Einleitung
Use this guide to replace a dead Bluetooth board.
Was du brauchst
Loosen the two Phillips screws securing the access door to your iMac.
Remove the access door.
Remove the following screws along the lower edge of your iMac:
Three 6 mm T8 Torx screws
One 8 mm T8 Torx screw
To lift the front bezel off the iMac, simultaneously:
Use your thumbs to press in the RAM arms and hold the iMac down.
Use your index fingers to pull the small bridge of material on the front bezel toward yourself.
Pull the front bezel up with your index fingers.
Once the small bridge of material has cleared the RAM arms, lift the front bezel by its lower edge just enough to clear the bottom edge of the rear case.
Lift the front bezel off the rear case and rotate it away from the bottom edge of the iMac, minding the camera and microphone cables still attached to its upper edge.
Disconnect the microphone cable.
Disconnect the camera cable by pulling its connector away from the socket on the camera board.
Use the flat end of a spudger to pry the Bluetooth antenna connector off the Bluetooth board.
Use the flat end of a spudger to gently pry the right side of the Bluetooth board away from the logic board.
Maneuver the Bluetooth board out from under the inverter cable and remove it from the iMac.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
