Zum Hauptinhalt wechseln
iMac Intel 24" EMC 2111 RAM Replacement
Was du brauchst
  1. iMac Intel 24" EMC 2111 RAM Replacement, Access Door: Schritt 1, Bild 1 von 2 iMac Intel 24" EMC 2111 RAM Replacement, Access Door: Schritt 1, Bild 2 von 2
    • Loosen the two Phillips screws securing the access door to your iMac.
    • Both screws remain captive within the access door.
    • Remove the access door.
  2. iMac Intel 24" EMC 2111 RAM Replacement, RAM: Schritt 2, Bild 1 von 1
    • Pull both RAM arms away from the iMac to release both RAM chips from their sockets.
  3. iMac Intel 24" EMC 2111 RAM Replacement: Schritt 3, Bild 1 von 1
    • Pull both RAM chips out of their slots.
    • During reinstallation, make sure both RAM arms are fully rotated outward before inserting the RAM chips. Use your thumbs to seat the new RAM chips into their sockets and then press the RAM arms back into the iMac.
    • It is normal to encounter a fair amount of resistance when pushing the RAM arms back into the iMac.
Abschluss
20 weitere Nutzer:innen haben diese Anleitung absolviert.
3 Kommentare
Hi, i'd love to make some upgrades but can't remember which imac 24is mine. Where can I read it? Can I switching it on? Thanks
Fabrizio Lazzeretti - Antwort
hello, i already have 2GB, is it possible to add more? thank you!
connie dekker - Antwort
via Everymac.com
Standard RAM: 1 GB Maximum RAM: 4 GB*
Details: 1 GB of RAM is installed as two 512 MB SO-DIMM modules.
*Apple officially supports 3 GB of RAM, but third-parties have been able to upgrade the system to 4 GB of RAM using two 2 GB memory modules
emaginechild -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 35
Insgesamt: 16,343
