Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
A basic representation on replacing the lens on the iON SnapCam 1045.
  1. Detach the magnetic  clip from the bottom  of the camera.
    • Detach the magnetic clip from the bottom of the camera.
    • The magnetic clip gets in the way of disassembly because it constantly spins and therefore a distraction so it is imperative to detach.
  2. Use a spudger to  gently detach  the  memory card and USB slot cover.
    • Use a spudger to gently detach the memory card and USB slot cover.
  3. Use a Phillips #000 Screwdriver to  loosen the 0.008 mm screw  located between the USB and memory card slots.
    • Use a Phillips #000 Screwdriver to loosen the 0.008 mm screw located between the USB and memory card slots.
    • This screw is really tiny and can easily fall off and get lost! Make use of a magnetic mat to hold it in place or better still put the magnetic clip to use for keeping the screw safe.
  4. Once again use the spudger to gently open the encasement. The case is a little fragile and forceful entry could lead to damage of the plastic case. Thread carefully.
    • Once again use the spudger to gently open the encasement.
    • The case is a little fragile and forceful entry could lead to damage of the plastic case. Thread carefully.
    • The Battery can be safely detached and replaced.
  5. To get to the motherboard, safely lift the battery to expose  an Aluminium plate that shields and holds the motherboard in place.
    • To get to the motherboard, safely lift the battery to expose an Aluminium plate that shields and holds the motherboard in place.
    • The plates are held down by four Phillips 0.008 mm screws on all four corners. Use a Phillips head #000 to safely loosen the screws.
  6. To replace the motherboard gently insert a plastic opening tool into one end and lift up.
    • To replace the motherboard gently insert a plastic opening tool into one end and lift up.
    • Be careful to avoid inserting material that is rough and too sturdy as it can damage components on the motherboard.
  7. The motherboard is in plain sight . The lens assembly is located  on the lower left part of the  motherboard just to the left of the power button.
    • The motherboard is in plain sight . The lens assembly is located on the lower left part of the motherboard just to the left of the power button.
    • To replace the lens assembly, simply flip it up and detach.
Abschluss
Jessica Matias
201 Reputation
2 Anleitungen geschrieben
IUPUI, Team S3-G3, Wilson Fall 2017 Mitglied von IUPUI, Team S3-G3, Wilson Fall 2017
IUPUI-WILSON-F17S3G3
3 Mitglieder
3 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 6
Insgesamt: 154
