Zum Hauptinhalt wechseln
Einleitung
Internal guide for removing LCD before logic board.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Carefully lay the LCD next to the rear panel. Use a plastic opening tool to lift the display data cable lock upwards. Pull the display data cable out of its socket.
    • Carefully lay the LCD next to the rear panel.
    • Use a plastic opening tool to lift the display data cable lock upwards.
    • Pull the display data cable out of its socket.
    • Do not pull the connector upward as you disconnect it from its socket.
  2. Remove the LCD assembly from the rear panel assembly.
    • Remove the LCD assembly from the rear panel assembly.
Abschluss
Andrew Optimus Goldheart
425.415 Reputation
411 Anleitungen geschrieben
iFixit Mitglied von iFixit
Community
104 Mitglieder
9.214 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 140
