Einleitung
Follow the steps in this guide to replace the front panel in a 21.5" Retina 4K Late 2015 iMac.
This procedure involves removing the faulty/broken display, as well as transferring the display data cable and thermal sensor to a new display.
Was du brauchst
In diesem Schritt verwendetes Werkzeug:iMac Intel 21.5" Cardboard Service Wedge$4.99
Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
Starting on the left of the display, near the power button, insert the iMac Opening Tool into the gap between the glass panel and the rear enclosure.
Use the tool like a pizza cutter—roll it along through the gap, and it will cut the foam adhesive through the center.
Run the tool up along the left side of the display.
Finish pushing the opening tool to the bottom of the right side of the display.
In diesem Schritt verwendetes Werkzeug:Plastic Cards$2.99
Starting from the top right corner of the iMac, wedge a plastic card between the display and frame.
Gently twist the plastic card sideways to create a gap between the display and frame.
Move slowly and be careful not to stress the display glass too much—you only need to make a gap of about 1/4".
Slide the card toward the center of the display to cut any of the remaining adhesive along the top right corner of the iMac.
Wedge the plastic card into the top right corner once again, and leave it there to prevent the adhesive from resticking.
Insert a second plastic card into the gap between the display and frame near the top left corner of the iMac.
Gently twist the card upward, slightly increasing the space between the display and frame.
Slide the plastic card toward the center, again stopping just before the iSight camera.
With both plastic cards inserted as shown near the corners, gently twist the cards sideways to increase the gap between display and case.
Begin to lift the top of the display up from the frame.
Hold the display with one hand while using your other hand to unplug the display power cable.
Continuing to support the display with one hand, flip up the metal retaining bracket on the display data cable.
Carefully pull the display data cable from its socket on the logic board.
Grasp the small tab at the end of one of the bottom edge display adhesive strips and pull the adhesive toward the top of the iMac to remove it.
Repeat this step with the other adhesive strip and remove it.
Lift the display up from the frame and remove it from the iMac.
It may be necessary to slowly lift from one side to peel against the remaining adhesive.
Use your fingernail or the pointed tip of a spudger to flip up the retaining flap on the display data connector.
Pull the display data cable connector straight out of its socket on the back of the display.
Use an iOpener near the top edge of the display assembly to heat and soften the adhesive on the piece of tape holding the thermal sensor in place.
Peel up the piece of tape securing the thermal sensor to the back of the display assembly.
Use an opening pick to break up the adhesive holding the thermal sensor to the back of the iMac display.
Disconnect the thermal sensor from its socket on the back of the display.
Remove the thermal sensor and transfer it to your new display assembly.
19 weitere Nutzer:innen haben diese Anleitung absolviert.
8 Kommentare
Hello, I damages my iMac 2833 screen cable with mistake, I tried to find one compatible with this type but I didn't find one, c an you advise me how to find one or even repair the cable because the the wider end not damage but the other end... thanks in advance to your help...
Hi,
I am in need of a display data cable as shown above for the iMac 21.5” Late 2015. Anyone know where I can order one? Finding one on the interent is awfully confusing in identifying the correct cable.
Thanks.
See step 20 above for the display data cable needed.
Hola saludos excelente artículo los felicito. Tengo una duda. Mi IMac de. 21.5 Inch 4K sufrió un golpe en la parte superior de la pantalla. Luego del impacto la pantalla sigue funcionando normalmente, pero el glass está con grietas y astillado. Es necesario cambiarlo todo? O existe un repuesto solo del glass. Gracias por su orientacion
