Einleitung
Prereq only, new front panel adhesive strips.
Was du brauchst
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Carefully peel off the first trapezoidal adhesive strip with a pair of tweezers.
Using a pair of tweezers, place the first trapezoidal adhesive strip (minding its correct orientation) on the matching side of the home button mounting bracket.
Use a pair of tweezers to grasp the corner of one of the adhesive strips placed on the mounting bracket.
Lift and peel the clear backing up off the adhesive strip, revealing the black adhesive strip.
