Zum Hauptinhalt wechseln
Einleitung
Internal prereq removal with front panel already removed.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Use the edge of a plastic opening tool to flip up the retaining flap on the headphone jack and front camera cable ZIF socket. Be sure you are prying upward on the hinged retaining flap, not the socket itself.
    • Use the edge of a plastic opening tool to flip up the retaining flap on the headphone jack and front camera cable ZIF socket.
    • Be sure you are prying upward on the hinged retaining flap, not the socket itself.
    • Peel the headphone jack and front camera cable off the rear case.
  2. Pull the headphone jack and front camera ribbon cable straight out of its socket on the logic board.
    • Pull the headphone jack and front camera ribbon cable straight out of its socket on the logic board.
  3. Remove the three 2 mm Phillips screws securing the SIM card slot to the rear panel.
    • Remove the three 2 mm Phillips screws securing the SIM card slot to the rear panel.
  4. Android Fix Kits
    A new screen or battery is one kit away.
    Jetzt kaufen
    Android Fix Kits
    Jetzt kaufen
  5. Remove the two 2.9 mm Phillips screws securing the headphone jack to the top edge of the rear panel.
    • Remove the two 2.9 mm Phillips screws securing the headphone jack to the top edge of the rear panel.
  6. Use a plastic opening tool to help pull the headphone jack out of its recess in the top of the rear panel.
    • Use a plastic opening tool to help pull the headphone jack out of its recess in the top of the rear panel.
    • Don't try to remove the assembly just yet, the ribbon cables are still connected.
  7. Peel the front camera and microphone cables off the rear panel.
    • Peel the front camera and microphone cables off the rear panel.
  8. Carefully remove the strip of tape covering the front camera cable connector. Use a plastic opening tool to disconnect the front camera cable from the microphone cable immediately below it.
    • Carefully remove the strip of tape covering the front camera cable connector.
    • Use a plastic opening tool to disconnect the front camera cable from the microphone cable immediately below it.
  9. Peel the front camera cable off the microphone cable.
    • Peel the front camera cable off the microphone cable.
Abschluss
Andrew Optimus Goldheart
426.171 Reputation
411 Anleitungen geschrieben
iFixit Mitglied von iFixit
Community
106 Mitglieder
9.284 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 197
