Zum Hauptinhalt wechseln
iPhone 4S Battery Replacement
Was du brauchst
  1. iPhone 4S Battery Replacement, Pentalobe Screws: Schritt 1, Bild 1 von 1
    • Remove the two bottom Pentalobe screws next to the 30-Pin connector.
    • It is recommended that you use a small 5-Point screwdriver for this process.
    • Remember to make sure your iPhone is fully turned off before commencing this process, to prevent serious injury to the phone.
  2. iPhone 4S Battery Replacement, Back Panel Removal: Schritt 2, Bild 1 von 2 iPhone 4S Battery Replacement, Back Panel Removal: Schritt 2, Bild 2 von 2
    • Push the back panel towards the top of the iPhone. Doing this should allow the back panel to slide off safely.
    • Do not apply too much pressure to the back. Especially if your phone has a cracked back panel.
    • Do not rush it! Time is key.
  3. iPhone 4S Battery Replacement, Battery Screws: Schritt 3, Bild 1 von 1
    • Remove these two screws that are securing the battery connector to the Logic Board.
    • Beware of unscrewing the battery connector, as your screwdriver does have the possibility to slip and pierce the battery.
    • For the bottom screws, it is recommended that you use a 1.5 mm screw bit, and a 1.7 mm for the top screw.
  4. iPhone 4S Battery Replacement, Battery Strip: Schritt 4, Bild 1 von 1
    • Locate and pull the plastic tab to pull out the battery. Make sure to pry up on the outside of the battery on all sides.
    • Do not pull on the plastic tab too hard, as it can easily rip, making the battery removal process harder.
  5. iPhone 4S Battery Replacement, Battery Removal: Schritt 5, Bild 1 von 1
    • Carefully remove the battery.
    • Remember, if you are replacing your battery, remember to preform a hard reset on your iPhone by holding on both the home and power button for a few seconds once the repair is all finished.
Abschluss
63 weitere Personen haben diese Anleitung absolviert.
1 Kommentar zur Anleitung
la olum bunu benim 1 yaşında kızım da biliyo
ahmetceylanbm - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 73
Letzte 30 Tage: 212
Insgesamt: 25,497
