Zum Hauptinhalt wechseln
iPhone 16 Pro Earpiece Speaker Removal
Grundständige Anleitung
Dies ist eine grundständige Anleitung. Es wird eine Vorgehensweise beschrieben, die die Voraussetzung für andere Anleitungen darstellt, aber keine eigenständige Reparatur.
Was du brauchst
  1. iPhone 16 Pro Earpiece Speaker Removal, Prepare the phone for disassembly: Schritt 1, Bild 1 von 2 iPhone 16 Pro Earpiece Speaker Removal, Prepare the phone for disassembly: Schritt 1, Bild 2 von 2
    • Allow the phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from the phone.
    • Hold the power and either volume buttons and slide to power off the phone.
    Frag FixBot
    Kommentar hinzufügen
  2. iPhone 16 Pro Earpiece Speaker Removal, Tape over any cracks: Schritt 2, Bild 1 von 2 iPhone 16 Pro Earpiece Speaker Removal, Tape over any cracks: Schritt 2, Bild 2 von 2
    • If the screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
    Frag FixBot
  3. iPhone 16 Pro Earpiece Speaker Removal, Mark your opening picks: Schritt 3, Bild 1 von 3 iPhone 16 Pro Earpiece Speaker Removal, Mark your opening picks: Schritt 3, Bild 2 von 3 iPhone 16 Pro Earpiece Speaker Removal, Mark your opening picks: Schritt 3, Bild 3 von 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Frag FixBot
  4. iPhone 16 Pro Earpiece Speaker Removal, Remove the pentalobe screws: Schritt 4, Bild 1 von 2 iPhone 16 Pro Earpiece Speaker Removal, Remove the pentalobe screws: Schritt 4, Bild 2 von 2
    • Use a P2 pentalobe screwdriver to remove the two 7.4 mm‑long screws on either side of the USB-C port.
    Frag FixBot
  5. iPhone 16 Pro Earpiece Speaker Removal, Only the earpiece speaker remains: Schritt 5, Bild 1 von 1
    • Only the earpiece speaker remains for replacement.
    Frag FixBot
Abschluss
To reassemble your iPhone, follow these instructions in reverse order.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 16 Pro Answers Community for help.
Nick Schultz
58.627 Reputation
318 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
123 Mitglieder
30.815 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 20
Insgesamt: 126
