Einleitung
Is your iMac always mute? Replace the speakers.
Was du brauchst
Orient the iMac face-side down on a table with the bottom edge facing yourself.
Remove the two Phillips screws securing the access door to the bottom grille of your iMac.
Remove the three T8 Torx screws securing the front bezel to the rear case along the lower edge of the iMac.
Turn the computer over.
Use your thumbs to press both RAM arms in past the front bezel for enough clearance to lift it off the rear case.
While holding the RAM arms in with your thumbs, lift the lower edge of the front bezel enough to clear the rear case.
In diesem Schritt verwendetes Werkzeug:Plastic Cards$2.99
Insert a plastic card up into the corner of the air vent slot near the top of the rear case.
Push the card toward the top of the iMac to release the front bezel latch.
Pull the front bezel away from the rear case.
Repeat this process for the other side of the front bezel.
If the bezel refuses to release, try pressing the lower edge back onto the rear case and repeat this opening process.
Lay your iMac stand-side down on a table.
Lift the front bezel from its lower edge and rotate it away from the rest of your iMac, minding the RAM arms that may get caught.
Lay the front bezel above the rest of the iMac.
If necessary, remove the piece of kapton tape wrapped around the microphone and camera connectors.
Peel the lower EMI shield off the lower edge of the iMac and off the two vertical 4" sections on either side of the iMac.
Tape the lower EMI shield up against the face of the display to keep it out of the way while you work.
Disconnect the IR board cable by pulling its connector toward the left edge of your iMac.
Remove the single T10 Torx screw securing the right speaker to the rear case.
Remove the two Phillips screws securing the AirPort/Bluetooth board to the logic board.
Use your finger to lift the AirPort/Bluetooth board from its left edge, disconnecting it from the logic board.
Use the flat end of a spudger to pry both antenna connectors up off the AirPort/Bluetooth board.
Use the tip of a spudger to push the ears on either side of the speaker connector toward the top edge of the iMac.
Remove the two T6 Torx screws securing the IR board bracket to the aluminum heat sink on the logic board.
Remove the IR board bracket.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
