulling its connector away from the face of the logic board.
      Frag FixBot
    21. iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 39, Bild 1 von 1
      • Remove the two T6 Torx screws near the top of the heat sinks.
      Frag FixBot
    22. iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 40, Bild 1 von 1
      • Remove the following seven screws securing the logic board to the rear case:
      • Three coarse-thread T10 Torx.
      • Three fine-thread T10 Torx.
      • One long coarse-thread T10 Torx.
      Frag FixBot
    23. iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 41, Bild 1 von 2 iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 41, Bild 2 von 2
      • Tuck the RAM arms into the iMac so they rest on the perforated metal grille along its lower edge.
      Frag FixBot
    24. iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 42, Bild 1 von 1
      • Rotate the top of the logic board toward yourself slightly.
      • Pull the right edge of the logic board toward yourself slightly to free the I/O ports from the rear case, being careful not to bend the board.
      • Continue rotating the board toward yourself until you have enough room to reach the SATA connector, shown in the next step.
      Frag FixBot
    25. iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 43, Bild 1 von 2 iMac G5 20" Model A1145 CPU Fan Replacement: Schritt 43, Bild 2 von 2
      • Continue rotating the board toward yourself until you have enough room to reach the SATA connector (shown in red).
      • Insert the blunt end of a metal spudger between the SATA connector and its socket. Twist the shaft of the metal spudger to separate the connector from its socket.
      • Disconnect the SATA cable from the logic board.
      • Lift the logic board out of the rear case by its edges, minding any cables that may get caught.
      Frag FixBot
    1. iMac G5 20" Model A1145 CPU Fan Replacement, CPU Fan: Schritt 44, Bild 1 von 1
      • Lift the CPU fan off the plastic posts protruding from the rear case.
      Frag FixBot
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 23
Letzte 30 Tage: 79
Insgesamt: 13,270
