Einleitung
Prereq-only guide to remove the entire display assembly.
Was du brauchst
In diesem Schritt verwendetes Werkzeug:Plastic Cards$2.99
Grasp the small tab at the end of one of the bottom edge display adhesive strips and pull the adhesive toward the top of the iMac to remove it.
Repeat this step with the other adhesive strip and remove it.
Lift the display up from the frame and remove it from the iMac.
It may be necessary to slowly lift from one side to peel against the remaining adhesive.
