Einleitung
Use this guide to replace or upgrade your hard drive for more storage space.
Was du brauchst
Lay your iMac front side down on a table with the lower edge facing yourself.
Loosen the single Phillips screw in the center of the access door.
Remove the access door from your iMac.
In diesem Schritt verwendetes Werkzeug:Heavy-Duty Suction Cups (Pair)$14.95
Stick two suction cups to opposing corners of the glass panel.
Remove the following 12 screws securing the front bezel to the rear case:
Eight 13 mm T8 Torx.
Four 25 mm T8 Torx.
Gently lift the front bezel from its top edge off the rear case.
Once the top edge of the front bezel has cleared the rear case, rotate the front bezel toward the stand and lift it off the rear case.
Rotate the front bezel away from the rest of the device and lay it above the top edge of the iMac.
Remove the two 5.3 mm T6 torx screws from the LCD connector.
Firmly grasp the pull tab on top of the connector and pull it straight up out of its port.
Place your hands on either side of the bottom of the display panel, and lift it up enough that you can reach the connectors inside.
While holding the display panel up with one hand, locate and remove the display thermal sensor cable from its connector.
While still holding the display panel up, use two fingers to firmly push down on the power supply cable connector from its socket.
To remove the hard drive bracket, squeeze the middle against the side of the hard drive while rotating the top left edge toward yourself.
After the left edge has been freed, rotate the bracket toward the right edge of the hard drive.
Lift the hard drive bracket straight up off the chassis.
If present, remove the small piece of tape covering the hard drive and optical drive temperature sensor cables.
Pull the hard drive temperature sensor cable straight away from its socket on the logic board.
Rotate the top of the drive toward yourself, then lift the hard drive straight up off its lower pins.
Insert the flat end of a spudger between the SATA data cable and the edge of the hard drive.
Twist the spudger to separate the SATA data cable from the hard drive.
Disconnect the SATA data cable from the hard drive.
Lift the hard drive out of your iMac, minding the thermal sensor cable that may get caught.
Remove the two T8 Torx screws and their attached rubber grommets from the hard drive.
Remove the two T8 Torx pins from the side of the hard drive nearest the power and data connectors.
To remove the hard drive thermal sensor, use the sharp end of a spudger to lift the center finger of the thermal sensor bracket while applying slight tension to the thermal sensor cable.
Use the flat end of a spudger to pry the hard drive thermal sensor bracket up off the adhesive securing it to the hard drive.
Use a spudger to remove the small piece of EMI foam from the top of the hard drive.
206 weitere Nutzer:innen haben diese Anleitung absolviert.
17 Kommentare
Exellent instructions....
I just installed a new HD on my iMac 8,1. Intalled the OS from original disc, it was 10.5.2, I don't know how to upgrade the OS.
I did software update, but only got 10.5.8. ¿what can I do? I would like to install Yosemite at least...
Any help?
You need to get to 10.6.8 via physical media, then app store update from there. I have read that Apple will send you a dvd for no cost, but the official price is $19.
I has a 8.1 as well , running Ubuntu 22.04 is great ! Stop obsolete OSX
