Einleitung
Keep those electrons flowing by replacing your broken power supply!
Was du brauchst
Loosen the two Phillips screws securing the access door to your iMac.
Remove the access door.
Remove the following screws along the lower edge of your iMac:
Three 6 mm T8 Torx screws
One 8 mm T8 Torx screw (Right side of the RAM slot on 2105)
In diesem Schritt verwendetes Werkzeug:Plastic Cards$2.99
Insert a plastic card up into the corner of the air vent slot near the top of the rear case.
Push the card toward the top of the iMac to release the front bezel latch.
Pull the front bezel away from the rear case.
Repeat this process for the other side of the front bezel.
If the bezel refuses to release, try lifting the lower edge of the front bezel slightly away from the rear case (detailed in the next few steps) and repeat the latch release process.
Lay your iMac stand-side down on a flat surface.
To lift the front bezel off the iMac, simultaneously:
Use your thumbs to press in the RAM arms and hold the iMac down.
Use your index fingers to pull the small bridge of material on the front bezel toward yourself.
Pull the front bezel up with your index fingers.
Once the small bridge of material has cleared the RAM arms, lift the front bezel by its lower edge just enough to clear the bottom edge of the rear case.
Lift the front bezel off the rear case and rotate it away from the bottom edge of the iMac, minding the camera and microphone cables still attached to its upper edge.
Disconnect the microphone cable.
Disconnect the camera cable by pulling its connector away from the socket on the camera board.
Remove the two 5 mm T6 Torx screws securing the display data cable connector to the logic board.
Pull the display data cable connector up off the logic board by its black pull tab.
Allow the lower EMI shield to hang down from the display.
Remove the four 7.5 mm T10 Torx screws securing the display to the rear case.
Lift the lower edge of the display and rotate it toward the top edge of your iMac.
Disconnect the two inverter cables at the top edge of the inverter using the method explained in the previous step.
Rotate the display until it is nearly perpendicular to the rear case and lift it up to peel it off the EMI shield stuck to its top edge.
Remove the single T10 Torx screw securing the left speaker to the rear case.
Pull the left speaker out of the rear case.
Use the flat end of a spudger to pry both antenna connectors up off the AirPort Extreme card.
In diesem Schritt verwendetes Werkzeug:Metal Spudger$2.99
Use a metal spudger to disconnect the SATA data cable up off the logic board.
Remove the single T10 Torx screw securing the right speaker to the logic board.
Lift the right speaker out of the rear case and move it out of the way.
Disconnect the speaker cable connector by lifting it straight up off its socket on the logic board.
Disconnect the HDD fan and power button from the logic board by pulling their connectors straight up off the sockets on the logic board.
If necessary, remove the pieces of tape holding the SATA data cable to the logic board.
Move the SATA data cable away from the face of the logic board.
Disconnect the DC-In cable by simultaneously depressing both locking arms and pulling its connector away from the socket on the logic board toward the top of your iMac.
Use the flat end of a spudger to pry the Bluetooth antenna cable connector up off the Bluetooth board.
Carefully de-route the IR board cable out from under the IR board and move it out of the way of the logic board.
Disconnect the following connectors from the logic board:
Camera/IR board cable.
Optical drive fan.
Disconnect the optical drive thermal sensor cable from the logic board by pulling its connector away from the socket on the logic board.
Remove the two T6 Torx screws securing the optical drive ribbon cable connector to the logic board.
Use the flat end of a spudger to pry the optical drive ribbon cable connector up off the logic board.
Bend the optical drive ribbon cable back away from the logic board.
Hard drive thermal sensor cable.
CPU fan cable.
Remove the two T6 Torx screws securing the top of the heat sink framework to the chassis.
Remove the following seven screws securing the logic board to the rear case:
Three coarse-thread T10 Torx.
Three fine-thread T10 Torx.
One long coarse-thread T10 Torx.
Carefully rotate the top edge of the logic board out of the rear case and lift the board up out of the iMac, minding the RAM arms and any cables that may get caught.
If necessary, remove the tape covering the metal chassis where the AC-In cable resides.
Use a pair of tweezers to pull the AC-In cable out from underneath the chassis.
Disconnect the AC-In cable by depressing the lock mechanism while pulling the connector away from its socket.
Remove four T10 Torx screws securing the power supply to the rear case.
Lift the power supply out of the rear case, minding the AC-in cable that may get caught.
82 weitere Nutzer:innen haben diese Anleitung absolviert.
9 Kommentare
Excellent guide !
Great guide! Powered down computer prior to vacation and came back to find it non-operative. This guide, about 90 minutes, and a $50 replacement power supply off of ebay and it is back up and running. This is a secondary computer we don't use much any more, but I hated to throw it out when it was still working for what we were using it for. Thanks so much!
