Zum Hauptinhalt wechseln
iPega 9023 Disassembly
Was du brauchst
  1. iPega 9023 Disassembly, Remove Cover: Schritt 1, Bild 1 von 2 iPega 9023 Disassembly, Remove Cover: Schritt 1, Bild 2 von 2
    • Remove the four screws with the 3 mm Triage driver from the backside of the controller.
    • Use the 3 mm Triage Driver for the screws in red.
    • Use the 4 mm nut driver as a makeshift extension to remove the screws in green.
    Frag FixBot
    Kommentar hinzufügen
  2. iPega 9023 Disassembly, Removing the logic board: Schritt 2, Bild 1 von 1
    • Remove the 4 screws holding the logic board in place.
    Frag FixBot
Abschluss
16 weitere Personen haben diese Anleitung absolviert.
3 Kommentare zur Anleitung
no sonecta celular solo nombre paraece tiene salguien
COSINITAS - Antwort Teilen
Which buttons do i need to buy for L1 fix? The buttons that are on the board.
שחר רוזנברג - Antwort Teilen
i have this ipega, and try to disasemble it, but accidentaly, that long flexy cable got tear up and broke, i need a detail name for replacement for the cable, can you suggest the name and the store that available sell the product?
Bagus Rizky Basuki - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 19
Letzte 30 Tage: 78
Insgesamt: 6,284
