Einleitung
Follow this guide to replace the top microphone assembly in an iPad Air 3 for both Wi-Fi and cellular models.
The assembly includes two microphones—one points towards the back and one points upwards. The cable is strongly glued in place.
Some photos in this guide were taken from a previous model. There are small differences between models, but the overall procedure is very similar.
Was du brauchst
You may need to reapply heat repeatedly throughout this process to prevent the adhesive from cooling and hardening.
Prepare an iOpener and place it on the bottom edge of the iPad's screen for about two minutes.
In diesem Schritt verwendetes Werkzeug:Clampy - Anti-Clamp$24.95
Place a suction cup next to the iPad's home button and press down to create a seal.
Firmly pull up on the suction cup to create a small gap between the front panel and the rear case.
Once you've opened a sufficient gap, insert an opening pick into the gap.
Slice through the adhesive under the screen by sliding the pick along the edge of the display, towards the bottom left corner.
Leave the pick in place temporarily to prevent the adhesive from re-sealing.
Apply heat to the left edge of the iPad for about two minutes, or until it's slightly too hot to touch comfortably.
If necessary, re-heat your iOpener for a few seconds or until it's a bit too hot to touch. Be careful not to overheat the iOpener, or it may burst.
Insert a second opening pick at the bottom left corner of the iPad.
Slide the second opening pick along the left side of the display to separate the adhesive underneath.
Leave the opening pick inserted near the top left corner of the iPad to prevent the adhesive from re-sealing.
Apply heat to the top edge of the iPad for about two minutes, or until it's slightly too hot to touch comfortably.
Insert a third opening pick at the top left corner of the iPad.
Use the opening pick to cut the adhesive under the top edge of the iPad by sliding it to the top right corner.
Apply heat to the final, right edge of the iPad for about two minutes, or until it's slightly too hot to touch comfortably.
Insert a fourth opening pick at the top right corner of the iPad.
Slide the opening pick down to the bottom right corner to cut the adhesive.
Slide the opening pick around the bottom right corner—pausing to apply more heat if needed—and cut the remaining adhesive on the bottom edge, but stop before you reach the home button.
Insert a fifth opening pick at the top of the iPad near (but not directly on) the front-facing camera.
Gently twist the pick to separate the display assembly from the iPad.
If needed, apply more heat and/or cut any remaining adhesive that prevents the display from separating.
Lift the display assembly from its top edge and carefully slide it up (towards the front-facing camera and headphone jack), until the screw that secures the battery power connector is revealed at the bottom.
In diesem Schritt verwendetes Werkzeug:Magnetic Project Mat$17.96
Remove the 1.9 mm Phillips screw that secures the battery power connector.
To disconnect the battery, slide one prong of a battery blocker or the tip of an opening pick under the battery power connector to ensure the power circuit is interrupted.
Leave the battery blocker in place as you work.
Slowly lift the display from its top edge, being careful not to strain the attached ribbon cables.
Remove the two 1.3 mm Phillips screws securing the display connector cover bracket.
Remove the display connector cover bracket.
Use a spudger to disconnect the two visible display flex connectors by gently prying them straight up from their sockets.
Use a Phillips screwdriver to remove the five screws securing the upper component bracket:
Three 1.4 mm-long screws
Two 2.4 mm-long screws
Use a spudger to push the upper component bracket towards the upper edge and off of the clips located near the rear camera.
Use the flat end of a spudger to disconnect the front camera cable by lifting straight up on the press connector.
In diesem Schritt verwendetes Werkzeug:Halberd Spudger$2.99
Insert an opening pick or a halberd spudger underneath the front camera to cut the adhesive securing it to the rear case.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Use a pair of tweezers to remove the front camera.
Use the flat end of a spudger to disconnect the microphone assembly cable by lifting straight up on the press connector.
Apply a heated iOpener to the top edge of the iPad to loosen the microphone assembly adhesive.
If you encounter a ball of adhesive resembling hot glue holding down the microphone assembly, use the pointed end of a spudger to pick it off.
Insert an opening pick or a halberd spudger underneath the bottom of the microphone assembly cable.
Slice the adhesive securing the microphone assembly to the rear case.
Use a pair of tweezers to remove the tape securing the microphone assembly to the rear case.
Use a pair of tweezers to remove the small strip of tape underneath the upper lip of the rear case.
Insert an opening pick or a halberd spudger underneath the lower microphone and peel it up from the rear case.
Slide an opening pick or a halberd spudger behind the microphone located on the upper lip of the rear case.
Peel the upper microphone away from the rear case.
Remove the microphone assembly from the rear case.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad Air 3 Answers community for help.
