Zum Hauptinhalt wechseln
iMac Intel 20" EMC 2133 and 2210 Logic Board Replacement
Was du brauchst
  1. iMac Intel 20" EMC 2133 and 2210 Logic Board Replacement, Access Door: Schritt 1, Bild 1 von 1
    • Loosen the single Phillips screw in the center of the access door.
    • This screw is captive in the access door.
    • Remove the access door from your iMac.
    • The glass panel is fixed onto the front bezel with fourteen magnets around its perimeter.
    • Stick two suction cups to opposing corners of the glass panel.
    • To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
    • If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent such as Windex.
  2. iMac Intel 20" EMC 2133 and 2210 Logic Board Replacement: Schritt 3, Bild 1 von 1
    • Gently pull the glass panel straight up off the iMac.
    • The glass panel has several positioning pins around its perimeter. To avoid shearing these pins off the glass panel, be sure to only pull straight up during removal.
    • Be meticulous about cleaning the LCD and the inside face of the glass panel before reinstallation, as any fingerprints or dust trapped inside will be annoyingly visible when the display is on. Placing the glass flat, inside face down, on a fresh aluminum-foil surface is a good way to keep it clean.
  3. iMac Intel 20" EMC 2133 and 2210 Logic Board Replacement, Front Bezel: Schritt 4, Bild 1 von 1
    • Remove the following 12 screws securing the front bezel to the rear case:
    • Eight 13 mm T8 Torx.
    • Four 25 mm T8 Torx.
  4. iMac Intel 20" EMC 2133 and 2210 Logic Board Replacement: Schritt 5, Bild 1 von 1
    • Place your hands at the top corners of the bezel (to the side) and lift the bezel 2-3cm from the body by working from the top. After this you can also disengage the bottom of the bezel (the memory modules will prevent the bottom of the bezel to detach first). When reassembling, start with the bottom of the bezel.
    • The top of the bezel hosts a microphone attached to the logic board. Gently lift the bezel to not damage the microphone wiring or connector by accidentally pulling the cable.
    • At this point, you can either detach the microphone cable and remove the bezel, or keep the microphone cable attached and rest the bezel on your work surface or the chassis of the Mac.
    • To fully detach the bezel: disconnect the microphone cable connector, removing tape as necessary.
    • To keep it attached, leave the microphone cable attached to the logic board, and place the bezel 'above' the chassis, with the microphone cable forming a hinge.
    • If you keep the microphone attached to the chassis, make sure you don't accidentally damage the microphone or logic board by bumping into the loose bezel.
  5. iMac Intel 20" EMC 2133 and 2210 Logic Board Replacement: Schritt 6, Bild 1 von 2 iMac Intel 20" EMC 2133 and 2210 Logic Board Replacement: Schritt 6, Bild 2 von 2
    • When reassembling the bezel:
    • be sure to tuck the microphone cable and connector into the void next to the camera board.
    • Gently guide the microphone connector and cables through the ±1in long slot at the right of the iSight camera. Once the bezel is properly assembled, gently push the microphone connector and cable into the bezel through that slot.
  6. iMac Intel 20" EMC 2133 and 2210 Logic Board Replacement, Display Panel: Schritt 7, Bild 1 von 2 iMac Intel 20" EMC 2133 and 2210 Logic Board Replacement, Display Panel: Schritt 7, Bild 2 von 2
    • Pull the LCD temperature sensor connector straight up out of its socket on the logic board.
    • If necessary, de-route the LCD temperature sensor cable from behind the logic board.
    • When you remove the LCD, check the routing of the LCD temperature display cable. On reinstalling the display, be sure this cable does not block one of the bottom screws for the front bezel.
  7. iMac Intel 20" EMC 2133 and 2210 Logic Board Replacement: Schritt 8, Bild 1 von 1
    • Remove the two 5.3 mm T6 Torx screws securing the data display cable to the logic board.
  8. iMac Intel 20" EMC 2133 and 2210 Logic Board Replacement: Schritt 9, Bild 1 von 1
    • Use the attached black tab to pull the data display cable connector away from the logic board.
  9. iMac Intel 20" EMC 2133 and 2210 Logic Board Replacement: Schritt 10, Bild 1 von 2 iMac Intel 20" EMC 2133 and 2210 Logic Board Replacement: Schritt 10, Bild 2 von 2
    • Remove the eight 12 mm T8 Torx screws securing the display panel to the rear case.
    • Lift the display panel from its left edge and rotate it toward the right edge of the iMac.
  10. iMac Intel 20" EMC 2133 and 2210 Logic Board Replacement: Schritt 11, Bild 1 von 2 iMac Intel 20" EMC 2133 and 2210 Logic Board Replacement: Schritt 11, Bild 2 von 2
    • With the display panel still lifted, disconnect the four inverter cables.
    • During reinstallation, place the four inverter cable connectors in voids between components attached to the rear panel so the display panel will sit flush.
    • During reassembly, the order of the inverter cables is interchangeable within each socket.
    • If you are replacing a hard drive and have an extra set of hands, it is possible to reach in and remove the drive without disconnecting anything but the LCD temp and display connector in the previous step with the LCD in its propped position.
  11. iMac Intel 20" EMC 2133 and 2210 Logic Board Replacement, Left Speaker: Schritt 12, Bild 1 von 1
    • Disconnect the left speaker cable connector from the audio board by pulling it straight away from its socket.
    • Pull the connector parallel to the face of the logic board.
  12. iMac Intel 20" EMC 2133 and 2210 Logic Board Replacement: Schritt 13, Bild 1 von 1
    • De-route the left speaker cable from the channel in the CPU fan. Continue completely de-routing the cable through the undersides of the IR board and heat sink.
  13. iMac Intel 20" EMC 2133 and 2210 Logic Board Replacement: Schritt 14, Bild 1 von 1
    • Disconnect the ambient temperature sensor cable by pulling its connector straight up off the logic board.
  14. iMac Intel 20" EMC 2133 and 2210 Logic Board Replacement: Schritt 15, Bild 1 von 1
    • If necessary, de-route the ambient temperature sensor cable from under the power button cables.
  15. iMac Intel 20" EMC 2133 and 2210 Logic Board Replacement: Schritt 16, Bild 1 von 2 iMac Intel 20" EMC 2133 and 2210 Logic Board Replacement: Schritt 16, Bild 2 von 2
    • Remove the single 28 mm T10 Torx screw securing the left speaker to the rear case.
    • Lift the left speaker up and out of the rear case. Don't try to slide the speaker out, since there is a plastic mounting pin under the top end of the speaker housing that holds it in place.
  16. iMac Intel 20" EMC 2133 and 2210 Logic Board Replacement, Logic Board: Schritt 17, Bild 1 von 1
    • Disconnect the power button and CPU fan by lifting their connectors straight up off the logic board.
    • Disconnect the SATA data cable from the logic board by carefully pulling it straight away from its socket.
    • The SATA connector on most iMacs tends to stick in its socket on the logic board. If you are having trouble disconnecting the SATA cable, insert a metal spudger or any other thin tool into the gap between the SATA connector and its socket and twist the spudger's shaft to safely separate the two pieces.
  17. iMac Intel 20" EMC 2133 and 2210 Logic Board Replacement: Schritt 19, Bild 1 von 1
    • Pull the SATA data cable out of its channel in the logic board and tuck it aside near the left edge of the rear case.
  18. iMac Intel 20" EMC 2133 and 2210 Logic Board Replacement: Schritt 20, Bild 1 von 2 iMac Intel 20" EMC 2133 and 2210 Logic Board Replacement: Schritt 20, Bild 2 von 2
    • Disconnect the DC-in cable by simultaneously depressing both locking arms and pulling its connector away from the socket on the logic board.
    • After both locking arms pass their retaining tabs, it is helpful to push them toward the left edge of your iMac with one hand while pulling on the body of the connector with your other hand.
  19. iMac Intel 20" EMC 2133 and 2210 Logic Board Replacement: Schritt 21, Bild 1 von 2 iMac Intel 20" EMC 2133 and 2210 Logic Board Replacement: Schritt 21, Bild 2 von 2
    • Use the flat end of a spudger to pry both AirPort antenna connectors up off the AirPort card.
  20. iMac Intel 20" EMC 2133 and 2210 Logic Board Replacement: Schritt 22, Bild 1 von 1
    • Move both AirPort antennas toward the lower edge of your iMac, out of the way of the logic board.
  21. iMac Intel 20" EMC 2133 and 2210 Logic Board Replacement: Schritt 23, Bild 1 von 1
    • Use the flat end of a spudger to pry the Bluetooth antenna connector up off the Bluetooth board.
  22. iMac Intel 20" EMC 2133 and 2210 Logic Board Replacement: Schritt 24, Bild 1 von 1
    • Pull the camera cable connector straight up out of its socket on the logic board.
  23. iMac Intel 20" EMC 2133 and 2210 Logic Board Replacement: Schritt 25, Bild 1 von 1
    • Pull the right speaker cable connector straight up out of its socket on the audio board.
  24. iMac Intel 20" EMC 2133 and 2210 Logic Board Replacement: Schritt 26, Bild 1 von 2 iMac Intel 20" EMC 2133 and 2210 Logic Board Replacement: Schritt 26, Bild 2 von 2
    • Remove the single 12 mm T10 Torx screw securing the right speaker to the rear case.
    • Lift the right speaker up and out of the rear case, to clear the plastic mounting pins underneath it.
  25. iMac Intel 20" EMC 2133 and 2210 Logic Board Replacement: Schritt 27, Bild 1 von 1
    • Lift the optical drive fan connector straight up out of its socket on the logic board.
  26. iMac Intel 20" EMC 2133 and 2210 Logic Board Replacement: Schritt 28, Bild 1 von 2 iMac Intel 20" EMC 2133 and 2210 Logic Board Replacement: Schritt 28, Bild 2 von 2
    • Use the flat end of a spudger to pry the optical drive cable clip up off the optical drive connector.
    • Lift the optical drive cable clip off the logic board.
    • During reinstallation, be sure the two raised bumps on the lower edge of the optical drive cable clip lock into the two voids on the underside of the optical drive socket.
  27. iMac Intel 20" EMC 2133 and 2210 Logic Board Replacement: Schritt 29, Bild 1 von 1
    • Push the optical drive cable connector toward the top of your iMac to disconnect it from the logic board.
  28. iMac Intel 20" EMC 2133 and 2210 Logic Board Replacement: Schritt 30, Bild 1 von 1
    • Lift the microphone cable connector straight up out of its socket on the audio board.
    • During reinstallation, ensure that the mic cable runs between the ODD fan and the board support. If the cable runs on the wrong side of the support, the cable will be too short to plug in.
  29. iMac Intel 20" EMC 2133 and 2210 Logic Board Replacement: Schritt 31, Bild 1 von 1
    • If necessary, remove the piece of tape securing the thermal sensor and fan cables to the chassis.
  30. iMac Intel 20" EMC 2133 and 2210 Logic Board Replacement: Schritt 32, Bild 1 von 1
    • Disconnect the following three cables from the logic board:
    • Hard drive thermal sensor.
    • Optical drive thermal sensor.
    • Hard drive fan.
    • When removing these connectors, it is helpful use your thumbnails to push the ears on either side of the connector toward the top of your iMac.
  31. iMac Intel 20" EMC 2133 and 2210 Logic Board Replacement: Schritt 33, Bild 1 von 1
    • Remove the following 13 screws securing the logic board to the rear case:
    • Six 7.2 mm coarse-thread T10 Torx.
    • Two 6.8 mm T8 Torx. When reinstalling these two screws, don't overtighten them, as the plastic tabs they hold down are thin and brittle, and can crack.
    • Three 7 mm fine-thread T10 Torx.
    • Two 24 mm T10 Torx.
  32. iMac Intel 20" EMC 2133 and 2210 Logic Board Replacement: Schritt 34, Bild 1 von 1
    • Lift the logic board out of the rear case, minding any cables that may get caught.
    • If the front edge of the logic board, under the RAM sockets, won't pull up, it's sticking on the three plastic mounting pins in the rear housing under this edge. Use a spudger under the front edge of the RAM sockets to gently push up on this edge until it clears these mounting pins.
Abschluss
45 weitere Nutzer:innen haben diese Anleitung absolviert.
7 Kommentare
Superb instructions. just replaced my iMac 2007 with another motherboard as I had a faulty ram slot and put in a new SSD hard drive. Would have struggled without this step by step guide.
john riley - Antwort
Thanks. I was able to successfully replace the logic board following these instructions. I'm not sure I would have been able to do it on my own.
Robert Moses - Antwort
How is named the block right above the ram slots? This thing covered with the bright aluminium « mini-Manhattan » :)  (or « porcupine »)?
I thought it was the CPU itself but if I read correctly, CPU is under the 45° structure. Right? Thank you.
Peri Vanvuchelen - Antwort
I’m sorry for the late answer, but I believe the chip under that heat sink is the North Bridge. It controls data transfer between the CPU, RAM, and graphics.
William Trammell -
What is the thing above the ram slots? That thing with the bright aluminium « porcupine » on top of it ;) thank you
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 14
Letzte 30 Tage: 58
Insgesamt: 53,859
