Zum Hauptinhalt wechseln
iMac Intel 27" EMC 2429 RAM Replacement
Was du brauchst
  1. iMac Intel 27" EMC 2429 RAM Replacement, Access Door: Schritt 1, Bild 1 von 2 iMac Intel 27" EMC 2429 RAM Replacement, Access Door: Schritt 1, Bild 2 von 2
    • Loosen the three Phillips screws securing the access door to the bottom edge of your iMac.
    • These screws will remain captive in the access door.
    • Remove the access door from your iMac.
    • During reassembly, fasten the access door loosely and align it with the pocket cut into the outer case of the iMac before fully tightening the screws.
  2. iMac Intel 27" EMC 2429 RAM Replacement, RAM: Schritt 2, Bild 1 von 1
    • Use your fingers or the tip of a spudger to slide the black plastic RAM tray pull tab out of the RAM slot.
  3. iMac Intel 27" EMC 2429 RAM Replacement: Schritt 3, Bild 1 von 2 iMac Intel 27" EMC 2429 RAM Replacement: Schritt 3, Bild 2 von 2
    • Pull the black plastic tab away from the iMac to eject the RAM chip from its socket.
    • The RAM modules are firmly seated and may require a fair amount of force to remove.
    • Use your fingers to slide the RAM chip out of its socket.
    • If necessary, repeat this process for the other RAM module(s).
Abschluss
90 weitere Nutzer:innen haben diese Anleitung absolviert.
Phillip Takahashi
86.752 Reputation
87 Anleitungen geschrieben
14 Kommentare
My iMac 21.5-inch Mid 2011 has EMC 2428, but still directions turned out to be the same.
I replaced the memory in my MacBook Pro, and used the old cards (2x2GB) to fill out the 2 empty slots that apple left empty, doubled the memory of 2 machines for the price of one ^_^
Mabel - Antwort
So confused. I have an end 2429 and I ordered some memory hut its says notebook memory, do these machines use the same type of ram?
Kosta Kritikos -
Thanks ifixit team, I did it. It is really piece of cake! Thanks again!
prelude0214 - Antwort
What's the real max capacity for the RAM?
Angel Pimienta - Antwort
16 Gb (4 x 4 Gb) DDR3 1333 MHz
Aleksei Marinichev -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 39
Letzte 30 Tage: 177
Insgesamt: 83,056
