Zum Hauptinhalt wechseln
iPhone 15 Plus Earpiece Speaker Replacement
Was du brauchst
  1. iPhone 15 Plus Earpiece Speaker Replacement, Prepare your phone for disassembly: Schritt 1, Bild 1 von 2 iPhone 15 Plus Earpiece Speaker Replacement, Prepare your phone for disassembly: Schritt 1, Bild 2 von 2
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone.
    • Hold the power and either volume buttons and slide to power off your phone.
  2. iPhone 15 Plus Earpiece Speaker Replacement, Tape over any cracks: Schritt 2, Bild 1 von 2 iPhone 15 Plus Earpiece Speaker Replacement, Tape over any cracks: Schritt 2, Bild 2 von 2
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 15 Plus Earpiece Speaker Replacement, Mark your opening picks: Schritt 3, Bild 1 von 3 iPhone 15 Plus Earpiece Speaker Replacement, Mark your opening picks: Schritt 3, Bild 2 von 3 iPhone 15 Plus Earpiece Speaker Replacement, Mark your opening picks: Schritt 3, Bild 3 von 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  4. iPhone 15 Plus Earpiece Speaker Replacement, Remove the pentalobe screws: Schritt 4, Bild 1 von 1
    • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the charging port.
  5. iPhone 15 Plus Earpiece Speaker Replacement, Heat the bottom edge: Schritt 5, Bild 1 von 1
    • Use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
  6. iPhone 15 Plus Earpiece Speaker Replacement, Insert an opening pick: Schritt 6, Bild 1 von 3 iPhone 15 Plus Earpiece Speaker Replacement, Insert an opening pick: Schritt 6, Bild 2 von 3 iPhone 15 Plus Earpiece Speaker Replacement, Insert an opening pick: Schritt 6, Bild 3 von 3
    • Apply a suction handle to the bottom edge of the back glass.
    • Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
    • Insert the tip of an opening pick into the gap.
  7. iPhone 15 Plus Earpiece Speaker Replacement, Back glass information: Schritt 7, Bild 1 von 1
    • As you slice the adhesive securing the back glass in the next steps, be careful of the following areas:
    • There's a delicate cable connecting the back glass to the phone, right next to the volume up button. Don't insert your pick here to avoid slicing the cable.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in each step to avoid bending these contacts.
  8. iPhone 15 Plus Earpiece Speaker Replacement, Separate the bottom edge adhesive: Schritt 8, Bild 1 von 3 iPhone 15 Plus Earpiece Speaker Replacement, Separate the bottom edge adhesive: Schritt 8, Bild 2 von 3 iPhone 15 Plus Earpiece Speaker Replacement, Separate the bottom edge adhesive: Schritt 8, Bild 3 von 3
    • Don't insert your opening pick deeper than 5 mm along the bottom edge.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  9. iPhone 15 Plus Earpiece Speaker Replacement, Heat the right edge: Schritt 9, Bild 1 von 1
    • Heat the right edge of the back glass until it's hot to the touch.
  10. iPhone 15 Plus Earpiece Speaker Replacement, Separate the bottom right corner adhesive: Schritt 10, Bild 1 von 3 iPhone 15 Plus Earpiece Speaker Replacement, Separate the bottom right corner adhesive: Schritt 10, Bild 2 von 3 iPhone 15 Plus Earpiece Speaker Replacement, Separate the bottom right corner adhesive: Schritt 10, Bild 3 von 3
    • Don't insert your pick deeper than 7 mm along the right edge.
    • Rotate your pick around the bottom right corner and slide it halfway up the right edge or until you feel a hard stop at a clip securing the back glass.
    • Don't slice near the volume buttons to avoid damaging the wireless charging cable.
    • Leave this pick inserted to prevent the adhesive from resealing.
  11. iPhone 15 Plus Earpiece Speaker Replacement, Heat the left edge: Schritt 11, Bild 1 von 1
    • Heat the left edge of the back glass until it's hot to the touch.
  12. iPhone 15 Plus Earpiece Speaker Replacement, Separate the left edge adhesive: Schritt 12, Bild 1 von 3 iPhone 15 Plus Earpiece Speaker Replacement, Separate the left edge adhesive: Schritt 12, Bild 2 von 3 iPhone 15 Plus Earpiece Speaker Replacement, Separate the left edge adhesive: Schritt 12, Bild 3 von 3
    • Don't insert your pick deeper than 5 mm along the left edge.
    • Insert a second opening pick at the bottom edge.
    • Rotate the second pick around the bottom left corner.
    • Slide this pick up to the top left corner to separate the adhesive.
  13. iPhone 15 Plus Earpiece Speaker Replacement, Heat the top edge: Schritt 13, Bild 1 von 1
    • Heat the top edge of the back glass until it's hot to the touch.
  14. iPhone 15 Plus Earpiece Speaker Replacement, Separate the top edge adhesive: Schritt 14, Bild 1 von 3 iPhone 15 Plus Earpiece Speaker Replacement, Separate the top edge adhesive: Schritt 14, Bild 2 von 3 iPhone 15 Plus Earpiece Speaker Replacement, Separate the top edge adhesive: Schritt 14, Bild 3 von 3
    • Don't insert your pick deeper than 3 mm along the top edge.
    • Rotate your second opening pick around the top left corner and slide it to the top right corner to separate the adhesive.
    • You might hear and feel clicks as the top two clips release.
    • Leave this pick in place to prevent the adhesive from resealing.
  15. iPhone 15 Plus Earpiece Speaker Replacement, Heat the top right corner: Schritt 15, Bild 1 von 1
    • Heat the top right corner of the back glass until it's hot to the touch.
  16. iPhone 15 Plus Earpiece Speaker Replacement, Separate the top right corner adhesive: Schritt 16, Bild 1 von 3 iPhone 15 Plus Earpiece Speaker Replacement, Separate the top right corner adhesive: Schritt 16, Bild 2 von 3 iPhone 15 Plus Earpiece Speaker Replacement, Separate the top right corner adhesive: Schritt 16, Bild 3 von 3
    • Don't insert your pick deeper than 4 mm along the right edge.
    • Rotate the second opening pick around the top right corner and slide it to the volume up button to separate the adhesive.
  17. iPhone 15 Plus Earpiece Speaker Replacement, Swing open the back glass: Schritt 17, Bild 1 von 2 iPhone 15 Plus Earpiece Speaker Replacement, Swing open the back glass: Schritt 17, Bild 2 von 2
    • Gently swing open the back glass to the right of the phone.
    • If the back glass feels stuck, go back around the perimeter to check for missed sections of adhesive or stuck clips.
    • Rest the back glass against a raised surface so it doesn't strain the cable.
  18. iPhone 15 Plus Earpiece Speaker Replacement, Unfasten the lower connector cover: Schritt 18, Bild 1 von 2 iPhone 15 Plus Earpiece Speaker Replacement, Unfasten the lower connector cover: Schritt 18, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    FixMat
    $36.95
    • Use a tri-point Y000 driver to remove the two 1.3 mm-long screws securing the lower connector cover.
  19. iPhone 15 Plus Earpiece Speaker Replacement, Remove the lower connector cover: Schritt 19, Bild 1 von 3 iPhone 15 Plus Earpiece Speaker Replacement, Remove the lower connector cover: Schritt 19, Bild 2 von 3 iPhone 15 Plus Earpiece Speaker Replacement, Remove the lower connector cover: Schritt 19, Bild 3 von 3
    • Use tweezers to slide the cover toward the top of the phone to unlatch it from the logic board.
    • Remove the cover.
    • During reassembly, latch the top edge of the cover onto its slot on the logic board before securing it with its screw.
  20. iPhone 15 Plus Earpiece Speaker Replacement: Schritt 20, Bild 1 von 3 iPhone 15 Plus Earpiece Speaker Replacement: Schritt 20, Bild 2 von 3 iPhone 15 Plus Earpiece Speaker Replacement: Schritt 20, Bild 3 von 3
    • Hold the back glass upright with one hand and rotate the bottom edge to the left to reveal the battery press connector just below the volume buttons.
    • Use the tip of an opening pick to pry up and disconnect the battery press connector from the logic board.
    • A plus and minus sign is printed on the head of this connector.
    • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side. Make sure it sits flat, as the insulating rubber around the sockets might prevent it from connecting fully.
  21. iPhone 15 Plus Earpiece Speaker Replacement, Unfasten the middle connector cover: Schritt 21, Bild 1 von 2 iPhone 15 Plus Earpiece Speaker Replacement, Unfasten the middle connector cover: Schritt 21, Bild 2 von 2
    • Use your tri-point Y000 driver to remove the 0.9 mm-long screw securing the middle connector cover.
  22. iPhone 15 Plus Earpiece Speaker Replacement, Remove the cover: Schritt 22, Bild 1 von 3 iPhone 15 Plus Earpiece Speaker Replacement, Remove the cover: Schritt 22, Bild 2 von 3 iPhone 15 Plus Earpiece Speaker Replacement, Remove the cover: Schritt 22, Bild 3 von 3
    • Use the flat end of a spudger or your finger to push the cover toward the bottom of the phone and unclip its top edge.
    • Remove the cover.
    • During reassembly, place the cover so its tab is just behind the clip on the logic board. Press down with one finger and slide the cover forward to engage the clip.
  23. iPhone 15 Plus Earpiece Speaker Replacement, Disconnect the wireless charging coil: Schritt 23, Bild 1 von 2 iPhone 15 Plus Earpiece Speaker Replacement, Disconnect the wireless charging coil: Schritt 23, Bild 2 von 2
    • Use an opening pick to pry up and disconnect the wireless charging coil and NFC connector.
  24. iPhone 15 Plus Earpiece Speaker Replacement: Schritt 24, Bild 1 von 1
    • Remove the back glass.
    • During reassembly:
    • This is a good point to test your repair before sealing up your phone. Temporarily reconnect the battery and back glass, power on your phone, and make sure it works as expected. Power it back down and continue reassembly.
    • Use this guide to reapply adhesive and install your back glass.
  25. iPhone 15 Plus Earpiece Speaker Replacement, Remove the upper connector cover: Schritt 25, Bild 1 von 3 iPhone 15 Plus Earpiece Speaker Replacement, Remove the upper connector cover: Schritt 25, Bild 2 von 3 iPhone 15 Plus Earpiece Speaker Replacement, Remove the upper connector cover: Schritt 25, Bild 3 von 3
    • Use your tri-point Y000 driver to remove the two 1.3 mm‑long screws securing the upper connector cover.
    • Remove the cover.
  26. iPhone 15 Plus Earpiece Speaker Replacement, Disconnect the front camera assembly: Schritt 26, Bild 1 von 3 iPhone 15 Plus Earpiece Speaker Replacement, Disconnect the front camera assembly: Schritt 26, Bild 2 von 3 iPhone 15 Plus Earpiece Speaker Replacement, Disconnect the front camera assembly: Schritt 26, Bild 3 von 3
    • Use the tip of an opening pick to pry up and disconnect the antenna, front sensors, and front camera press connectors (three connectors in total).
  27. iPhone 15 Plus Earpiece Speaker Replacement, Remove the front camera and sensors: Schritt 27, Bild 1 von 2 iPhone 15 Plus Earpiece Speaker Replacement, Remove the front camera and sensors: Schritt 27, Bild 2 von 2
    • Use tweezers or your fingers to pull the front camera and sensors out of their recess in the frame and remove them.
  28. iPhone 15 Plus Earpiece Speaker Replacement, Disconnect the earpiece speaker: Schritt 28, Bild 1 von 2 iPhone 15 Plus Earpiece Speaker Replacement, Disconnect the earpiece speaker: Schritt 28, Bild 2 von 2
    • Use the tip of an opening pick to pry up and disconnect the earpiece speaker press connector.
  29. iPhone 15 Plus Earpiece Speaker Replacement, Unfasten the earpiece speaker: Schritt 29, Bild 1 von 2 iPhone 15 Plus Earpiece Speaker Replacement, Unfasten the earpiece speaker: Schritt 29, Bild 2 von 2
    • Use a Phillips #000 driver to remove the seven screws securing the earpiece speaker:
    • Five 1.6 mm‑long screws
    • Two 1.3 mm‑long screws
  30. iPhone 15 Plus Earpiece Speaker Replacement, Remove the earpiece speaker: Schritt 30, Bild 1 von 3 iPhone 15 Plus Earpiece Speaker Replacement, Remove the earpiece speaker: Schritt 30, Bild 2 von 3 iPhone 15 Plus Earpiece Speaker Replacement, Remove the earpiece speaker: Schritt 30, Bild 3 von 3
    • Insert the flat end of a spudger between the top left edge of the earpiece speaker and pry up until you can grab it with your fingers.
    • Remove the earpiece speaker.
  31. iPhone 15 Plus Earpiece Speaker Replacement, Remove the antenna: Schritt 31, Bild 1 von 3 iPhone 15 Plus Earpiece Speaker Replacement, Remove the antenna: Schritt 31, Bild 2 von 3 iPhone 15 Plus Earpiece Speaker Replacement, Remove the antenna: Schritt 31, Bild 3 von 3
    • Your earpiece speaker has an adhered antenna that must be transferred to your new speaker.
    • Insert your opening pick between the antenna and the earpiece speaker.
    • Slide the pick under the antenna and pry up to separate the adhesive securing it.
    • Remove the antenna
  32. iPhone 15 Plus Earpiece Speaker Replacement, Reassembly information: Schritt 32, Bild 1 von 2 iPhone 15 Plus Earpiece Speaker Replacement, Reassembly information: Schritt 32, Bild 2 von 2
    Tesa 61395 Tape
    $6.99
    • During reassembly, follow these steps to reinstall the antenna:
    • Remove any leftover adhesive from the earpiece speaker and antenna.
    • If the existing adhesive is still sticky, you can reuse it instead of applying new tape.
    • Before sticking the antenna to the earpiece speaker, fasten the earpiece speaker to the frame and install the front camera and sensors. Connect all three press connectors.
    • Apply a small piece of thin, double-sided tape, such as Tesa tape, to the antenna.
    • Finally, connect the antenna press connector, then stick it onto the earpiece speaker.
Abschluss
To reassemble your phone, follow these instructions in reverse order.
Eine weitere Person hat diese Anleitung absolviert.
Clay Eickemeyer
86.085 Reputation
455 Anleitungen geschrieben
Guide Team Mitglied von Guide Team
Staff
9 Mitglieder
13.297 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 13
Letzte 30 Tage: 86
Insgesamt: 1,238
