Einleitung
Use this guide to remove all components from the rear case of your iPhone 11 Pro. This guide will show you how to remove speaker, cables, taptic engine, battery, logic board, and button covers so you can replace a dented or bent cover.
Was du brauchst
Einführungsvideo
Power off your iPhone before beginning disassembly.
Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
12 weitere Nutzer:innen haben diese Anleitung absolviert.
3 Kommentare
If yo buy it from indonesia it only cost you arround $100-$200
