Einleitung
Use this guide to replace your optical drive cable.
Ersatzteile
Keine Ersatzteile angegeben.
Loosen the two Phillips screws securing the access door to your iMac.
Remove the access door.
Remove the following screws along the lower edge of your iMac:
Three 6 mm T8 Torx screws
One 8 mm T8 Torx screw
To lift the front bezel off the iMac, simultaneously:
Use your thumbs to press in the RAM arms and hold the iMac down.
Use your index fingers to pull the small bridge of material on the front bezel toward yourself.
Pull the front bezel up with your index fingers.
Once the small bridge of material has cleared the RAM arms, lift the front bezel by its lower edge just enough to clear the bottom edge of the rear case.
Lift the front bezel off the rear case and rotate it away from the bottom edge of the iMac, minding the camera and microphone cables still attached to its upper edge.
Disconnect the microphone cable.
Disconnect the camera cable by pulling its connector away from the socket on the camera board.
Peel the two highlighted EMI shield tabs off the frame of the LCD.
Remove the two T6 Torx screws securing the display data cable to the logic board.
Pull the black plastic tab attached to the display data cable connector to disconnect it from the logic board.
Use your fingertips to pull both sides of the wide inverter cable connector out of its socket on the logic board.
De-route the inverter cable from its location next to the CPU fan.
Remove the eight T8 Torx screws securing the display assembly to the rear case.
Remove the strip of tape covering the optical drive cable connector.
Gently pull the cable retainer on the optical drive cable ZIF socket toward the right side of the iMac.
Pull the optical drive ribbon cable out of its socket, being careful not to rip it in the process.
Pull the optical drive thermal sensor connector toward the right side of the iMac to disconnect it from the logic board.
Peel off the strip of EMI tape attaching the right side of the optical drive to the rear case.
Push down on the optical drive bracket retaining clip while pulling the top edge of the optical drive away from the rear case.
Rotate the optical drive slightly toward the bottom edge of the iMac while pulling it away from the rear case to release the lower retaining clip.
Pull the optical drive away from the right side of the rear case and remove it from the iMac.
Remove the two T6 Torx screws securing the optical drive cable to the optical drive.
Insert the flat end of a spudger into the gap between the optical drive cable connector and the optical drive.
Twist the spudger to separate the connector from the optical drive.
2 weitere Nutzer haben diese Anleitung absolviert.
