Einleitung
Hier wird der Austausch von Einschaltknopf/Lautstärkeregler gezeigt.
Wir empfehlen die Mikrowelle vor dem Gebrauch zu reinigen, da sonst Essensreste oder Ähnliches am iOpener hängenbleiben können. Lege den iOpener in die Mitte der Mikrowelle.
  • Wir empfehlen die Mikrowelle vor dem Gebrauch zu reinigen, da sonst Essensreste oder Ähnliches am iOpener hängenbleiben können.
  • Lege den iOpener in die Mitte der Mikrowelle.
    • Für sich drehende Mikrowellen: Stelle sicher, dass der Teller sich drehen kann. Wenn der iOpener hängenbleibt kann er sich überhitzen und sogar Feuer fangen.
which temperature must be used for heating? Thx
fbarletta - Antwort
I found you need to be very patient when using the iOpener. It's worth taking your time, giving the heat time to work on the glue. When I finally got the battery out, there were some strips of glue left behind that I just cleaned off with some isopropanol before installing the new battery.
By the way, I had to run the iOpener for longer in my microwave for it to get hot enough. When it was too hot to touch, I figured it was hot enough for the batteries.
Fredrik -
I didn't find this to be as hard as I had built it up in my mind to be; HOWEVER, saying that I need to say years ago I was the local Nokia service center in my town. But many years ago right after they got rid of analog times. Yeah. A classic installer/repairer mistake when starting something they haven't fixed or installed before is picking up the instructions, flipping through them; maybe even reading a section that is new-then tossing the instructions over the shoulder. "I got this." This usually comes right before something major gets broke. And I can tell you when you try to do it yourself and then mess it up horribly then take it to the repair shop. Well we called that "I can do it myself" syndrome and charged extra to put back together what they brought in in the box. Now knowing all this - I can't stress this enough because I am stupid, stupid, stupid. COVER YOUR SCREEN IN CLEAR BOXING TAPE AND READ ALL THE INSTRUCTION BELOW THROUGH TO THE END BEFORE EVEN ATTEMPTING THIS FIX. Take my advise.
windizy - Antwort
I didn't have an iOpener, so I used a wheat type heat bag. If you do this though, make sure you put a layer of plastic between your Mac and the bag, or you'll get condensation in places you don't want it.
Martin Gray - Antwort
I started out using the iOpener but switched to my wife's hairdryer. A heat gun or hair dryer proved to be much more convenient and is a time saviour. You can heat more and the glue becomes more fluid make the next steps with the opening picks much easier
Jan Van Puymbroeck - Antwort
Use a hair dryer! Watch this vid: https://youtu.be/16GkvjVyOJA It is much easier to do if you heat it from the other side.
Fletcher Carpenter - Antwort
I wonder how many people actually wrapped in their iPhone into iOpener and put this "sandwich" into microwave??
putinaspiliponis - Antwort
I know this is obvious, but backup your iPad with iTunes before you start. I'd also turn off your passcode if you have one.
Laurie Higgins - Antwort
Ther first time you heat up the iOpener for this repair when its room temperature I had to heat it up for more than 30 seconds. I remember I had to heat it up for around 45 seconds. However, after that when you need to reheat it again during the repair 30 seconds will be enough.
Yousef Ghalib - Antwort
I've been with Samsung for 8 years now!! Never did i have a case on any of my phones My Samsung 8 is 2 months old the case protector around the edge pop off and broke my phone it's like someone put a bullet hole in it
Sherry Carew - Antwort
Not everybody has a microwave. You need to state how long and at what temperature in a conventional oven.
Esmond Pitt - Antwort
Hi, the microware have multiple power 1 to 9, what must be used ?
Regards,
Cedric
Cedric VINCENT - Antwort
Erhitze den iOpener für dreißig Sekunden auf höchster Stufe.
  • Erhitze den iOpener für dreißig Sekunden auf höchster Stufe.
    • Während des Reperationsprozesses kühlt sich der iOpener wieder ab. Erhitze ihn dann noch einmal zusätzlich einmal für 30 Sekunden.
  • Achte darauf, den iOpener während der Reparatur nicht zu überhitzen. Eine Überhitzung bringt den iOpener möglicherweise zum Platzen.
  • Berühre niemals den iOpener, falls er dir geschwollen vorkommt.
  • Falls der iOpener in der Mitte immer noch zu heiß ist, um ihn anzufassen, dann benutze ihn weiter, bis er ein wenig herunter gekühlt ist, bevor du ihn erneut erhitzt. Ein ordnungsgemäß erhitzter iOpener sollte für bis zu 10 Minuten warm bleiben.
May I know the temperate limit about heating iOpener? (maximum 150 degrees Celsius?) thx so much.
yamayhuang - Antwort
I had to heat mine up for more than 30 seconds. After 30 seconds on high it was only warm. It had to keep trying different times and checking it until it got hot. I think the initial time that I put it in for was over a minute.
whale13 - Antwort
DO NOT USE IN NON ROTATING MICROWAVE! It will pop a hole. I had it in for 45 seconds the first time. It wasn't very hot inside and I saw it started to leak on the paper towel I put under it. Just a fair bit of advice. I think I will just stick with the heat gun. Loud but useful.
Alex Jackson - Antwort
I don't own a microwave.
mdanihy - Antwort
Its again waterproof when you change iphone 7 battery?
Jon - Antwort
I don't have a microwave???
Joe Blow - Antwort
30 sec at which equivalent watts setting and what temperature does iOpener heats up to for 30 secs. Only just bought it so needs info before using it. Thanks
Sam Stieg - Antwort
can i use just ordinary microwave???
juneseok kwon - Antwort
If I don't have a microwave then I try to use hot air gun so how many munuts i want to heat ?
Mohideen Rifay - Antwort
I heated mine up for 30 seconds, tested, then again for 30 seconds. It felt adequately hot. Leaving it on the left side, per the instruction, for a minute did not loosen the adhesive. I ended up pulling the suction cup hard enough to shadder the old screen. Moral of the story, I don't think it gets hot enough safely to have an affect.
Travis Dixon - Antwort
There is a clear problem here with the heating part using the iopener things....no details are given. Whoever is testing them needs to make it clear - What temperature does it need to be? And for which phone models, because they differ in what's needed. It's only £10-15 for a laser guided temp sensor unit, and the designers/repairers should have one of those already for doing these kinds of repairs. Explaining half a repair, is worse than not explaining at all :-(
assortedrubbish - Antwort
I used a hot water bottle, works well as it covers the whole screen and stays hot for longer.
dave - Antwort
If I may suggest include your microwave wattage so people can get an idea on time for there own
Patrick Storey - Antwort
I ended up using a hair dryer. That iOpener thing took forever.
mark fitzgerald - Antwort
Halte den iOpener an einem der flachen Enden und vermeide die heiße Mitte, während du ihn aus der Mikrowelle nimmst.
  • Halte den iOpener an einem der flachen Enden und vermeide die heiße Mitte, während du ihn aus der Mikrowelle nimmst.
  • Der Beutel wird sehr heiß, sei vorsichtig beim Gebrauch. Lege dir am besten einen Topflappen bereit.
Will a hair dryer work for heating the glass?
Me berg - Antwort
Yes, as does a heat gun.
anonymous 4602 - Antwort
Lasse den SIM Einschub mit einer SIM Auswurfnadel oder einer aufgebogenen Büroklammer herausspringen. Lasse den SIM Einschub mit einer SIM Auswurfnadel oder einer aufgebogenen Büroklammer herausspringen.
  • Lasse den SIM Einschub mit einer SIM Auswurfnadel oder einer aufgebogenen Büroklammer herausspringen.
Kommentar hinzufügen
Ziehe den SIM Einschub aus seinem Fach und entferne ihn vom iPad. Wenn nötig kannst du jetzt die SIM Karte herauslösen und austauschen.
  • Ziehe den SIM Einschub aus seinem Fach und entferne ihn vom iPad.
  • Wenn nötig kannst du jetzt die SIM Karte herauslösen und austauschen.
Wenn das Displayglas gesprungen ist, versuche die Splitter unter Verschluss zu halten und Verletzungen während der Reparatur zu vermeiden, indem du  das Glas mit Tape zusammenhälst. Lege sich überlappende Streifen aus durchsichtigem Packtape über das iPad Display,  bis die ganze Oberfläche bedeckt ist. Dadurch werden Glasscherben unter Verschluss gehalten und bauliche Intaktheit beim Hebeln und Display anheben sichergestellt.
  • Wenn das Displayglas gesprungen ist, versuche die Splitter unter Verschluss zu halten und Verletzungen während der Reparatur zu vermeiden, indem du das Glas mit Tape zusammenhälst.
  • Lege sich überlappende Streifen aus durchsichtigem Packtape über das iPad Display, bis die ganze Oberfläche bedeckt ist.
    • Dadurch werden Glasscherben unter Verschluss gehalten und bauliche Intaktheit beim Hebeln und Display anheben sichergestellt.
  • Gib dein Bestes, um den Rest der Anleitung wie beschrieben zu folgen. Da das Glas jedoch, sobald es einmal gebrochen ist, höchstwahrscheinlich weiter zersplittern wird, brauchst du eventuell ein metallenes Hebelwerkzeug, um das Glas herauszudrücken.
  • Trage eine Sicherheitsbrille, um deine Augen zu schützen und gebe darauf acht, das LCD nicht zu beschädigen.
Yes...wear safety glasses for sure when doing this!
Josh West - Antwort
If you have ANY cracks FOR SURE do the tape. I would also make sure to wear safety glasses as it can fly all over even with the tape. And do it somewhere that you don't mind tiny glass shards going everywhere. I had one 3 inch crack in the glass in the lower right corner and it started spidering. The plastic pics don't work once well once they hit a broken point in the glass so you better have a lot of heat to loosen the adhesive, or you end up using an exacto knife to get around the cracked spots.
jesseokerlund - Antwort
On a few occasions I had an unexpected pop as the glass shattered and little shards struck me in the face. I had taped the surface but pieces at the edge still managed to break free. My advice: definitely wear the safety glasses, and definitely tape the entire glass surface.
robertmhussey - Antwort
Echo jesseokerlund's comments that you will have glass flying. I made the mistake of doing the repair at my kitchen table and had a lot of cleanup to do. The job would be much easier if there was no broken glass, and the hardest part is where the glass is broken right next to the bezel. I used the metal spudger to work those pieces free, but it takes some time.
+ 1 on the safety glass, I almost got hurt while doing this.
alexisfogel - Antwort
  • Nochmal, da du im Laufe der Demontage eventuell mit zersplittertem Glas arbeitest, empfehlen wir dringend eine Sicherheitsbrille, um deine Augen vor umherfliegenden Glassplittern zu schützen.
  • Lege den iOpener flach auf die rechte Kante des iPads und glätte es, sodass ein guter Kontakt zwischen der iPad- und der iOpener-Oberfläche besteht.
  • Lasse den Beutel etwa 90 Sekungen auf dem iPad liegen, bevor du versuchst, das Front Panel zu öffnen.
It is ver likely that the glass you are trying to replace is broken, and this is tempered glass therefore it will chatter in many small pieces while you are working on it. Take this safety advice very seriously and protect your eyes!!! The glass pieces fly everywhere. AGAIN: PROTECT YOUR EYES!!!! BE SAFE!!!
McGiord - Antwort
This last statement cannot be underemphasized! I got two shards of very fine glass into my right eye, luckily got them out right away, before reaching for the safety goggles! Later on, I removed them again because working w/ the small parts was easier. Protect your eyes, people!
Lou Bomski -
Just use some scotch wide transparent tape and cover the broken screen BEFORE you start to taking it apart. It will hold all the shards together and nothing will fly around.
Vatevaaa -
I covered the screen in clear packing tape to control glass particles.
I placed the ipad outside in direct afternoon sunlight for an hour and all of the adhesive was softened quite well.....the screen was off in just a few minutes !
John - Antwort
This is a very good idea John, I wish I'd seen this comment before I spent hours picking tiny bits of glass off the glue!
Tom Scott -
Thumbs up for this tip. I left it out in the sun for 15 min only and it worked a treat. I used a razor blade. The plastic tools are next to useless.
olafgoy -
I had some issues after replacing this cable.
Once I had it in and back together only the down volume was working, and shortly after the gyro gave out.
I ended up going to where the new cable connects to the board, removing it, then replacing it as gently as possible. Not too firm.
I also removed a foam spacer in that area because it was pushed out over the gyro board.
Now I'm back to full functionality!
clatekeen - Antwort
me 2 my volumen up doesn't work and the switch sound/silent any fix?
Zadd -
Badly broken screen, taped and warmed about 15 minutes on heating pad set on high. Perfect, gentle, overall warming! Mark the front with Sharpie, ie WiFi, cable, etc. Used thin metal iSes... type tool and guitar pics. BUY NEW Plastic bezel!!! So super cheap. Rewarm on heating pad as necessary. Compressed air helpful to blow away tiny glass bits. Wear glasses! Take breaks! This is easy if you warm carefully and are patient!
Max - Antwort
I am in the process of replacing a shattered screen on an iPad 3 wifi, and I literally was removing glass piece by piece! I do recommend having a roll of wide clear sealing tape at hand. Then, when you see loose glass shards, pull off about 4 to 5 inches, and stick the tape to pick up the loose glass, and once in a while, fold the tape onto itself (sticky to sticky side), and set it aside. This helps keep it from getting everywhere. Also, spread news paper under your work. Some people don't really think of these things, but the fact is, hardened glass will find its way into your skin very easily. Extremely sharp!
dbrown900 - Antwort
Have not attempted this repair on my wife's iPad 2, but is there a reason that you put the iOpener on top of the device rather than putting the device on top of the iOpener? After all, heat rises.
Stephen Weber - Antwort
Der Klebering weist in der oberen rechten Ecke des iPads, etwa 5 cm von der oberen Kante entfernt, eine kleine Lücke auf. Diese Schwäche wirst du ausnutzen. Richte das Werkzeug auf die Stummtaste aus. Führe die Spitze eines Plastic Opening Tools in die Lücke zwischen dem  Frontglas und der Kunststoffeinfassung. Führe nur die äußerste Spitze des Öffnungswerkzeuges ein, gerade weit genug um den Spalt zu weiten. Es kann einige Kraft fordern, die verkeilte Spitze des Öffnungswerkzeuges zwischen Glas und Kunststoff zu bekommen. Bleibe geduldig und sei vorsichtig, wenn das Plastic Opening Tool vor und zurück bewegst, falls das notwendig ist.
  • Der Klebering weist in der oberen rechten Ecke des iPads, etwa 5 cm von der oberen Kante entfernt, eine kleine Lücke auf. Diese Schwäche wirst du ausnutzen.
  • Richte das Werkzeug auf die Stummtaste aus. Führe die Spitze eines Plastic Opening Tools in die Lücke zwischen dem Frontglas und der Kunststoffeinfassung. Führe nur die äußerste Spitze des Öffnungswerkzeuges ein, gerade weit genug um den Spalt zu weiten.
  • Es kann einige Kraft fordern, die verkeilte Spitze des Öffnungswerkzeuges zwischen Glas und Kunststoff zu bekommen. Bleibe geduldig und sei vorsichtig, wenn das Plastic Opening Tool vor und zurück bewegst, falls das notwendig ist.
there is the power flex cable near the top right side of the screen. It could be damaged is not careful.
ChiangFeng Li - Antwort
Yes, I severed this one on my first attempt. Might note that you want to start prying open below the sound controls. Additionally I found that a razor was helpful in getting the first pic into the device. Obviously you want to be careful as a razor could cause some serious damage, but I just used the tip of the metal to get some space to fit a pick.
Nick Dresang - Antwort
Maybe I was doing it wrong, but the plastic opening tool I was using kept bending before it was prying anything apart. Therefore I suggest using either a metal spudger or a razor blade to make the very first opening but being VERY careful. My assistant/wife later scratched the LCD going overboard with the metal tools.
Logan Kennedy - Antwort
There is a way of making the Wifi/Bluetooth Antenna replacement much easier. If you have a steady hand and a soldering iron simply desolder the connecting cable from the bottom of the antenna and solder it back onto the new antenna. This means there is no need to dismantle the iPad and the repair is much faster. Hope this helps :-)
Richard - Antwort
The process was pretty straightforward, you do need to be careful in a few spots (like the wifi antenna in the lower right) but overall I found it to be of medium level of difficulty.
It took me 2.5hrs to slowly dismantle and replace the broken screen.
Here are some tips I learned while doing it:
- instead of plastic spudger, better to use kit knife or razor blade. I found plastic to bend and malform quite easily.
- watch out for lower right corner where wifi antenna sits, it's easy to damage it
- if you have a cracked screen, use protective goggles - i used tape to secure broken glass pieces together, but that didn't quite work and lots of glass was flying as I was prying the screen off the ipad
- opening tool you put in the microwave sold here is not worth it - didn't do that great for me. I mostly used a hair drier and was very successful melting adhesive
- tools I'd only need again to do it again - guitar picks, kit knife, phillips screwdriver, hair drier :D
Overall, I found it to be quite interesting project!
michalmotykiewicz - Antwort
Seconding the problem about plastic components. They just aren't strong / precise enough to fight this glass. Save them for the really nasty bits like the wifi cable, and use an X-Acto or equivalent everywhere else.
Golden Neckbeard -
Wish I would have seen your comment before I went through it. Switched to a razor blade and that helped for sure. Thought about a hair dryer as well but stuck with the micro heating tool. Probably should have done the dryer. :-/
Josh West -
Had much more success using the metal spudger versus the plastic opening tool that came with the front panel kit.
Paul Boyer - Antwort
I had success using Paddle Pop sticks instead of guitar picks. (not sure what they are called in the US). The guitar picks tended to deform and melt with the heat of my hot gun. The glue used to attach the screen is just amazingly strong! It takes a lot of patience to remove all the fragments. I have done about 6 screens now and it is a turdful job!
Jack - Antwort
I think we call those popsicle sticks. They seem kind of thick for this, at least a lot thicker than a guitar pick.
John -
It is not glue, they use a very strong double sided 3M tape
Odus182 -
Pay attention to the Power Button cable located in the upper right corner !!!
Nathan - Antwort
Successful battery change but I did sever the cord/ribbon to the power/sleep button. As my iPad had been opened before at a repair shop, I think they put adhesive over the cord as the small section was stuck underneath the LCD, barely visible. So be careful not to put adhesive above that exposed ribbon/cord to the power/sleep button or the next time you open it up, it's severed.
Breadman - Antwort
On the iPad 2 I repaired, the opening started at 1 inch and ended at 3mm.
Justin H - Antwort
Like others i found the plastic tool pretty useless. Exacto, razor blade, or small metal pick/pry tool works much better to get that first guitar pick inserted. Be careful not to damage the bezel too much. Unless to plan to replace it.
B Kirkham - Antwort
If you have an iPAD that has been repaired before note that the adhesive strip might not have an opening by the volume control as shown. I replaced the glass and the new glass had a 2" gap to the left of the Home button only.
winwoodc - Antwort
The glass is much thinner than you'd think and I broke mine trying to lever it off before the adhesive has softened enough. Be VERY gentle!
winwoodc - Antwort
My plastic opening tool broke in no time flat. Perhaps I was pressing down too hard and not wiggling it enough. But for me I found that the metal spudger was the best tool for the job. I was able to wiggle it while slowly prying up the glass and once it was under the surface of the glass I was able to work it along the edge quite easily. I saw that some people used a razor blade but I would be afraid the blade would break. The metal spudger was just thin enough to do the job well.
Achte darauf, dass das Werkzeug an der richtigen Stelle einführst - zwischen der Kunststoffeinfassung des Displays und dem Front Panel Glas.
  • Achte darauf, dass das Werkzeug an der richtigen Stelle einführst - zwischen der Kunststoffeinfassung des Displays und dem Front Panel Glas.
This visual is helpful. It would be great also to have a diagram of the top of the ipad, marked with "top," "bottom," "left," "right," and then an arrow pointing to each of the problematic areas, such as wifi cable, digitizer cable, etc. It would be easier to see the whole schematic while working rather than scrolling through the instructions and trying to visualize each piece separately. Good to see where to be careful...
Christa - Antwort
Lasse die Spitze des Plastic Opening Tools eingekeilt zwischen dem Frontglas und der Kunststoffeinfassung und führe ein Opening Pick in die Lücke,  direkt neben dem Plastic Opening Tool. Lasse die Spitze des Plastic Opening Tools eingekeilt zwischen dem Frontglas und der Kunststoffeinfassung und führe ein Opening Pick in die Lücke,  direkt neben dem Plastic Opening Tool.
  • Lasse die Spitze des Plastic Opening Tools eingekeilt zwischen dem Frontglas und der Kunststoffeinfassung und führe ein Opening Pick in die Lücke, direkt neben dem Plastic Opening Tool.
My screen was too broken for this "heat, cut with picks, and leave in place" method to work anywhere but the top, where it was essentially undamaged.
I wound up using a spudger through all the cracked sections to pry upwards just *inside* the perimeter of the adhesive, intentionally breaking the digitizer and the glass further, until I could remove the entire front panel except for the adhered portions - about half the perimeter in my case.
I then used tools to pry up the glass from the *opposite* direction, that is the broken interior edge I had earlier created, thus not having to fight the bezel and also having a clear line of sight to any interior components I might be damaging.
Of course, doing it this way made it much easier to drop tiny shards of glass all over the interior, but I found a little diligent cleaning much easier than trying to keep the glass intact while breaking the glue, as in this guide.
Golden Neckbeard - Antwort
I found that using a scraper blade was the easiest way to get under the glass, both for broken and unbroken areas.
Jeff Snider - Antwort
Entferne das Plastic Opening Tool vom iPad und schiebe das Opening Pick weiter unter das Frontglas bis zu einer Tiefe von etwa 1-1,5 cm. Entferne das Plastic Opening Tool vom iPad und schiebe das Opening Pick weiter unter das Frontglas bis zu einer Tiefe von etwa 1-1,5 cm.
  • Entferne das Plastic Opening Tool vom iPad und schiebe das Opening Pick weiter unter das Frontglas bis zu einer Tiefe von etwa 1-1,5 cm.
It should be noted that the glass can be much more difficult to remove when it is cracked and shattered (as is usually the reason for replacement) . Depending on the location and severity of the cracks, the order and technique of removal requires modification.
I have found that putting a layer of clear packing tape over the entire screen is helpful, wether it's cracked or not. It will prevent the spraying of glass shards, should the glass break while separating the adhesive; with a broken screen, it should eliminate the risk of cutting yourself during removal, as well as hold all the pieces together. Unfortunately, it also makes the iOpener slightly less effective, so peel it back when applying it. Suction cups can also be helpful during final removal of the glass.
Having a hot air gun/pencil can be helpful in removing smaller pieces if broken glass that remain once the bulk of it is removed.
Nick V - Antwort
Just trashed an I pad... Not an electronics person. Did an iphone 5 battery with no problems was following instructions and once I hit the next step I realized I had already screwed up the screen... Moving forward tring to unhook LCD pictures are not very clear on which direction to push or pull so broke that... Now writing a review on it... Take it to a pro if you aren't certain!
rondiedonelson - Antwort
I found that the adhesive could be separated when the pick or spudger was in at a depth of between 1/4" (6.4 mm) and 3/8" (9.5 mm). You can always go back and work it in deeper if you are having trouble separating.
Yoh but this is not so simple of your screen is shattered to the edges. Basically I had to lift, shatter more, and then pick off the splintered glass with tweezers bit by bit. Patience is a virtue here. I gave up on saving the adhesive and used it to help remove the splinters. I basically removed the edges of the iPad like that and then lift glass off. WEAR SAFETY GLASSES. I would be blind now if I didn’t. wifi antenna -Go slow make sure it’s hot +check what you are doing in the crack. Remove all splinters fromiPad when it’s open. Clean LCD with a microfibre cloth and inside of your new digitizer. When I first reassembled, the home button didn’t work. I reopened and made sure the two gold connectors align with the two spikes on the body. I placed the home button board face down onto the connector spikes with adhesive on the other side, then lowered the digitiser onto it so the board would stick to the digitiser. Notes: forget plastic spudger they’re only place holders, I used a blade knife and metal Spudgers
Sarah Pegden - Antwort
Während du daran arbeitest, den Kleber auf der rechten Seite des iPad zu lösen, erhitze den iOpener erneut und platziere ihn auf der unteren Kante des iPads.
  • Während du daran arbeitest, den Kleber auf der rechten Seite des iPad zu lösen, erhitze den iOpener erneut und platziere ihn auf der unteren Kante des iPads.
I have found that its better to put more than one pick down the side of the screen to keep it open and prevent it from sticking back down.
Roberto Enrieu - Antwort
Während die Unterkante vom iOpener erhitzt wird, fange an, den Kleber an der rechten Kante des iPads zu lösen. Fahre mit dem Opening Pick die Kante des iPads entlang nach unten und löse dabei den Kleber. Der verwendete Kleber ist sehr stark und ein erheblicher Kraftaufwand kann vonnöten sein. Arbeite mit Bedacht.
  • Während die Unterkante vom iOpener erhitzt wird, fange an, den Kleber an der rechten Kante des iPads zu lösen.
  • Fahre mit dem Opening Pick die Kante des iPads entlang nach unten und löse dabei den Kleber.
  • Der verwendete Kleber ist sehr stark und ein erheblicher Kraftaufwand kann vonnöten sein. Arbeite mit Bedacht.
  • Wenn die Spitze des Opening Picks unter dem Frontglas hervorschaut, ziehe das Pick wieder ein wenig heraus. Zwar wird nichts beschädigt, wenn du das Opening Pick so tief positionierst, aber es kann Kleberrückstände auf dem LCD hinterlassen.
Um den Kleber zu lösen, kann es notwendig sein, den erhitzten iOpener nochmal auf auf der rechten Kante des iPads aufzulegen.  Das hängt davon ab, wieweit dein iPad schon wieder heruntergekühlt ist, während du daran gearbeitet hast. Wenn das Opening Pick im Kleber hängen bleibt, "walze" das Pick entlang der Seitenkante des iPads und löse dabei weiter den Kleber. Wenn das Opening Pick im Kleber hängen bleibt, "walze" das Pick entlang der Seitenkante des iPads und löse dabei weiter den Kleber.
  • Um den Kleber zu lösen, kann es notwendig sein, den erhitzten iOpener nochmal auf auf der rechten Kante des iPads aufzulegen. Das hängt davon ab, wieweit dein iPad schon wieder heruntergekühlt ist, während du daran gearbeitet hast.
  • Wenn das Opening Pick im Kleber hängen bleibt, "walze" das Pick entlang der Seitenkante des iPads und löse dabei weiter den Kleber.
The volume power button cable is really close to the edge and is frequently loose and non adherent to the frame. If your pick is deep into the iPad, you are almost sure to cut the cable. Be very cautious around the top right corner of the iPad.
silvain1038 - Antwort
I absolutely severed this cable when loosening the adhesive around the volume button area. There is really no way of knowing if this cable somewhat elevated from the frame and therefore susceptible to being cut, and it happens to be right where one starts to remove the face with the guitar picks. The cable is directly in from the down volume button, so be extra careful not to put the guitar pick in too far in this area. I recommend buying a power/volume button cable just in case. Replacing this cable is also not easy, but doable. Just try to avoid doing it.
nickmalmquist - Antwort
Why not work in reverse to the top edge, and back around to the area where that cable may be unsecured? Haven't don't an iPad (yet, staring one in the face right now) but that would be my alternative so the screen is mostly loose and you could possibly see the cable looking from the now open left side of the glass?
Matt Needham - Antwort
Bevor du das erste Opening Pick aus der unteren Ecke des iPads entfernst, platziere ein zweites Pick unter der rechten Ecke des Frontglases, um zu verhindern, dass der Kleber wieder anzieht. Erhitze den iOpener erneut und platziere ihn an der Oberkante des iPads.
  • Bevor du das erste Opening Pick aus der unteren Ecke des iPads entfernst, platziere ein zweites Pick unter der rechten Ecke des Frontglases, um zu verhindern, dass der Kleber wieder anzieht.
  • Erhitze den iOpener erneut und platziere ihn an der Oberkante des iPads.
Bei den nächsten Schritten ist große Achtsamkeit vonnöten.
  • Bei den nächsten Schritten ist große Achtsamkeit vonnöten.
  • Die Wi-Fi Antenne ist mit Schrauben und einem Kabel an der unteren rechten Ecke des hinteren iPad-Gehäuses angebracht. Wegen der Ausrichtung der Wi-Fi Antenne, ist es dringend erforderlich mit Vorsicht vorzugehen, da andernfalls der Wi-Fi Antenne irreparabler Schaden zugefügt werden kann.
  • Du musst den Kleber, der Antenne und Front Panel verbindet, entfernen, ohne die empfindlichen Teile, mit denen die Antenne unten am iPad befestigt ist, zu beschädigen. Sei vorsichtig beim weiteren Vorgehen.
I cut through my wifi cable partially, but it still works (surprisingly). I'd recommend staying well clear of this with the pick. When you go to lift the screen (future step, NOT NOW), use a really good light, start to lift the glass slightly at the corner and you will be able to see the cable. Then you can heat it more and watch the cable as you pull through the adhesive there making sure your not catching the cable.
B Kirkham - Antwort
If you heat the sides and top, releasing the adhesive, you can peel the broken glass front panel up from the body and with a little force the bottom comes loose. This avoids working around and damaging the Wi-Fi Antennae.
Michael Vovaris - Antwort
I know it is hard to tell from the photo, but the Wi-Fi antenna is kind of like a flap that opens on the right and is attached on the left. So if you use a pick to slide from right to left, the pick might slide under the flap and then sever how it is attached. When I had my pick just to the right of where the Wi-Fi antenna is, I was able to twist my pick a little (like you are tightening a screw) and pry the screen up where the antenna is located. Then I just moved my pick to the left of the antenna and could continue loosening the screen.
Irreversible damage to the Wi-Fi antenna is nearly unavoidable, but this is not the end of the world since you can pick up a perfectly fine replacement on-line for a few bucks. Many digitizer screen replacement kits include a new WiFi antenna and new bezel since removing the screen without damage to these is also nearly impossible. If your iPad is old enough to need a new battery, and you plan on keeping it thru at least another battery's expected life span, then I would plan on replacing the digitizer screen, bezel, and WiFi antenna as part of the battery replacement. The battery is going to be the most expensive of the set, say around $15 (US), and adding the other three will only add about another $15 (check the prices in ebay, amazon, etc.). Removing the screen often results in damage to the on/off and volume control cable since it too runs along the upper right hand edge of the base right under the screen. If you cut thru this then add another $1 to replace it too.
Jerry - Antwort
Based on my experience just (nearly) completing this job on an iPad 2, CDMA, is that the trickiest step is reconnecting the three CDMA antenna cables on the underside of the CDMA chip that is part of the logic board assembly. These are nearly microscopic button connectors (maybe 0.5 mm in diameter). I needed 8X magnification glasses, very bright light, tweezers, and incredible luck to get these reattached. They pop off no problem, but getting them positioned to apply pop-on force takes a LOT of patients! Maybe someone knows a trick to doing this? There’s a similar connector on the WiFi cable but the chip it attaches to can be removed from the logic board so you’re able to manage positioning them interdependently. The CDMA chip is attached (soldered?) to the logic board and the three button connectors are on the underside, and pretty close to one another, so getting all THREE attached and then the logic board in place is a miracle.
Jerry - Antwort
Fahre mit dem Opening Pick entlang der rechten unten Ecke des iPads und löse dabei den Kleber dort. Fahre mit dem Pick nicht weiter als bis zu der rechten unteren Ecke. Andernfalls kannst du die Wi-Fi Antenne beschädigen.
  • Fahre mit dem Opening Pick entlang der rechten unten Ecke des iPads und löse dabei den Kleber dort.
  • Fahre mit dem Pick nicht weiter als bis zu der rechten unteren Ecke. Andernfalls kannst du die Wi-Fi Antenne beschädigen.
Be sure to have a replacement Bluetooth Wi-Fi antenna because it is very likely to get the cable broken at this step.
McGiord - Antwort
Be extremely careful and patient at this step. Proceed slowly with only the tip ( 1/16th in. - 2mm max.) of the pick. There are two tinny screws that attach the bottom of the antenna to the iPad frame. This antenna part is easly severed if the pick goes too far.
Happenned to me and had to replace the antenna.
Marc Bouchard - Antwort
Der Schritt verlangt, dass du das Opening Pick entlang der rechten unteren Ecke des Front Panels bewegst. Die Wi-Fi Antenne befindet sich sehr nahe an der Ecke und  wird leicht abgetrennt, wenn der Kleber unfachmännisch gelöst wird. Ziehe das Pick nicht vollständig unter dem Frontglas hervor, sondern nur ein bisschen, sodass sich 1-2 mm der Spitze noch unter dem Frontglas befinden.
  • Der Schritt verlangt, dass du das Opening Pick entlang der rechten unteren Ecke des Front Panels bewegst. Die Wi-Fi Antenne befindet sich sehr nahe an der Ecke und wird leicht abgetrennt, wenn der Kleber unfachmännisch gelöst wird.
  • Ziehe das Pick nicht vollständig unter dem Frontglas hervor, sondern nur ein bisschen, sodass sich 1-2 mm der Spitze noch unter dem Frontglas befinden.
  • Fahre mit der Spitze des Opening Picks entlang der unteren Kante des iPads und entferne so den Kleber über der Wi-Fi Antenne.
I nearly broke my wifi antenna because I didn't read this whole step clearly and didn't go backwards and release the antenna from the front panel. Admittedly, this is my own fault but I've edited the step to make this point more clear.
My screen was way too shattered for me to be able to use the screen instructions as suggested, so I followed the general principal but ignored the order around, because that simply wouldn't have worked...and destroyed the antenna.
Maybe step one should be "BE CAREFUL IN THIS CORNER OR YOU WILL BREAK THE ANTENNA!" A diagram highlighting where all the cables (antenna, digitiser, volume, toggle switch) lie with the screen still attached would be helpful too.
HRB - Antwort
Or maybe you should have read the entire thing before starting if you were not planing on following it step by step
Hawesg Garrett -
I Broke my antenna like many others. It is glued to the glass and has 1mm thick foam backing that is also glued to the inner case. Then there is a tiny grounding connector screwed at the lower edge of the case. Once you can get things loosened up around this antenna, you will need to detach this antenna from the glass. Work at it with your picks or spudger until you get it free, if you do not get it to release from the glass you will break the grounding ribbon. I bought a cheap aftermarket antenna on amazon for $3. turns out it has a bad cable coming from it. I was able to unsolder the cable from the one I broke and solder it to the new antenna.
chrisnewitt - Antwort
This BEGS for an Archer "Just The Tip" reference.
Christian - Antwort
It wasn't obvious to me at first that I'd broken the antenna. A picture of the antenna that works compared with one that is broken would be useful. Fortunately I'd ordered the replacement part just in case, as suggested.
I think using extra heat on this spot may make it easier to unstick without breaking the antenna?
A diagram of what the antenna looks like, from the side, would make it clearer what to do with the pick. You are trying to detach the antenna from the glass, without ripping it off where it's screwed into the bottom of the ipad. Since you can't see what you are doing, and the antenna is quite fragile, that's tricky.
I think once you've broken one you would know better how to do it. When you slide the pick to the right you need to be sure the pick is moving above the antenna and not snagging on it in any way, and you need to be sure the antenna is completely detached from the glass, so you don't tear it when you lift the glass up.
Chris Jordan - Antwort
Can anybody give me a clue as to what the exact part is in step 57, As there are slightly different cables for the ipad 2, Mine is A1395, Thanks.
Jasper - Antwort
Sobald du hinter der Wi-Fi Antenne angekommen bist (etwa 3 cm entfernt von der rechten Ecke bzw. direkt neben dem Home Button,  führe das Opening Pick wieder soweit ein, wie es geht. Fahre mit dem Pick nach rechts und löse so den Kleber, der Wi-Fi Antenne und Frontglas verbindet.
  • Sobald du hinter der Wi-Fi Antenne angekommen bist (etwa 3 cm entfernt von der rechten Ecke bzw. direkt neben dem Home Button, führe das Opening Pick wieder soweit ein, wie es geht.
  • Fahre mit dem Pick nach rechts und löse so den Kleber, der Wi-Fi Antenne und Frontglas verbindet.
    • Die Antenne ist unten am iPad mit Schrauben und einem Kabel befestigt. Mit diesem Schritt wird die Antenne vom Front Panel getrennt, wobei sichergestellt ist, dass die Antenne nicht beschädigt wird, wenn du das Panel entfernst.
Be extremely cautious on this step! I did it wrong and my antenna went to !@#$.
Lars Lien Ankile - Antwort
Also once it is unattached from the front panel, if the antennas adhesive touches the glass again it can re-adhere to front panel and may rip apart after all. Keep a close eye on it or leave a pick or card in there to prevent it from re-sticking.
Danny Hartley - Antwort
Fahre damit fort, den Kleber entlang der Unterseite des iPads zu lösen. Ziehe dazu das Opening Pick weit genug heraus, um den Home Button zu umschiffen und führe es wieder etwa 1,3 cm tief ein, sobald du den Home Button passiert hast. Falls der Kleber an der Unterseite schon zu sehr abgekühlt hat, erhitze den iOpener erneut, um den Kleber dort zu erwärmen, wo du gerade arbeitest. Erhitze den iOpener niemals länger als eine Minute am Stück und warte immer mindestens zwei Minuten, bevor du ihn erneut erhitzt.
  • Fahre damit fort, den Kleber entlang der Unterseite des iPads zu lösen. Ziehe dazu das Opening Pick weit genug heraus, um den Home Button zu umschiffen und führe es wieder etwa 1,3 cm tief ein, sobald du den Home Button passiert hast.
  • Falls der Kleber an der Unterseite schon zu sehr abgekühlt hat, erhitze den iOpener erneut, um den Kleber dort zu erwärmen, wo du gerade arbeitest.
  • Erhitze den iOpener niemals länger als eine Minute am Stück und warte immer mindestens zwei Minuten, bevor du ihn erneut erhitzt.
Fahre damit fort, den Kleber entlang der Unterkante des iPads zu lösen. Bei iPad 4 Modellen darfst du den Pick in diesem Bereich höchstens 1,3 cm tief einschieben, du könntest sonst das Flachbandkabel zum Home Button beschädigen.
  • Fahre damit fort, den Kleber entlang der Unterkante des iPads zu lösen.
  • Bei iPad 4 Modellen darfst du den Pick in diesem Bereich höchstens 1,3 cm tief einschieben, du könntest sonst das Flachbandkabel zum Home Button beschädigen.
  • Lasse das Opening Pick eingekeilt unter dem Frontglas nahe dem Home Button.
This should include details about the Home Button Ribbon Cable. Unlike an iPad 3 (which doesn't have this cable) the iPad 4 has a Home Button Ribbon Cable that runs along the left side of the Home Button and is adhered to the glass. If the guitar pick is inserted too far (more than 0.5") it is possible to damage or sever this cable.
robjpete - Antwort
There is a reason this is an iPad 2 Wi-Fi EMC-2560 repair guide. This guide isn't for iPad 3 or 4...
Christian -
I think the guides carry common steps between them. I'm reading this string of comments on multiple ipad 3/4 repair guides.
Anticept - Antwort
Can I suggest putting the warning in red at the top of the instruction rather than half-way through it? I work from these guides by scrolling through them as I go, and I'd already put the spudger through the ribbon cable before I read the warning!
spl23 - Antwort
Erhitze den iOpener wieder in der Mikrowelle und lege ihn auf die rechte Seite des iPads, um den Kleber in diesem Bereich zu erwärmen.
  • Erhitze den iOpener wieder in der Mikrowelle und lege ihn auf die rechte Seite des iPads, um den Kleber in diesem Bereich zu erwärmen.
Fahre mit dem Opening Pick entlang der Oberkante des iPads und ziehe es leicht heraus, um den Bügel der Frontkamera zu umfahren Der Kleber ist in diesem Bereich sehr dick aufgetragen, weswegen beträchtlich Kraft aufgewendet werden muss. Arbeite langsam und vorsichtig und achte darauf, nicht abzurutschen und dir oder dem iPad keinen Schaden zuzufügen. Falls der Kleber schon zu sehr angefühlt ist, platziere den iOpener wieder entlang der Oberkante und arbeite weiter. Falls der iOpener schon zu sehr abgekühlt ist, erhitze ihn erneut.
  • Fahre mit dem Opening Pick entlang der Oberkante des iPads und ziehe es leicht heraus, um den Bügel der Frontkamera zu umfahren
  • Der Kleber ist in diesem Bereich sehr dick aufgetragen, weswegen beträchtlich Kraft aufgewendet werden muss. Arbeite langsam und vorsichtig und achte darauf, nicht abzurutschen und dir oder dem iPad keinen Schaden zuzufügen.
  • Falls der Kleber schon zu sehr angefühlt ist, platziere den iOpener wieder entlang der Oberkante und arbeite weiter. Falls der iOpener schon zu sehr abgekühlt ist, erhitze ihn erneut.
  • Falls das Plektrum im Kleber steckenbleibt, dann "rolle" es vorwärts wie in Schritt 9 gezeigt wurde.
In my case I damaged the right GSM antenna which was somehow sticked to the front panel... Be really careful as I really didn't felt that I was damaging anything...
MattLise Gaillzik - Antwort
+1 on the right 3g antenna - it is adhered to the glass and I cut right through it with the opening pick. The replacement included adhesive to re-stick it to the glass, so this is a definite feature of this antenna. This is a thin film similar to the wifi antenna, so maybe going around it at a shallow depth from the corner to the camera and then returning to the corner slightly deeper would allow you to separate the antenna from the glass without damaging it.
doog - Antwort
Be very careful when going around the front camera, I cracked my screen by prying up too much and causing too much stress!
Rowdydtk - Antwort
The GSM component is glued to the screen with different adhesive (more like glue). I managed to not damage this but it was really tricky. The guitar pick is too thick and weak to release this from the screen. Id recommend you wait until you lift the glass (future step, NOT NOW). Then, with a good light you'll see the white plastic adhered to the glass. A thin metal pick or exacto is needed to patiently cut & pry your way through the adhesive. Careful of the camera as your pulling in that direction.
B Kirkham - Antwort
Fahre damit fort, den Kleber entlang der oberen Kante des iPads zu lösen und fahre mit dem Opening Pick um die linke obere Ecke. Wenn der Kleber warm genug ist, entferne den iOpener zur Vereinfachung vom iPad.  Wenn der Kleber jedoch noch relativ fest hält, erhitze den iOpener erneut und lege ihn auf die linke Kante, während du weiterarbeitest.
  • Fahre damit fort, den Kleber entlang der oberen Kante des iPads zu lösen und fahre mit dem Opening Pick um die linke obere Ecke.
  • Wenn der Kleber warm genug ist, entferne den iOpener zur Vereinfachung vom iPad. Wenn der Kleber jedoch noch relativ fest hält, erhitze den iOpener erneut und lege ihn auf die linke Kante, während du weiterarbeitest.
Fahre mit dem Plektrum entlang der linken Kante des iPads und löse dabei den Kleber. Der Klebestreifen ist hier durch den Digitizer an der ganzen linken Seite sehr dünn.  Schiebe das Pick deswegen nicht tiefer als 1,3 cm ein, um Schäden am Digitizer  zu vermeiden. Das Digitizer-Kabel befindet sich etwa 5 cm von der Unterseite des iPads entfernt. Halte an, wenn du noch etwa 6 cm von der Unterkante des iPads entfernt bist. Das Digitizer-Kabel befindet sich etwa 5 cm von der Unterseite des iPads entfernt. Halte an, wenn du noch etwa 6 cm von der Unterkante des iPads entfernt bist.
  • Fahre mit dem Plektrum entlang der linken Kante des iPads und löse dabei den Kleber. Der Klebestreifen ist hier durch den Digitizer an der ganzen linken Seite sehr dünn. Schiebe das Pick deswegen nicht tiefer als 1,3 cm ein, um Schäden am Digitizer zu vermeiden.
  • Das Digitizer-Kabel befindet sich etwa 5 cm von der Unterseite des iPads entfernt. Halte an, wenn du noch etwa 6 cm von der Unterkante des iPads entfernt bist.
The second photo does not show the iPad 4's Home Button Ribbon Cable.
robjpete - Antwort
Because this is for an iPad 2
Odus182 -
@odus182 It says clear as day that this is an iPad 4 guide!
Mike Enos -
This is the hardest part the digitizer cable runs the length of this side and u have to be very carefull with the pick . Only go in an 1/8 inch I severed it by going the half (recommended) luckily I had a new screen standing by . I used I opener for heating and it was slow but ok.
wperrin623 - Antwort
How do i fix my digitiser if it's broken? Do i need to buy a new iPad screen with digitiser?
Jenny Le - Antwort
just ruined my digitiser..any ideas how to fix it?
dleimonis -
Löse den Kleber entlang der linken unteren Ecke mit dem Pick, dass sich noch an der Unterkante des iPads befindet. Das untere Ende des Digitizer-Kabels ist nur etwa 1cm von der Unterseite des iPads entfernt. Gehe langsam und vorsichtig vor und achte darauf, das Kabel nicht durchzutrennen.
  • Löse den Kleber entlang der linken unteren Ecke mit dem Pick, dass sich noch an der Unterkante des iPads befindet.
  • Das untere Ende des Digitizer-Kabels ist nur etwa 1cm von der Unterseite des iPads entfernt. Gehe langsam und vorsichtig vor und achte darauf, das Kabel nicht durchzutrennen.
If your screen is broken or shattered there are no worries with the digitizer cable, It is all on the new screen.
Exactly. I purposely severed mine as it was a complete screen replacement and made the LCD removal easier.
Heble mit einem Opening Pick die rechte untere Ecke des iPads nach oben und ergreife es. Teilweise kann der Kleber rund um das iPad wieder angezogen haben.  Wenn das der Fall ist, fahre mit einem Pick unter die Kante des iPads, wo das Frontglas noch festklebt und "durchtrenne" den Kleber.
  • Heble mit einem Opening Pick die rechte untere Ecke des iPads nach oben und ergreife es.
  • Teilweise kann der Kleber rund um das iPad wieder angezogen haben. Wenn das der Fall ist, fahre mit einem Pick unter die Kante des iPads, wo das Frontglas noch festklebt und "durchtrenne" den Kleber.
Should be right-hand corner
longg - Antwort
Be very careful when pushing the guitar pick around the corner of the power/volume buttons. The ribbon cable for these buttons may be stuck to the adhesive and break when lifting the screen or when sliding the pick along this area. I have done 4 iPad 2 repairs and at least one of the delicate components do not make it. I would recommend ordering a wi-fi/bluetooth antenna, bezel with strips, and a power/volume cable. It is nice to have a "just-in-case" part or two, they are very inexpensive. I noticed that the I tended to break one of these delicate components when the screen was shattered in the area of those components.
thetechandtutor - Antwort
At this point it is a good idea to get the packing tape back out and wrap it around 2 or 3 of your fingers making a circle with the sticky on the outside. Make it loose enough you can place your fingers on the table surface to the side and pull your fingers out. When you remove all the tiny parts/screws in the next steps put them on top of the tape so you know exactly where they are when you need them
windizy - Antwort
Halte das iPad an der unteren und oberen rechten Ecke fest und klappe das Frontglas vom iPad weg. Achte darauf, dass möglicherweise noch Kleber vorhanden sein könnte. Schneide mit einem Opening Pick jeglichen Kleber, der das Front Panel noch unten halten könnte, durch.
  • Halte das iPad an der unteren und oberen rechten Ecke fest und klappe das Frontglas vom iPad weg.
  • Achte darauf, dass möglicherweise noch Kleber vorhanden sein könnte. Schneide mit einem Opening Pick jeglichen Kleber, der das Front Panel noch unten halten könnte, durch.
Check to the right of the Home button to see if the wifi/bluetooth antenna is still stuck to the glass side or has released. If it is still stuck to the glass use the guitar pick to carefully scrape it off. If your goal is to replace the antenna, then you needn't be so careful.
jerry81 - Antwort
Be very careful not to touch the LCD. It's a pain to remove smudges. One thing that might help when you need to hold it while reattaching it during reassembly: attach a small suction cup to the metal side. That way you can avoid touching the sides where your hand might slip to the LCD side.
patjmccarthy - Antwort
Do you need to use some adhesive strips to remount the plastic bezel? The bezel I ordered didn't come with any and the ones you can order only seem to have strips for mounting the glass and not the bezel.
James - Antwort
You'd better. The original bezel is glued. You can find 3mm fine/double-sided (black) tape on Amazon. I use it when I replace the bezel because they fit perfectly under the bezel. I use for all sorts of repairs on iPhones, Samsungs, etc. Such as this [one|http://www.amazon.com/gp/product/B005GIS...]
Rany -
In order to prevent touching the LCD screen with your finger(s), I use the thin plastic food wrapper to cover it. It will temporary stick to the LCD screen and provide excellent protection from fingerprints.
Th Th - Antwort
Very good suggestion. It worked like a charm.
Laurie Higgins -
you can use latex gloves to keep smudges and finger prints from the screen. I'm getting ready to repair mine, thanks for all the comments and tips. Btw, I wonder if a vacuum cleaner would work for removing small pieces of glass.
De Dios sept.10 2014
dediosjon - Antwort
where is the connecotr for home button at the ipad 3....i have nothin where i can plug in the flex cable comin from the button
Georg Heinze - Antwort
Go slowly as you lift up the glass and be sure that you are not tearing a ribbon cable. When I lifted the glass the digitizer cable was torn and unusable. Perhaps I had cut it with the pick/spudger but it tore completely off when I lifted the glass. Good thing I had purchased the full front panel assembly with the digitizer (IF116-018-3).
When reassembling I used canned air to blow off dust on the LCD before closing it up.
You can use a clean soft brush like a make-up brush or small paint brush to brush off the LCD.
I like how the pictures show an intact screen being removed (although the one in step 4 has a couple of cracks in). I don’t know if anyone would have the luxury of being able to remove a screen in one piece, the ipads I've fixed have been completely smashed pretty much all the way around the outside of the lcd underneath. I used this guide to know where to watch for cables etc - very helpful. I end up using a window scraper/razor to scrape off the glass shards/adhesive around the edge. Glass shards/dust all over the lcd is easy enough to get off but cleaning the lcd after that is a real pain. Does anyone have any suggestions how to clean the lcd properly?
Matthew Judge - Antwort
Entferne die vier 2 mm Kreuzschlitzschrauben  #00, die das LCD am Aluminiumrahmen befestigen. Die untere linke Schraube ist vom Verbinder des Home Button Kabels verdeckt. Schiebe das Kabel vorsichtig zur Seite, um an die Schraube zu gelangen.
  • Entferne die vier 2 mm Kreuzschlitzschrauben #00, die das LCD am Aluminiumrahmen befestigen.
  • Die untere linke Schraube ist vom Verbinder des Home Button Kabels verdeckt. Schiebe das Kabel vorsichtig zur Seite, um an die Schraube zu gelangen.
Hebe die rechte Seite des LCD mit dem Plastiköffnungswerkzeug aus dem iPad. Klappe das LCD über die linke Kante und lege es auf die Frontscheibe. Sei vorsichtig, wenn du das LCD bewegst. Das Flachbandkabel ist sehr empfindlich und kann beschädigt werden, wenn es zu stark belastet wird.
  • Hebe die rechte Seite des LCD mit dem Plastiköffnungswerkzeug aus dem iPad.
  • Klappe das LCD über die linke Kante und lege es auf die Frontscheibe.
  • Sei vorsichtig, wenn du das LCD bewegst. Das Flachbandkabel ist sehr empfindlich und kann beschädigt werden, wenn es zu stark belastet wird.
Ziehe das Stück Tape, das den LCD Flachbandkabelstecker verdeckt,  mit der Spudgerspitze ab.
  • Ziehe das Stück Tape, das den LCD Flachbandkabelstecker verdeckt, mit der Spudgerspitze ab.
You can actually skip this and go directly to step 37.
ilconte - Antwort
Klappe die Haltelasche über dem ZIF Stecker des LCD Flachbandkabels hoch. Löse mit den Händen oder eine Pinzette das LCD Flachbandkabel von seiner Fassung auf dem Logic Board. Löse mit den Händen oder eine Pinzette das LCD Flachbandkabel von seiner Fassung auf dem Logic Board.
  • Klappe die Haltelasche über dem ZIF Stecker des LCD Flachbandkabels hoch.
  • Löse mit den Händen oder eine Pinzette das LCD Flachbandkabel von seiner Fassung auf dem Logic Board.
I killed my iPad permanently on this step. The black flap snapped off. The ribbon will not seat in there apparently because now my display is just black. I can hold the Home button down and hear a beep/tone, but there's nothing at all on the display. It's a brick now.
jimdelrio - Antwort
x2
My retainer flap broke before it would move, tried to tape the cable back in place, LCD is totally dead now (wasn't before) even though I heard sounds...
mikemiller73 - Antwort
I ran into similar problem and was able to fix it.
I used a thin mylar piece, cut to the size of the ribbon cable and push it in, on top of the ribbon cable to thicken it.
Digitizer(Touch screen), Not responding after Tear down.
Instead of the mylar tape, I re-used the screen protector from an old Nintendo DS and cut it to size. I did not think it would work but it did for me after 4,5 tries. Good luck.
Th Th - Antwort
The pictures here are very misleading. The ZIF lock tab is towards the back of the connector - opposite to where the cable comes in. you flip it up and over. The picture here does NOT show the lock tab released! when replacing make sure the white lines go right into the connector - you should almost not see them anymore.
Mark Smith - Antwort
As Mark Smith noted the lock on the ZIF connector is at the BACK of the connector, the side FARTHEST from the cable. Put your spudger or opener at the back of the connector and gently pull up while pushing toward the connector. The black bar at the back of the connector will pop up and release pressure on the cable.
Awfki - Antwort
The ZIF connector lock is almost impossible to see in the pictures, and even tough to see when you're looking at it. It is a really thin black bar with a hinge on the long edge. As Mark Smith and Awfki stated, pull up gently on the long edge that is opposite the ribbon cable. When inserting the new ribbon cable be sure to get the cable lined up, then push in straight and evenly.
Ohne die Vorderseite des LCD zu berühren, hebe das LCD vom Front Panel hoch.
  • Ohne die Vorderseite des LCD zu berühren, hebe das LCD vom Front Panel hoch.
Entferne, wenn vorhanden, das Stückchen Isolierband, welches die WiFi Antenne, das Lautsprecherkabel und das Home Button Kabel bedeckt. Entferne, wenn vorhanden, das Stückchen Isolierband, welches die WiFi Antenne, das Lautsprecherkabel und das Home Button Kabel bedeckt.
  • Entferne, wenn vorhanden, das Stückchen Isolierband, welches die WiFi Antenne, das Lautsprecherkabel und das Home Button Kabel bedeckt.
Klappe den Sicherungsbügel am ZIF Verbinder des Home Button Flachbandkabels  hoch. Klappe den Sicherungsbügel am ZIF Verbinder des Home Button Flachbandkabels  hoch.
  • Klappe den Sicherungsbügel am ZIF Verbinder des Home Button Flachbandkabels hoch.
Ziehe das Flachbandkabel des Home Buttons mit einer Pinzette gerade aus seinem Sockel auf dem Logic Board. Ziehe das Flachbandkabel des Home Buttons mit einer Pinzette gerade aus seinem Sockel auf dem Logic Board.
  • Ziehe das Flachbandkabel des Home Buttons mit einer Pinzette gerade aus seinem Sockel auf dem Logic Board.
Löse das Flachbandkabel zum Home Button aus seinem Sitz im Gehäuse.
  • Löse das Flachbandkabel zum Home Button aus seinem Sitz im Gehäuse.
Ziehe das Stückchen Klebeband, welches das Flachbandkabel zum Digitizer am Logic Board befestigt, mit der Spudgerspitze ab.
  • Ziehe das Stückchen Klebeband, welches das Flachbandkabel zum Digitizer am Logic Board befestigt, mit der Spudgerspitze ab.
Klappe die Sicherungsbügel an beiden Verbindern des Flachbandkabels zum Digitizer hoch. Klappe die Sicherungsbügel an beiden Verbindern des Flachbandkabels zum Digitizer hoch. Klappe die Sicherungsbügel an beiden Verbindern des Flachbandkabels zum Digitizer hoch.
  • Klappe die Sicherungsbügel an beiden Verbindern des Flachbandkabels zum Digitizer hoch.
Löse die Klebeverbindung unter dem Digitizer-Flachbandkabel mit dem flachen Ende des Spudgers. Ziehe das Digitizer-Flachbandkabel gerade aus dem Sockel auf dem Logic Board.
  • Löse die Klebeverbindung unter dem Digitizer-Flachbandkabel mit dem flachen Ende des Spudgers.
  • Ziehe das Digitizer-Flachbandkabel gerade aus dem Sockel auf dem Logic Board.
Löse das Flachbandkabel zum Digitizer und trenne mit dem flachen Ende des Spudgers die Klebeverbindung des Kabels zum Aluminium-Rückgehäuse. Löse das Flachbandkabel zum Digitizer und trenne mit dem flachen Ende des Spudgers die Klebeverbindung des Kabels zum Aluminium-Rückgehäuse.
  • Löse das Flachbandkabel zum Digitizer und trenne mit dem flachen Ende des Spudgers die Klebeverbindung des Kabels zum Aluminium-Rückgehäuse.
Ziehe das Flachbandkabel zum Digitizer mit den Fingern aus der Vertiefung im Aluminiumrahmen.
  • Ziehe das Flachbandkabel zum Digitizer mit den Fingern aus der Vertiefung im Aluminiumrahmen.
  • Entferne das Front Panel vom iPad.
Löse das Isolierband, das den Kabelstecker der Kopfhörerbuchsen Einheit bedeckt, ab. Klappe mit der  Spudgerspitze die Haltelaschen an den beiden ZIP Steckern, mit denen das Kopfhörerbuchsen Kabel am Logic Board befestigt ist, um. Klappe mit der  Spudgerspitze die Haltelaschen an den beiden ZIP Steckern, mit denen das Kopfhörerbuchsen Kabel am Logic Board befestigt ist, um.
  • Löse das Isolierband, das den Kabelstecker der Kopfhörerbuchsen Einheit bedeckt, ab.
  • Klappe mit der Spudgerspitze die Haltelaschen an den beiden ZIP Steckern, mit denen das Kopfhörerbuchsen Kabel am Logic Board befestigt ist, um.
Fahre mit dem flachen Ende eines Spudgers unter das Kabel der Kopfhörer Einheit und löse den Kleber, mit dem sie am hinteren Aluminiumrahmen befestigt ist. Ziehe das Kabel der Kopfhörerbuchsen Einheit gerade heraus aus seiner Fassung auf dem Logic Board. Ziehe das Kabel der Kopfhörerbuchsen Einheit gerade heraus aus seiner Fassung auf dem Logic Board.
  • Fahre mit dem flachen Ende eines Spudgers unter das Kabel der Kopfhörer Einheit und löse den Kleber, mit dem sie am hinteren Aluminiumrahmen befestigt ist.
  • Ziehe das Kabel der Kopfhörerbuchsen Einheit gerade heraus aus seiner Fassung auf dem Logic Board.
Löse und entferne das Stück Tape, das den ZIF Stecker des SIM Platinenkabels bedeckt. Klappe die Haltelasche des ZIF Steckers um. Ziehe das SIM Platinenkabel mit einer Spudgerspitze gerade aus seiner Fassung auf dem Logic Board.
  • Löse und entferne das Stück Tape, das den ZIF Stecker des SIM Platinenkabels bedeckt.
  • Klappe die Haltelasche des ZIF Steckers um.
  • Ziehe das SIM Platinenkabel mit einer Spudgerspitze gerade aus seiner Fassung auf dem Logic Board.
I found it easier to remove the 7 screws first in step 42 then gently pull the logic board towards you freeing the SIM board cable.
Rich1981 - Antwort
This cable is really fragile, I found it easier to flip the retaining flap then remove all 7 screws in step 42 then gently pull the logic board toward you freeing the SIM board cable.
Rich1981 - Antwort
Der SIM Kartenleser ist mit drei 1,75 mm Kreuzschlitzschrauben #00 am Aluminiumrahmen befestigt. Drehe sie heraus.
  • Der SIM Kartenleser ist mit drei 1,75 mm Kreuzschlitzschrauben #00 am Aluminiumrahmen befestigt. Drehe sie heraus.
Be sure and remove the SIM card first from the side of the Ipad. Use a removal tool or insert a small paper clip into the hole to eject the card.
asever1 - Antwort
Schiebe das Kabel zur Kopfhöreranschluss-Einheit aus dem Weg und entferne den SIM Kartenleser vom iPad.
  • Schiebe das Kabel zur Kopfhöreranschluss-Einheit aus dem Weg und entferne den SIM Kartenleser vom iPad.
  • Achte beim Wegschieben des Kabels der Kopfhöreranschluss-Einheit darauf, nicht zu stark an der Kopfhörerbuchse zu ziehen. Sie könnte sonst herausbrechen.
While reassembling it's easier to insert the cable into the connector while placing the SIM board into place. This allows you to get the end of the cable back enough and slip it into the connector.
ken - Antwort
Löse das Klebeband, das die Kopfhörerbuchsen Einheit abdeckt, ab.
  • Löse das Klebeband, das die Kopfhörerbuchsen Einheit abdeckt, ab.
Entferne die einzelne 2,6 mm Kreuzschlitzschraube, mit der das Kamerakabel an der Kopfhörerbuchsen Einheit festgemacht ist.
  • Entferne die einzelne 2,6 mm Kreuzschlitzschraube, mit der das Kamerakabel an der Kopfhörerbuchsen Einheit festgemacht ist.
Heble die Frontkamera mit dem flachen Ende eines Spudgers aus ihrer Fassung auf der Kopfhörerbuchsen Einheit. Ohne den Spudger zwischendurch zu entfernen, fahre ihn nach rechts und löse den Kleber, der das Kamerakabel an Ort und Stelle hält. Ohne den Spudger zwischendurch zu entfernen, fahre ihn nach rechts und löse den Kleber, der das Kamerakabel an Ort und Stelle hält.
  • Heble die Frontkamera mit dem flachen Ende eines Spudgers aus ihrer Fassung auf der Kopfhörerbuchsen Einheit.
  • Ohne den Spudger zwischendurch zu entfernen, fahre ihn nach rechts und löse den Kleber, der das Kamerakabel an Ort und Stelle hält.
Klappe mit der Spudgerspitze die Haltelasche des Mikrofonkabel ZIF Steckers um. Führe die Spudgerspitze unterhalb des Flachbandkabels des Mikrofons ein und es von seinem ZIF Stecker. Fahre mit dem Spudger nach links und löse den Kleber, der das Flachbandkabel des Mikrofons an der Kopfhörerbuchsen Einheit festmacht.
  • Klappe mit der Spudgerspitze die Haltelasche des Mikrofonkabel ZIF Steckers um.
  • Führe die Spudgerspitze unterhalb des Flachbandkabels des Mikrofons ein und es von seinem ZIF Stecker.
  • Fahre mit dem Spudger nach links und löse den Kleber, der das Flachbandkabel des Mikrofons an der Kopfhörerbuchsen Einheit festmacht.
Heble mit dem flachen Ende eines Spudgers das Antennenverbindungskabel aus seiner Fassung auf der Platine der Kopfhörerbuchsen Einheit.
  • Heble mit dem flachen Ende eines Spudgers das Antennenverbindungskabel aus seiner Fassung auf der Platine der Kopfhörerbuchsen Einheit.
Klappe die Haltelasche, die den Flachbandkabelstecker von Lautstärke/Power Button an der Platine der Kopfhörerbuchsen Eineit befestigt. Trenne das Flachbandkabel von seinem ZIF Stecker.
  • Klappe die Haltelasche, die den Flachbandkabelstecker von Lautstärke/Power Button an der Platine der Kopfhörerbuchsen Eineit befestigt.
  • Trenne das Flachbandkabel von seinem ZIF Stecker.
Entferne die folgenden Schrauben von der Kopfhörerbuchsen Einheit: Fünf 2,6 mm Kreuzschlitzschrauben Zwei 2,2 mm Breitkopfschrauben
  • Entferne die folgenden Schrauben von der Kopfhörerbuchsen Einheit:
    • Fünf 2,6 mm Kreuzschlitzschrauben
    • Zwei 2,2 mm Breitkopfschrauben
    • Zwei 2,6 mm Kreuzschlitzschrauben
      • Diese Schrauben sind im Aluminiumrahmen verankert. Achte darauf, dass du den Schraubenzieher parallel zur Schraube hälst, um eine Beschädigung zu vermeiden.
Halte das Flachbandkabel der Kopfhörerbuchsen Einheit fest und ziehe die Einheit vorsichtig parallel zum iPad in Richtung Unterseite des Geräts. Halte das Flachbandkabel der Kopfhörerbuchsen Einheit fest und ziehe die Einheit vorsichtig parallel zum iPad in Richtung Unterseite des Geräts.
  • Halte das Flachbandkabel der Kopfhörerbuchsen Einheit fest und ziehe die Einheit vorsichtig parallel zum iPad in Richtung Unterseite des Geräts.
Greife die Kopfhörerbuchsen Einheit mit beiden Händen und ziehe sie mit beiden Händen vom iPad weg. Achte dabei auf Kabel, die im Weg sein können. Greife die Kopfhörerbuchsen Einheit mit beiden Händen und ziehe sie mit beiden Händen vom iPad weg. Achte dabei auf Kabel, die im Weg sein können. Greife die Kopfhörerbuchsen Einheit mit beiden Händen und ziehe sie mit beiden Händen vom iPad weg. Achte dabei auf Kabel, die im Weg sein können.
  • Greife die Kopfhörerbuchsen Einheit mit beiden Händen und ziehe sie mit beiden Händen vom iPad weg. Achte dabei auf Kabel, die im Weg sein können.
Entferne die folgenden Schrauben, mit denen das Power- und Lautstärketastenkabel am Aluminiumrahmen befestigt ist:
  • Entferne die folgenden Schrauben, mit denen das Power- und Lautstärketastenkabel am Aluminiumrahmen befestigt ist:
    • Zwei 5,5 mm Kreuzschlitzschrauben
    • Eine 2,6 mm Kreuzschlitzschraube
  • Die oberen zwei Schrauben sind im Aluminiumrahmen verankert. Achte darauf, dass der Schraubendreher sich gerade über der Schraube befindet.
Entferne die Kunststoffabdeckungen auf den Lautstärketasten.
  • Entferne die Kunststoffabdeckungen auf den Lautstärketasten.
Entferne die einzelne 2,6 mm Kreuzschlitzschraube, die Lautstärketastenrahmen am Aluminiumrahmen festmacht.
  • Entferne die einzelne 2,6 mm Kreuzschlitzschraube, die Lautstärketastenrahmen am Aluminiumrahmen festmacht.
    • Diese Schraube ist im Aluminiumrahmen verankert. Achte darauf, dass sich der Schraubendreher immer direkt über der Schraube befindet.
Keile die Kante eines Plastic Opening Tools unter den Sleep Sensor und achte dabei darauf, das empfindliche Kabel nicht zu beschädigen. Fahre mit dem Plastic Opening Tool um den Sensor und löse dabei den Kleber.
  • Keile die Kante eines Plastic Opening Tools unter den Sleep Sensor und achte dabei darauf, das empfindliche Kabel nicht zu beschädigen.
  • Fahre mit dem Plastic Opening Tool um den Sensor und löse dabei den Kleber.
Kommentar hinzufügen
Fahre mit einem Spudger unter die Power- und Lautstärkekabel und löse dabei den Kleber. Fahre mit einem Spudger unter die Power- und Lautstärkekabel und löse dabei den Kleber.
  • Fahre mit einem Spudger unter die Power- und Lautstärkekabel und löse dabei den Kleber.
Löse den Kleber unter dem Lautstärketastenabschnitt des Flachbandkabels mit der Spudgerspitze. Löse den Kleber unter dem Lautstärketastenabschnitt des Flachbandkabels mit der Spudgerspitze.
  • Löse den Kleber unter dem Lautstärketastenabschnitt des Flachbandkabels mit der Spudgerspitze.
Fahre mit der Spudgerspitze weiter Richtung Oberseite des iPads und löse dabei den Kleber. Fahre mit der Spudgerspitze weiter Richtung Oberseite des iPads und löse dabei den Kleber. Fahre mit der Spudgerspitze weiter Richtung Oberseite des iPads und löse dabei den Kleber.
  • Fahre mit der Spudgerspitze weiter Richtung Oberseite des iPads und löse dabei den Kleber.
Während die Spudgerspitze sich noch unter dem Flachbandkabel befindet, hebe den Power Button vorsichtig aus seiner Fassung auf dem Aluminiumrahmen. Während die Spudgerspitze sich noch unter dem Flachbandkabel befindet, hebe den Power Button vorsichtig aus seiner Fassung auf dem Aluminiumrahmen.
  • Während die Spudgerspitze sich noch unter dem Flachbandkabel befindet, hebe den Power Button vorsichtig aus seiner Fassung auf dem Aluminiumrahmen.
Halte das Power- & Lautstärketastenkabel mit beiden Händen fest und hebe die Lautstärketasten und Haltesperre aus ihren Fassungen im Aluminiumrahmen. Hebe das  Power- & Laustärkekabel aus der hinteren Aluminiumschale.
  • Halte das Power- & Lautstärketastenkabel mit beiden Händen fest und hebe die Lautstärketasten und Haltesperre aus ihren Fassungen im Aluminiumrahmen.
  • Hebe das Power- & Laustärkekabel aus der hinteren Aluminiumschale.
Zwänge das Plastiköffnungswerkzeug unter die Oberseite der Einschalttaste. Hebele die Oberseite der Einschalttaste hoch aus der Halteklammer.
  • Zwänge das Plastiköffnungswerkzeug unter die Oberseite der Einschalttaste.
  • Hebele die Oberseite der Einschalttaste hoch aus der Halteklammer.
Wiederhole den vorigen Schritt für die Unterseite der Einschalttaste. Hebe die Halteklammer für die Einschalttaste aus der Einheit für Lautstärkeregler und Einschalttaste. Hebe die Halteklammer für die Einschalttaste aus der Einheit für Lautstärkeregler und Einschalttaste.
  • Wiederhole den vorigen Schritt für die Unterseite der Einschalttaste.
  • Hebe die Halteklammer für die Einschalttaste aus der Einheit für Lautstärkeregler und Einschalttaste.
Zwänge die Spitze des Plastiköffnungswerkzeugs unter die Oberseite der Rotationssperre/des Stummschalters. Schiebe das Werkzeug nach unten, um die Oberseite des Schalters aus der Halteklammer zu lösen.
  • Zwänge die Spitze des Plastiköffnungswerkzeugs unter die Oberseite der Rotationssperre/des Stummschalters.
  • Schiebe das Werkzeug nach unten, um die Oberseite des Schalters aus der Halteklammer zu lösen.
Schiebe die Spitze des Plastiköffnungswerkzeugs unter die obere Lautstärkewippe und hebe sie aus der Halteklammer. Wiederhole das Ganze für die untere Lautstärkewippe.
  • Schiebe die Spitze des Plastiköffnungswerkzeugs unter die obere Lautstärkewippe und hebe sie aus der Halteklammer.
  • Wiederhole das Ganze für die untere Lautstärkewippe.
Hebe das Flachbandkabel zum Lautstärkeregler und Einschalttaste hoch und entferne es.
  • Hebe das Flachbandkabel zum Lautstärkeregler und Einschalttaste hoch und entferne es.
Abschluss
Um dein Gerät wieder zusammenzusetzen, folge den Schritten in umgekehrter Reihenfolge. Benutze unsere iPad 4 CDMA Front Panel Klebestreifen Anleitung, um das Front Panel wieder neu zu verkleben.
2 weitere Nutzer haben diese Anleitung absolviert.
Besonderer Dank geht an diese Übersetzer:
100%
Diese Übersetzer helfen uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Beginne zu übersetzen ›
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 14
Letzte 30 Tage: 56
Insgesamt: 1,457
