Einleitung
Upgrade your RAM for an instant increase in speed.
EMC 2133 models use PC2-5300 RAM and EMC 2210 models use PC2-6400 RAM. The maximum RAM for both models is 6 GB.
Werkzeuge
Ersatzteile
Loosen the single Phillips screw in the center of the access door.
Remove the access door from your iMac.
Use the tip of a spudger to pull the black plastic RAM tabs out of the memory bay.
Pull the black plastic RAM tab away from your iMac to eject the RAM chip.
152 weitere Nutzer haben diese Anleitung absolviert.
12 Kommentare
I currently have a 4GB memory module installed on an EMC 2210 in one of the memory slots. Can I still install the original 1GB ram in the other slot making it 5GB total memory?
[|It depends on the model. Check here:] https://support.apple.com/en-us/HT201191
Alex Nos -
Thank you for the guide. I had 2GB. I took out 1 module to add a 4GB module. So easy and now my 2133 iMac is jaw dropping fast.
Garison
Hi Garison,
I hope you can answer my question. I have an iMac, medio 2007, Intel 20" EMC 2133.
RAM: (1GB + 1GB) 667 MHz DDR2 SDRAM.
I would like to make my iMac "jaw dropping fast" as well ;-)
Is it PC 5300 or PC 6400 I should buy?
And what setup wold you recommend? (1GB + 2GB), (1GB + 4GB), (2GB + 2GB) or (2GB + 4GB)?
Thanks,
Mikkel
