Einleitung
How to remove and replace the logic board on the iPhone 11 Pro.
Note: Each iPhone's logic board and Face ID + proximity sensor are paired at the factory, so replacing the logic board will disable Face ID unless you also install a replacement Face ID module + proximity sensor that has been properly paired to your new logic board.
Was du brauchst
Videoanleitungen
12 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
where can I get the parts?
Manoj Acharya - Antwort
