Einleitung
Follow this guide to replace the rear camera in your iPad Pro 11" 4th gen.
LTE and mmWave iPads: This guide is written with a previous iPad Pro model. Your device may look a little different, but the procedure is identical.
Wi-Fi only iPads: Use this guide as a general reference, but you may need to perform extra disassembly not covered in this guide.
Battery note: In some photos, you'll see two card strips blocking the battery connector. That's an optional technique—it's better to fully discharge the battery instead. Ignore this visual discrepancy as you work through the guide.
Screen disconnection: Some photos in this guide show the screen disconnected and fully removed. This isn't necessary for the procedure, so this guide skips those steps. If you wish to remove the screen, follow this guide.
This guide is written with an A2301 model iPad Pro.
Was du brauchst
Unplug any cables and fully shut down your iPad.
If your battery is swollen, take appropriate precautions.
Camera module, ambient light sensors, proximity senor, and front microphone
Display cables
Screen magnets
LCD edges
Apply a heated iOpener to the right edge of the screen for two minutes.
In diesem Schritt verwendetes Werkzeug:Clampy - Anti-Clamp$24.95
Pull the blue handle backward to unlock the Anti-Clamp's arms.
Place an object under your iPad so it rests level between the suction cups.
Position the suction cups near the middle of the right edge—one on the top, and one on the bottom.
Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
Pull the blue handle forward to lock the arms.
Turn the handle clockwise 360 degrees or until the cups start to stretch.
Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
Wait one minute to give the adhesive a chance to release and present an opening gap.
If your screen isn't getting hot enough, you can use a hair dryer to heat along the right edge of the iPad.
Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
Skip the next step.
Apply a suction handle to the right edge of the screen, about 5 cm from the bottom edge.
Pull up on the suction handle with firm, constant pressure to create a gap just small enough to insert an opening pick.
Insert the tip of an opening pick into the gap.
Insert a new opening pick in the gap you just created.
Slide the pick along the right edge to separate the adhesive.
Leave the pick in the top right corner to prevent the adhesive from re-sealing.
Apply a heated iOpener to the top edge of the screen for two minutes.
Don't insert an opening pick more than 2 mm near the top left and right edges or you'll damage the ambient light sensors.
Don't insert an opening pick more than 1 mm near the middle of the top edge or you'll damage the camera module, proximity sensor, and front microphone.
Slide the pick along the top right edge, stopping when you reach the right ambient light sensor.
Leave the pick in to prevent the adhesive from re-sealing.
Insert a new opening pick to the right of the ambient light sensor.
Slide the pick along the middle section of the top edge, stopping when you reach the left ambient light sensor.
Insert a new opening pick to the left of the ambient light sensor.
Slide the pick along the top left edge, stopping when you reach the left ambient light sensor.
Once the top edge adhesive has been separated, you can remove the two picks near the ambient light sensors.
Apply a heated iOpener to the bottom edge of the screen for two minutes.
Insert a new opening pick in the bottom right corner below the existing pick.
Slide the pick around the bottom right corner to separate the adhesive.
Slide the opening pick along the bottom edge, stopping at the USB-C port.
Leave the pick in to prevent the bottom edge adhesive from re-sealing.
Insert a new opening pick to the left of the USB-C port.
Separate the remaining bottom edge adhesive.
Leave the pick in the bottom left corner to prevent the bottom edge adhesive from re-sealing.
Apply a heated iOpener to the left edge of the screen for two minutes.
The display cables are located within small indents of the frame and require an opening pick to be inserted at a 45° angle.
There are flat sections of the frame which require an opening pick to be inserted horizontally.
Insert an opening pick at a 45˚ angle just above the bottom left corner.
Carefully slide the pick along the left edge, stopping when you reach the flat section of the frame.
Lower the opening pick so it is horizontal to the screen.
Continue separating the left edge adhesive until you reach the next indented section of the frame.
Separate the remaining adhesive, making sure to follow the instructions exactly as written.
Slide the pick at a 45˚ downward angle and don't insert the pick more than 5 mm.
Slide the pick horizontally and don't insert the pick more than 5 mm.
Use an opening pick to remove any remaining adhesive keeping the screen stuck to the frame.
Grab the top right and bottom left corners of the screen.
Slowly slide the screen towards the bottom right corner to separate it from the frame.
Shift the screen towards the bottom right corner of the frame until the ambient light sensor ribbon cable near the top edge is uncovered.
In diesem Schritt verwendetes Werkzeug:FixMat$36.95
Use a Phillips screwdriver to remove the two screws securing the ambient light sensor cable bracket to the logic board:
One 1.3 mm screw
One 2.0 mm screw
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Use a pair of tweezers or your fingers to remove the bracket.
Use the flat end of a spudger to disconnect the ambient light sensor cable by lifting straight up on the press connectors.
Grip the right edge of the screen and fold it open like a book.
Lay the screen down over the left edge of the iPad.
Use a Phillips screwdriver to remove the five screws securing the lower cable shield to the logic board:
Two 2.0 mm screws
Three 1.3 mm screws
Use tweezers or your fingers to grab and remove the lower cable shield.
Use a Phillips screwdriver to remove the three 1.2 mm screws securing the top cable shield.
Apply a heated iOpener to the top cable shield for one minute to soften the adhesive securing it to the logic board.
Insert an opening pick under the top cable shield and gently pry up to separate the adhesive.
Use tweezers or your fingers to grab and remove the top cable shield.
Use tweezers to disconnect the two antenna cables.
Slide an opening pick under the antenna cables to separate them from the logic board.
Slide an opening pick between the antenna cables and the mmWave interconnect cable to separate them.
Use a Phillips screwdriver to remove the 1.2 mm screw securing the press connector bracket to the logic board.
Use tweezers or your fingers to remove the antenna cable bracket.
Use the flat end of a spudger to disconnect the mmWave flex cable.
Slide an opening pick under the mmWave flex cable to separate it from the logic board.
Use your Phillips screwdriver to remove the six screws securing the rear camera shield to the frame:
Two 2.8 mm screws
One 1.9 mm screw
One 1.9 mm screw
One 1.2 mm screw
One 1.2 mm screw
Use tweezers or your fingers to lift the right side of the camera shield up.
Slide the shield out horizontally.
Use the pointed end of a spudger to disconnect the wide angle camera cable.
Use the pointed end of a spudger to disconnect the power button and LED cable.
Use the flat end of a spudger to disconnect the LiDAR sensor cable.
Fold the LiDAR sensor cable away from the frame to access the press connectors underneath.
Use the pointed edge of a spudger to disconnect the ultra wide camera cable.
Use the flat end of a spudger to gently pry up and loosen the rear camera module.
Use tweezers or your fingers to grab and remove the rear camera module.
