Einleitung
Restore sound to your iMac by replacing the audio board.
Loosen the single Phillips screw in the center of the access door.
Remove the access door from your iMac.
Stick two suction cups to opposing corners of the glass panel.
Remove the following 12 screws securing the front bezel to the rear case:
Eight 13 mm T8 Torx.
Four 25 mm T8 Torx.
Place your hands at the top corners of the bezel (to the side) and lift the bezel 2-3cm from the body by working from the top. After this you can also disengage the bottom of the bezel (the memory modules will prevent the bottom of the bezel to detach first). When reassembling, start with the bottom of the bezel.
Pull the LCD temperature sensor connector straight up out of its socket on the logic board.
If necessary, de-route the LCD temperature sensor cable from behind the logic board.
Remove the two 5.3 mm T6 Torx screws securing the data display cable to the logic board.
Use the attached black tab to pull the data display cable connector away from the logic board.
Remove the eight 12 mm T8 Torx screws securing the display panel to the rear case.
Lift the display panel from its left edge and rotate it toward the right edge of the iMac.
With the display panel still lifted, disconnect the four inverter cables.
If you are replacing a hard drive and have an extra set of hands, it is possible to reach in and remove the drive without disconnecting anything but the LCD temp and display connector in the previous step with the LCD in its propped position.
Disconnect the right speaker cable connector from the audio board by pulling it straight up from its socket.
Remove the single 12 mm T10 Torx screw securing the right speaker to the rear case.
Disconnect the left speaker cable connector from the audio board by pulling it straight away from its socket.
Disconnect the microphone cable connector from the audio board by pulling it straight up from its socket.
Using the tip of a spudger, flip up the audio to logic board ribbon cable retaining flap (toward the bottom of your iMac).
Pull the audio to logic board ribbon cable straight out of its socket.
Remove the four 5.4 mm T6 Torx screws securing the audio board to the logic board.
7 weitere Nutzer haben diese Anleitung absolviert.
