Was du brauchst
Set screen up a little bit to get to power connection
Power connection has PH000 screw holding it together
Slide a card under connection
Lift display back up to get to the display cables
Unscrew 2 PH000 Screws from display cable bracket
Use the flat end of plastic spudger to lift off connections
Whoohoo we got it off now clean the edges for any broken glass
Light covers place on top of proxmity sensors
APPLY HEAT TO HOME BUTTON 15-20 Seconds should do the trick
Take of home button flex cover
Use flat end of spudger to pry up home button flex connector
Install home button on new screen I recommend using liquid adhesive for this!
Push the home button a couple of times to make sure it stills on and make sure it is clicking!
Connect all 4 Flex cables to the logic board!
Now at the bottom of the new screen screw in the battery connection to test the new screen!
2 weitere Personen haben diese Anleitung absolviert.
