1. Remove any external skins placed on the device. To do so, simply lift up and peel to remove.
    • Remove any external skins placed on the device. To do so, simply lift up and peel to remove.
  2. Firmly pull on the back clip in order to remove.
    • Firmly pull on the back clip in order to remove.
    • Use a Phillips head screwdriver to remove the four 4mm PH00 screws located on the sides of the device. All screws are located under each of the grey covers for the microSD card and the microUSB insert.
    • Grab a metal or plastic opening tool and insert it into the middle slot on the bottom of the camera and lightly pry open.
    • Locate the camera lens in the bottom left-hand corner of the picture which can be replaced by replacing the entire cover. The back of the cover is also shown. The camera is now located in the top right-hand corner of the picture.
    • Using the nylon spudger, pop up the edges of the motherboard.
    • With the Micro USB port exposed, part can be replaced with advanced soldering and circuitry.
Abschluss
Baleigh Hance
Mitglied seit 20.11.2017
101 Reputation
1 Anleitung geschrieben
IUPUI, Team S22-G4, Bayer Fall 2017 Mitglied von IUPUI, Team S22-G4, Bayer Fall 2017
IUPUI-BAYER-F17S22G4
5 Mitglieder
4 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 40
