Einleitung
Prerequisite guide for accessing upper components in an iPad mini 4 LTE.
Was du brauchst
Run the pointed end of a spudger between the looped tape and the plastic cellular antenna housing to make it easier to peel the tape up.
Remove the following four Phillips screws holding the upper component bracket in place:
Two 2.1 mm screws
Two 1.2 mm screws
Fast fertig!
Abschluss
