Zum Hauptinhalt wechseln
Einleitung
A iPhone 4 trouble shooting repair is much easier than you think. If your iPhone 4 will not turn on unless plugged in to a charger, and even then it's only on for two minutes and then will shut off again. If you try to plug your iPhone 4 into the computer it will come up with the Apple logo and then will fade off and on forever. Lastly when your iPhone 4 does turn on if it says that it's December 31. Your problem is your battery. In this manual I will teach you how completely take apart your iPhone 4 and replace the battery.
  1. Before you begin make sure that the phone is on silent and it is shut off.
    • Before you begin make sure that the phone is on silent and it is shut off.
  2. Remove both five-point tamper resistant screws which are located on either side of the charging port. Remove them with your T5 Torx screwdriver. Remove both five-point tamper resistant screws which are located on either side of the charging port. Remove them with your T5 Torx screwdriver.
    • Remove both five-point tamper resistant screws which are located on either side of the charging port. Remove them with your T5 Torx screwdriver.
  3. After the screws are removed the back should slide up and remove smoothly. After the screws are removed the back should slide up and remove smoothly.
    • After the screws are removed the back should slide up and remove smoothly.
  4. Android Fix Kits
    Ein neues Display oder Akku sind nur ein Kit entfernt.
    Jetzt kaufen
    Android Fix Kits
    Jetzt kaufen
  5. You can then remove the screw on the battery connector. Which will free up your battery for removal.
    • You can then remove the screw on the battery connector. Which will free up your battery for removal.
  6. Then you will take your plastic opening tool and begin to pry up the battery connector, which is the plate you took the screw out of. After you have that up you can begin to pry up on each edge of the battery. Then you will take your plastic opening tool and begin to pry up the battery connector, which is the plate you took the screw out of. After you have that up you can begin to pry up on each edge of the battery.
    • Then you will take your plastic opening tool and begin to pry up the battery connector, which is the plate you took the screw out of. After you have that up you can begin to pry up on each edge of the battery.
  7. After removing the battery you can put the replacement battery in and connect the battery connector. After removing the battery you can put the replacement battery in and connect the battery connector.
    • After removing the battery you can put the replacement battery in and connect the battery connector.
  8. you can then pit the back cover back on and screw in the five-point tamper resistant screws and it should be ready to use.
    • you can then pit the back cover back on and screw in the five-point tamper resistant screws and it should be ready to use.
Abschluss
Your iPhone 4 should now be back to its former glory!
cody m nixon
154 Reputation
1 Anleitung geschrieben
Vegas Room H9 Mitglied von Vegas Room H9
Community
13 Mitglieder
15 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
Insgesamt: 332
