Einleitung
Prereq for disconnecting all connectors from logic board.
Was du brauchst
Use a plastic opening tool to gently pry the upper metal plate up from the front-facing camera cable connector.
Being careful not to break the plate or the tape attached to it, pry it up and fold it away from the front-facing camera cable connector.
Gently pry the second (lower) metal plate up from the front-facing camera cable connector.
Again, carefully pry the plate up and away from the front-facing camera cable connector.
Use a plastic opening tool to pry the front-facing camera cable's connector up from its socket on the logic board.
Gently fold the front-facing camera cable up and out of the way of the logic board.
Use tweezers to peel up and remove the small piece of tape covering the headphone jack cable connector.
Use a plastic opening tool to gently pry the lower metal plate up from the headphone jack cable connector.
Being careful not to break the plate or the tape attached to it, pry it up and fold it away from the headphone jack cable connector.
Pry the second (top) metal plate up from the front-facing camera cable connector.
Again, carefully pry the plate up and away from the headphone jack cable connector.
Use a plastic opening tool to pry the headphone jack cable's connector up out of its socket on the logic board.
Use a plastic opening tool to pry the top left antenna cable up from its socket on the logic board.
Remove the following three screws securing the top right antenna to the rear case:
Two 1.3 mm #00 Phillips screws from the side of the antenna's socket.
One 1.8 mm #00 Phillips screw.
Disconnect the top right antenna's coaxial cable from the logic board with a plastic opening tool.
Gently bend the cable and screw tab up out of the way of the logic board.
Use a plastic opening tool to pry the rear-facing camera cable up from its socket on the logic board.
Pry the top right antenna's ribbon cable up from its socket on the logic board with a plastic opening tool.
Use tweezers to peel up and remove the small piece of tape covering the button ribbon cable ZIF connector.
Use the tip of a spudger to lift up the tab on the button ribbon cable ZIF connector.
Use tweezers to pull the button ribbon cable straight out of its ZIF socket on the logic board.
Gently peel back the wide piece of tape covering the top of the right speaker.
Use the flat end of a spudger to disconnect the two bottom antenna cable connectors from their sockets on the logic board.
Use the tip of a spudger to peel back the small piece of tape covering both antenna cables on the bottom right side of the iPad.
With the tip of a spudger, peel up the larger piece of tape covering both antenna cables near the bottom of the rear case.
Use the tip of a spudger to pry the small metal retaining clip off the left antenna cable, then de-route the cable from the clip.
Use the tip of a spudger to remove the small piece of tape securing the antenna cable in the bottom right corner of the iPad.
Use the tip of a spudger to pry the antenna cable tape up from the rear case of the iPad.
Gently pull the antenna cable out of the way as you work along the piece of tape, to keep it from resealing.
