Zum Hauptinhalt wechseln
Dieser Teardown ist keine Reparaturanleitung. Um dein iPad Pro 13" zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. iPad Pro 13" Chip ID, Main Board Side 1: Schritt 1, Bild 1 von 2 iPad Pro 13" Chip ID, Main Board Side 1: Schritt 1, Bild 2 von 2
    • Apple APL1206/339S01449 S Apple M4 deca-core applications processor
    • Micron MT62F768M64D4AS-026 XT:B 6 GB LPDDR5X SDRAM memory
    • Kioxia K5A4RE0344CA12329 256 GB NAND flash
    • STMicroelectronics ST33J secure microcontroller
    • Apple APL1066/343S00682 power management
    • Apple APL1067/343S00683 power management
    • Analog Devices MAX98709B audio amplifier
  2. iPad Pro 13" Chip ID: Schritt 2, Bild 1 von 1
    • Texas Instruments SN25A23 USB type-C controller
    • Winbond W25Q80DV 1 MB serial NOR flash memory
    • Likely Apple U0MAR9-Y7 Thunderbolt 3 controller
    • Winbond W25Q64NE 8 MB serial NOR flash memory
    • Likely Broadcom BCM15900B0 touchscreen controller
    • Likely Broadcom BCM15957A0 touchscreen controller
    • Qualcomm PMX65-000 power management
  3. iPad Pro 13" Chip ID: Schritt 3, Bild 1 von 1
    • Qualcomm QET7100-001 envelope tracker
    • Apple 343S00613-A0 power management
    • Likely Apple 343S00377 power management
    • Likely Qualcomm clock generator
    • Texas Instruments TPS61230A 5 V / 6 A step-up converter
    • Texas Instruments TPS61022 8 A boost converter
    • Texas Instruments TPS259814L 6 mΩ eFuse
  4. iPad Pro 13" Chip ID, Main Board Side 1 - Connectivity: Schritt 4, Bild 1 von 1
    • Qualcomm SDX70M-000 Snapdragon X70 modem
    • Qualcomm SDR735-001 RF transceiver
    • Skyworks SKY58440-11 front-end module
    • Broadcom AFEM-8233 front-end module
    • Skyworks SKY50313 ? front end module
    • Apple 339S01360 WiFi & Bluetooth module
  5. iPad Pro 13" Chip ID, Main Board Side 1 - Sensors: Schritt 5, Bild 1 von 1
    • Bosch Sensortec accelerometer & gyroscope
    • Bosch Sensortec pressure sensor
  6. iPad Pro 13" Chip ID, Camera Board Side 1: Schritt 6, Bild 1 von 2 iPad Pro 13" Chip ID, Camera Board Side 1: Schritt 6, Bild 2 von 2
    • Apple 338S00990-A1 power management
    • Texas Instruments LM3567A1 LED flash driver
  7. iPad Pro 13" Chip ID, Wireless Charging Board Side 1: Schritt 7, Bild 1 von 2 iPad Pro 13" Chip ID, Wireless Charging Board Side 1: Schritt 7, Bild 2 von 2
    • Likely NXP Semiconductor wireless charging controller
    • Texas Instruments TPS62825 2 A step-down converter
1 Kommentar zur Anleitung
Good technical detailing
Lokesh Ram - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 15
Letzte 7 Tage: 56
Letzte 30 Tage: 194
Insgesamt: 10,027
