Einleitung
This guide covers the disassembly of the iON SnapCam 1045 battery.
Was du brauchst
Detach the magnetic clip from the bottom of the camera.
The magnetic clip gets in the way of disassembly because it constantly spins and therefore a distraction so it is imperative to detach.
Use a Phillips #000 Screwdriver to loosen the 0.008 mm screw located between the USB and memory card slots.
Once again use the spudger to gently open the encasement.
The Battery can be safely detached and replaced.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
