Einleitung
Replace your broken optical drive fan to keep temperatures down!
Was du brauchst
Orient the iMac face-side down on a table with the bottom edge facing yourself.
Remove the two Phillips screws securing the access door to the bottom grille of your iMac.
Remove the three T8 Torx screws securing the front bezel to the rear case along the lower edge of the iMac.
Turn the computer over.
Use your thumbs to press both RAM arms in past the front bezel for enough clearance to lift it off the rear case.
While holding the RAM arms in with your thumbs, lift the lower edge of the front bezel enough to clear the rear case.
In diesem Schritt verwendetes Werkzeug:Plastic Cards$2.99
Insert a plastic card up into the corner of the air vent slot near the top of the rear case.
Push the card toward the top of the iMac to release the front bezel latch.
Pull the front bezel away from the rear case.
Repeat this process for the other side of the front bezel.
If the bezel refuses to release, try pressing the lower edge back onto the rear case and repeat this opening process.
Lay your iMac stand-side down on a table.
Lift the front bezel from its lower edge and rotate it away from the rest of your iMac, minding the RAM arms that may get caught.
Lay the front bezel above the rest of the iMac.
If necessary, remove the piece of kapton tape wrapped around the microphone and camera connectors.
Peel the lower EMI shield off the lower edge of the iMac and off the two vertical 4" sections on either side of the iMac.
Tape the lower EMI shield up against the face of the display to keep it out of the way while you work.
Remove the two T6 Torx screws securing the display data cable connector to the logic board.
To disconnect the display data cable, grab its connector's black tab and pull it away from the face of the logic board.
Peel back the two EMI tape strips from the left and right edges of the display.
Remove the four recessed T10 Torx screws securing the display to the rear case.
Lift the lower edge of the display slightly out of the rear case.
Disconnect both inverter cables (shown in red) by pulling their connectors toward the bottom edge of your iMac.
Lift the display until it is nearly perpendicular to the rear case.
Disconnect the remaining two inverter cables (shown in red) by pulling their connectors toward the top edge of your iMac.
While holding the display perpendicular to the rear case, pull it upward to peel off the EMI shield stuck to its upper edge.
Disconnect the IR board cable by pulling its connector away from the socket on the IR board.
De-route the IR cable from under the aluminum heat sink and tuck it behind the optical drive to keep it out of the way.
Remove the single T10 Torx screw securing the left speaker to the rear case.
Lift the left speaker out of the rear case and de-route its cable across the logic board.
Remove the single T10 Torx screw securing the right speaker to the rear case.
Lift the right speaker out of the rear case, minding the short cable between the speaker and its connector (located slightly above the right speaker).
Disconnect the speakers from the logic board by pulling their connector toward the top edge of the iMac.
Remove the two Phillips or two T6 Torx screws securing the AirPort/Bluetooth board to the logic board.
Use your finger to lift the AirPort/Bluetooth board from its left edge, disconnecting it from the logic board.
Use the flat end of a spudger to pry both antenna cable connectors up off the AirPort/Bluetooth board.
Disconnect the DC-in cable by simultaneously depressing both locking arms and pulling its connector away from the socket on the logic board toward the top of your iMac.
Disconnect the ambient light sensor by pulling its connector away from the face of the logic board.
Disconnect the optical drive thermal sensor cable from the logic board by pulling its connector toward the left edge of the iMac.
Remove the two T6 Torx screws securing the optical drive connector to the logic board.
Use the flat end of a spudger to pry the optical drive connector up off the logic board.
Disconnect the CPU fan from the logic board by pulling its connector toward the top edge of the iMac.
Disconnect the hard drive thermal sensor from the logic board by pulling its connector toward the top edge of the iMac.
Disconnect the hard drive fan by pulling its connector away from the face of the logic board.
Disconnect the power button cable by pulling its connector away from the face of the logic board.
Remove the following seven screws securing the logic board to the rear case:
Three coarse-thread T10 Torx.
Three fine-thread T10 Torx.
One long coarse-thread T10 Torx.
Tuck the RAM arms into the iMac so they rest on the perforated metal grille along its lower edge.
Rotate the top of the logic board toward yourself slightly.
Pull the right edge of the logic board toward yourself slightly to free the I/O ports from the rear case, being careful not to bend the board.
Continue rotating the board toward yourself until you have enough room to reach the SATA connector, shown in the next step.
Continue rotating the board toward yourself until you have enough room to reach the SATA connector (shown in red).
Insert the blunt end of a metal spudger between the SATA connector and its socket. Twist the shaft of the metal spudger to separate the connector from its socket.
Disconnect the SATA cable from the logic board.
Lift the logic board out of the rear case by its edges, minding any cables that may get caught.
Lift the optical drive fan off the plastic posts protruding from the rear case.
Eine weitere Person hat diese Anleitung absolviert.
