Zum Hauptinhalt wechseln
iPhone 16 Pro Max Screen Replacement
Was du brauchst
  1. iPhone 16 Pro Max Screen Replacement, Before you begin: Schritt 1, Bild 1 von 3 iPhone 16 Pro Max Screen Replacement, Before you begin: Schritt 1, Bild 2 von 3 iPhone 16 Pro Max Screen Replacement, Before you begin: Schritt 1, Bild 3 von 3
    • Allow your iPhone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your iPhone.
    • Hold the power and either volume buttons, and slide to power off your iPhone.
    Frag FixBot
    Kommentar hinzufügen
  2. iPhone 16 Pro Max Screen Replacement, Tape over any cracks: Schritt 2, Bild 1 von 2 iPhone 16 Pro Max Screen Replacement, Tape over any cracks: Schritt 2, Bild 2 von 2
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
    Frag FixBot
  3. iPhone 16 Pro Max Screen Replacement, Remove the pentalobe screws: Schritt 3, Bild 1 von 2 iPhone 16 Pro Max Screen Replacement, Remove the pentalobe screws: Schritt 3, Bild 2 von 2
    • Use a P2 pentalobe driver to remove the two 7.4 mm-long screws on either side of the charge port.
    Frag FixBot
  4. iPhone 16 Pro Max Screen Replacement, Mark your opening picks: Schritt 4, Bild 1 von 3 iPhone 16 Pro Max Screen Replacement, Mark your opening picks: Schritt 4, Bild 2 von 3 iPhone 16 Pro Max Screen Replacement, Mark your opening picks: Schritt 4, Bild 3 von 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Frag FixBot
  5. iPhone 16 Pro Max Screen Replacement, Create a gap with a suction handle: Schritt 5, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    iOpener
    $14.95
    • The next two steps show how to create an initial gap using a suction handle.
    • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
    • You can also use an iOpener to heat the screen. Follow these instructions to heat and apply the iOpener properly.
    Frag FixBot
  6. iPhone 16 Pro Max Screen Replacement: Schritt 6, Bild 1 von 3 iPhone 16 Pro Max Screen Replacement: Schritt 6, Bild 2 von 3 iPhone 16 Pro Max Screen Replacement: Schritt 6, Bild 3 von 3
    • Apply a suction handle to the bottom edge of the screen.
    • While supporting the frame with one hand, pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
    • If you can't create a gap, apply more heat to the edge and try again.
    • Insert the tip of an opening pick into the gap.
    Frag FixBot
  7. iPhone 16 Pro Max Screen Replacement, Screen information: Schritt 7, Bild 1 von 1
    • As you slice the adhesive securing the screen in the following steps, don't insert your pick deeper than 3 mm to avoid damaging the following areas:
    • Two delicate cables connecting the screen to the iPhone—one just above the Action button and the other about halfway along the left edge of the iPhone
    • Multiple spring contacts around the perimeter of the iPhone
    Frag FixBot
  8. iPhone 16 Pro Max Screen Replacement, Slice the bottom edge adhesive: Schritt 8, Bild 1 von 2 iPhone 16 Pro Max Screen Replacement, Slice the bottom edge adhesive: Schritt 8, Bild 2 von 2
    • Slide the opening pick along the bottom edge to release the adhesive.
    • Don't insert the pick deeper than 3 mm to avoid damaging the spring contacts.
    • If the adhesive feels difficult to slice, reheat the edge for a minute.
    • Leave the opening pick in the bottom-left corner to prevent the adhesive from resealing.
    Frag FixBot
  9. iPhone 16 Pro Max Screen Replacement, Heat the left edge: Schritt 9, Bild 1 von 1
    • Use a hair dryer or heat gun to heat the left edge of the screen until it's hot to the touch.
    Frag FixBot
  10. iPhone 16 Pro Max Screen Replacement, Separate the left adhesive: Schritt 10, Bild 1 von 2 iPhone 16 Pro Max Screen Replacement, Separate the left adhesive: Schritt 10, Bild 2 von 2
    • Don't insert your pick deeper than 3 mm to avoid damaging the spring contacts and cables.
    • Insert a second opening pick in the bottom-left corner, close to the existing pick.
    • Slide the opening pick along the left edge of the screen to separate the adhesive and release the metal clips.
    • You'll hear and feel the metal clips release as you pass them.
    • Leave the opening pick in the top-left corner to prevent the adhesive from resealing.
    Frag FixBot
  11. iPhone 16 Pro Max Screen Replacement, Separate the remaining adhesives: Schritt 11, Bild 1 von 3 iPhone 16 Pro Max Screen Replacement, Separate the remaining adhesives: Schritt 11, Bild 2 von 3 iPhone 16 Pro Max Screen Replacement, Separate the remaining adhesives: Schritt 11, Bild 3 von 3
    • Repeat the heating and slicing procedure along the remaining screen edges.
    Frag FixBot
  12. iPhone 16 Pro Max Screen Replacement, Swing open the screen: Schritt 12, Bild 1 von 3 iPhone 16 Pro Max Screen Replacement, Swing open the screen: Schritt 12, Bild 2 von 3 iPhone 16 Pro Max Screen Replacement, Swing open the screen: Schritt 12, Bild 3 von 3
    • At this point, the screen should be free from the frame. If the screen feels stuck, go back around the perimeter with your pick and carefully check for missed sections of adhesive or stuck clips.
    • Carefully lift the screen upwards until the clips along the long edges clear the frame.
    • Swing open the screen over the left edge of the iPhone and lay it flat on your work surface.
    Frag FixBot
  13. iPhone 16 Pro Max Screen Replacement, Remove the connector covers: Schritt 13, Bild 1 von 1
    • Use a tri-point Y000 driver to remove the two 1.3 mm‑long screws securing the front sensor and display connector covers.
    Frag FixBot
  14. iPhone 16 Pro Max Screen Replacement: Schritt 14, Bild 1 von 3 iPhone 16 Pro Max Screen Replacement: Schritt 14, Bild 2 von 3 iPhone 16 Pro Max Screen Replacement: Schritt 14, Bild 3 von 3
    • Use tweezers to grasp the front sensor connector cover near the screw hole.
    • Lift and remove the cover.
    • Repeat the procedure to remove the display connector cover.
    Frag FixBot
  15. iPhone 16 Pro Max Screen Replacement, Disconnect the screen: Schritt 15, Bild 1 von 3 iPhone 16 Pro Max Screen Replacement, Disconnect the screen: Schritt 15, Bild 2 von 3 iPhone 16 Pro Max Screen Replacement, Disconnect the screen: Schritt 15, Bild 3 von 3
    • Use the tip of a spudger to pry up and disconnect the display press connector.
    • Repeat for the front sensor press connector.
    Frag FixBot
  16. iPhone 16 Pro Max Screen Replacement, Remove the screen: Schritt 16, Bild 1 von 1
    • Lift the screen and remove it.
    Frag FixBot
  17. iPhone 16 Pro Max Screen Replacement, Disassembly complete: Schritt 17, Bild 1 von 1
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your iPhone.
    • Depending on your iPhone model, some reassembly photos may have minor visual discrepancies. The procedure, however, will be correct for your iPhone.
    Frag FixBot
  18. iPhone 16 Pro Max Screen Replacement, Ambient light sensor information: Schritt 18, Bild 1 von 1
    • The ambient light sensor is located behind the screen, next to the cut‑out for the Face ID sensors.
    • Check if the replacement screen comes with one installed. If it does, click here to skip the next twelve steps.
    Frag FixBot
  19. iPhone 16 Pro Max Screen Replacement, Remove the ambient light sensor bracket: Schritt 19, Bild 1 von 2 iPhone 16 Pro Max Screen Replacement, Remove the ambient light sensor bracket: Schritt 19, Bild 2 von 2
    • Use a tri‑point Y000 driver to remove the 1 mm‑long screw securing the bracket on the ambient light sensor.
    Frag FixBot
  20. iPhone 16 Pro Max Screen Replacement: Schritt 20, Bild 1 von 2 iPhone 16 Pro Max Screen Replacement: Schritt 20, Bild 2 von 2
    • Use a pair of tweezers or your fingers to lift and remove the ambient light sensor bracket.
    Frag FixBot
  21. iPhone 16 Pro Max Screen Replacement, Heat the ambient light sensor cable: Schritt 21, Bild 1 von 1
    • Use a hair dryer, heat gun, or iOpener to soften the adhesive under the ambient light sensor and ambient light sensor cable.
    Frag FixBot
  22. iPhone 16 Pro Max Screen Replacement, Peel up the ambient light sensor cable: Schritt 22, Bild 1 von 3 iPhone 16 Pro Max Screen Replacement, Peel up the ambient light sensor cable: Schritt 22, Bild 2 von 3 iPhone 16 Pro Max Screen Replacement, Peel up the ambient light sensor cable: Schritt 22, Bild 3 von 3
    • Be careful and work slowly—the cable is extremely delicate, especially near the sensor. Don't try to lift the sensor itself yet.
    • Slowly slide an opening pick under the ambient light sensor cable, starting under the connector at the bottom and working upwards until the cable is free from the screen.
    • If the adhesive doesn't peel up easily, apply more heat.
    Frag FixBot
  23. iPhone 16 Pro Max Screen Replacement, Reheat the ambient light sensor: Schritt 23, Bild 1 von 1
    Frag FixBot
  24. iPhone 16 Pro Max Screen Replacement, Pry up the ambient light sensor: Schritt 24, Bild 1 von 3 iPhone 16 Pro Max Screen Replacement, Pry up the ambient light sensor: Schritt 24, Bild 2 von 3 iPhone 16 Pro Max Screen Replacement, Pry up the ambient light sensor: Schritt 24, Bild 3 von 3
    • Work slowly to avoid tearing the thin cable attached to the ambient light sensor. If it feels stubborn, apply more heat instead of using more force.
    • Use the flat end of a spudger to slowly pry up the ambient light sensor from the side with the protruding cable.
    • Remove the ambient light sensor.
    Frag FixBot
  25. iPhone 16 Pro Max Screen Replacement, Prepare the ambient light sensor: Schritt 25, Bild 1 von 1
    Tesa 61395 Tape
    $2.95
    • Use tweezers to reposition any adhesive that may have covered the ambient light sensor during removal. The adhesive should form a border around the raised rectangle.
    • If the adhesive was damaged or stayed with the old screen, replace it with a 1 mm wide strip of thin, double-sided tape along its top border.
    Frag FixBot
  26. iPhone 16 Pro Max Screen Replacement, Place the ambient light sensor: Schritt 26, Bild 1 von 2 iPhone 16 Pro Max Screen Replacement, Place the ambient light sensor: Schritt 26, Bild 2 von 2
    • Align the ambient light sensor with its recess in the back of the screen.
    • Use a spudger or your finger to press the ambient light sensor into its recess.
    Frag FixBot
  27. iPhone 16 Pro Max Screen Replacement, Warm the ambient light sensor cable: Schritt 27, Bild 1 von 1
    • Use a hair dryer, heat gun, or iOpener to soften the adhesive under the ambient light sensor and its cable. It only needs to be warm—not hot.
    Frag FixBot
  28. iPhone 16 Pro Max Screen Replacement, Press the ambient light sensor: Schritt 28, Bild 1 von 3 iPhone 16 Pro Max Screen Replacement, Press the ambient light sensor: Schritt 28, Bild 2 von 3 iPhone 16 Pro Max Screen Replacement, Press the ambient light sensor: Schritt 28, Bild 3 von 3
    Tesa 61395 Tape
    $2.95
    • Use your finger to press down the ambient light sensor cable.
    • If the ambient light sensor cable isn't sticking, apply a few small pieces of thin, double‑sided tape, like Tesa tape, to the back of the sensor cable.
    Frag FixBot
  29. iPhone 16 Pro Max Screen Replacement, Install the ambient light sensor bracket: Schritt 29, Bild 1 von 3 iPhone 16 Pro Max Screen Replacement, Install the ambient light sensor bracket: Schritt 29, Bild 2 von 3 iPhone 16 Pro Max Screen Replacement, Install the ambient light sensor bracket: Schritt 29, Bild 3 von 3
    • Use tweezers or your fingers to hook the ambient light sensor bracket over the back of the sensor and set it into place.
    Frag FixBot
  30. iPhone 16 Pro Max Screen Replacement: Schritt 30, Bild 1 von 1
    • Use a tri‑point Y000 driver to install the 1 mm‑long screw securing the bracket on the ambient light sensor.
    Frag FixBot
  31. iPhone 16 Pro Max Screen Replacement, Remove the adhesive and its residue: Schritt 31, Bild 1 von 2 iPhone 16 Pro Max Screen Replacement, Remove the adhesive and its residue: Schritt 31, Bild 2 von 2
    • Use a spudger or tweezers to remove the adhesive chunks from the iPhone's frame.
    • Work around the fragile grounding clips. If you bend one out of place, gently bend it back with your fingers or tweezers.
    Frag FixBot
  32. iPhone 16 Pro Max Screen Replacement: Schritt 32, Bild 1 von 1
    • If you're reinstalling your existing screen, be sure to remove any remaining adhesive from the back of your screen as well.
    Frag FixBot
  33. iPhone 16 Pro Max Screen Replacement: Schritt 33, Bild 1 von 2 iPhone 16 Pro Max Screen Replacement: Schritt 33, Bild 2 von 2
    • Using a lint-free cloth (or coffee filter) and some high concentration (>90%) isopropyl alcohol, clean the areas of the frame and screen where you removed the old adhesive.
    • For best results, swipe your cleaning cloth in one direction, not back and forth.
    • Take your time doing this. A clean frame allows replacement adhesive to lay evenly, ensuring a better bond.
    Frag FixBot
  34. iPhone 16 Pro Max Screen Replacement, Apply the replacement adhesive: Schritt 34, Bild 1 von 1
    • Lay the adhesive sheet over the frame to determine its proper orientation.
    • Use features such as the camera cutout to visualize how the adhesive will lay in the frame.
    Frag FixBot
  35. iPhone 16 Pro Max Screen Replacement: Schritt 35, Bild 1 von 1
    • Grasp the tab in the corner of the adhesive sheet and peel the liner to expose a third of the adhesive.
    • The exposed adhesive is very sticky. Don't let it touch anything until you're ready to apply it to the frame.
    • If your adhesive has multiple liners, peel the liner that exposes the side that sticks to the frame.
    Frag FixBot
  36. iPhone 16 Pro Max Screen Replacement: Schritt 36, Bild 1 von 3 iPhone 16 Pro Max Screen Replacement: Schritt 36, Bild 2 von 3 iPhone 16 Pro Max Screen Replacement: Schritt 36, Bild 3 von 3
    • Carefully align the exposed edge of the adhesive strip with the corresponding edge of your iPhone's frame.
    • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
    • When it's correctly aligned, gently press the exposed adhesive strip into place.
    Frag FixBot
  37. iPhone 16 Pro Max Screen Replacement: Schritt 37, Bild 1 von 3 iPhone 16 Pro Max Screen Replacement: Schritt 37, Bild 2 von 3 iPhone 16 Pro Max Screen Replacement: Schritt 37, Bild 3 von 3
    • Continue peeling away the liner from the adhesive, gently pressing the adhesive into place.
    • If you've correctly aligned the adhesive, the edges will fall perfectly into place.
    • If your adhesive is slightly misaligned, pull the long edges into alignment with the frame.
    • If the adhesive begins to crease or wrinkle, remove it and start over with fresh adhesive.
    • If you don't have another set of adhesive strips handy, it's okay to temporarily put your iPhone back together and use it normally without any adhesive. Just keep in mind that your iPhone's water resistance will be compromised until you replace the adhesive.
    Frag FixBot
  38. iPhone 16 Pro Max Screen Replacement: Schritt 38, Bild 1 von 2 iPhone 16 Pro Max Screen Replacement: Schritt 38, Bild 2 von 2
    • Use a spudger to press the adhesive around the entire perimeter of your iPhone.
    • Don't press too hard, or you'll stretch and deform the adhesive.
    Frag FixBot
  39. iPhone 16 Pro Max Screen Replacement: Schritt 39, Bild 1 von 3 iPhone 16 Pro Max Screen Replacement: Schritt 39, Bild 2 von 3 iPhone 16 Pro Max Screen Replacement: Schritt 39, Bild 3 von 3
    • Use a spudger or your fingers to lift the pull tab connected to the large front liner—the pull tab is often in a corner of the liner.
    • Use the pull tab to peel off the large front liner from the adhesive.
    • At this point, you may still have liners covering the perimeter, which prevent the adhesive from accidentally sticking to anything while you're reassembling your iPhone. Don't remove these small release liners just yet.
    Frag FixBot
  40. iPhone 16 Pro Max Screen Replacement, Reconnect the screen: Schritt 40, Bild 1 von 2 iPhone 16 Pro Max Screen Replacement, Reconnect the screen: Schritt 40, Bild 2 von 2
    • Use your finger to press down and connect the display connector.
    • To re-attach wide press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    • Press down and connect the front sensor connector.
    • Align the connector carefully over its socket and press down with your fingertip until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
    • This is a good time to power on your iPhone and test all functions before you seal it up. Be sure to power your iPhone back down completely before you continue.
    • If your iPhone doesn't turn on, connect it to a power source and try again.
    Frag FixBot
  41. iPhone 16 Pro Max Screen Replacement, Install the connector covers: Schritt 41, Bild 1 von 2 iPhone 16 Pro Max Screen Replacement, Install the connector covers: Schritt 41, Bild 2 von 2
    • Tuck the display connector cover's tab into its frame cutout and lay the cover in place.
    • Repeat with the front sensor connector cover.
    Frag FixBot
  42. iPhone 16 Pro Max Screen Replacement: Schritt 42, Bild 1 von 1
    • Use a tri-point Y000 driver to install the two 1.3 mm‑long screws securing the two connector covers.
    Frag FixBot
  43. iPhone 16 Pro Max Screen Replacement, Remove the final liners: Schritt 43, Bild 1 von 3 iPhone 16 Pro Max Screen Replacement, Remove the final liners: Schritt 43, Bild 2 von 3 iPhone 16 Pro Max Screen Replacement, Remove the final liners: Schritt 43, Bild 3 von 3
    • While supporting the screen, use your fingers or a spudger to peel away all perimeter liners, exposing the adhesive.
    • Be careful not to touch the exposed adhesive.
    • Check the frame and screen for any stray liners and remove them. There should be no liners remaining.
    Frag FixBot
  44. iPhone 16 Pro Max Screen Replacement, Install the screen onto the frame: Schritt 44, Bild 1 von 2 iPhone 16 Pro Max Screen Replacement, Install the screen onto the frame: Schritt 44, Bild 2 von 2
    • Carefully align the screen's top clips with their frame cutouts.
    Frag FixBot
  45. iPhone 16 Pro Max Screen Replacement: Schritt 45, Bild 1 von 3 iPhone 16 Pro Max Screen Replacement: Schritt 45, Bild 2 von 3 iPhone 16 Pro Max Screen Replacement: Schritt 45, Bild 3 von 3
    • Lower the screen onto the frame, beginning with the top edge.
    • If you feel resistance, a perimeter clip may have bent out of place and is being crushed by the frame. Look at the point of resistance and gently straighten any bent clips.
    • Make sure the screen edge isn't pinching any cables.
    Frag FixBot
  46. iPhone 16 Pro Max Screen Replacement, Apply heat to the perimeter: Schritt 46, Bild 1 von 1
    • Use a hair dryer, heat gun, or an iOpener to heat the screen perimeter until it's slightly too hot to touch.
    • The heat softens the adhesive and helps create a better bond.
    Frag FixBot
  47. iPhone 16 Pro Max Screen Replacement, Apply pressure to the perimeter: Schritt 47, Bild 1 von 2 iPhone 16 Pro Max Screen Replacement, Apply pressure to the perimeter: Schritt 47, Bild 2 von 2
    • Use your fingers to firmly squeeze around the perimeter of the iPhone.
    Frag FixBot
  48. iPhone 16 Pro Max Screen Replacement: Schritt 48, Bild 1 von 2 iPhone 16 Pro Max Screen Replacement: Schritt 48, Bild 2 von 2
    • Place your iPhone screen-side down on a clean, flat work surface.
    • Lay a strip of tape around the perimeter of the back glass to protect the finish.
    • Stack coins around the perimeter of the back glass until you create a wall that's as tall as the rear camera protrusions.
    • Alternatively, you can use vise clamps around the perimeter of your device to set the new adhesive.
    Frag FixBot
  49. iPhone 16 Pro Max Screen Replacement: Schritt 49, Bild 1 von 2 iPhone 16 Pro Max Screen Replacement: Schritt 49, Bild 2 von 2
    • Place 3-4 heavy books squarely on top of your iPhone.
    • The coins may leave a slight impression on the bottom book cover, so don't use anything valuable.
    • Leave the books in place for about 30 minutes.
    • The pressure will help activate the adhesive.
    Frag FixBot
  50. iPhone 16 Pro Max Screen Replacement, Install the pentalobe screws: Schritt 50, Bild 1 von 2 iPhone 16 Pro Max Screen Replacement, Install the pentalobe screws: Schritt 50, Bild 2 von 2
    • Use a P2 pentalobe driver to install the two 7.4 mm-long screws on either side of the charge port.
    Frag FixBot
Abschluss
After your repair, calibrate a genuine replacement screen using Apple's Repair Assistant. Navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
18 weitere Personen haben diese Anleitung absolviert.
Arthur Shi
343.003 Reputation
914 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
122 Mitglieder
27.514 Anleitungen geschrieben
8 Kommentare zur Anleitung
Greetings. Is it true that viewing with a magnifying glass under the light of the house ruins the screen? On the iPhone 16 Pro Max
Ss Vv - Antwort Teilen
That's a good question! I would say that under normal house lights, you're very unlikely to damage the screen with a magnifying glass.
I haven't tried it, but it's theoretically possible to damage the screen with a magnifying glass if you're in direct sunlight.
Arthur Shi - Antwort Teilen
Hello, if we put a thin paper into the groove between the screen and the iPhone frame and pull it left and right. Does the waterproof glue get damaged? I did this out of curiosity. I'm a little worried that I may have damaged the device.
AMG78 - Antwort Teilen
Isn’t it necessary to transplant the ambient light sensor on the back of the old screen to the new screen?
Ld44hbxhkhr - Antwort Teilen
If the replacement screen doesn't include one, it'll need to be transferred. Those steps have been added to this guide.
Nick Schultz - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 85
Letzte 7 Tage: 659
Letzte 30 Tage: 2,856
Insgesamt: 51,635
