Zum Hauptinhalt wechseln
iMac G5 20" Model A1145 RAM Replacement
Was du brauchst
  1. iMac G5 20" Model A1145 RAM Replacement, Access Door: Schritt 1, Bild 1 von 1
    • Orient the iMac face-side down on a table with the bottom edge facing yourself.
    • Remove the two Phillips screws securing the access door to the bottom grille of your iMac.
    • The screws are captive in the access door.
    • Before beginning the repair, unplug the computer and press and hold the power switch for 20-30 seconds, to discharge internal capacitors.
    Frag FixBot
    Kommentar hinzufügen
  2. iMac G5 20" Model A1145 RAM Replacement: Schritt 2, Bild 1 von 1
    • Remove the access door.
    Frag FixBot
  3. iMac G5 20" Model A1145 RAM Replacement, RAM: Schritt 3, Bild 1 von 1
    • Insert your fingers into the two RAM arms and pull both arms toward yourself to eject the RAM chip.
    Frag FixBot
  4. iMac G5 20" Model A1145 RAM Replacement: Schritt 4, Bild 1 von 1
    • Slide the RAM chip straight out of its socket.
    • Make sure both RAM arms are fully rotated outward before reinstalling your RAM chip.
    Frag FixBot
Abschluss
13 weitere Personen haben diese Anleitung absolviert.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 39
Insgesamt: 21,635
