Zum Hauptinhalt wechseln
iPhone 5 Display Assembly Replacement
Archivierte Anleitung
Diese Anleitung wurde ausschließlich für historische Zwecke erhalten. Verwende die aktualisierte Version dieser Anleitung, um deine Reparatur durchzuführen.
Was du brauchst
  1. iPhone 5 Display Assembly Replacement, Safety Precautions and Replacement Preparations: Schritt 1, Bild 1 von 3 iPhone 5 Display Assembly Replacement, Safety Precautions and Replacement Preparations: Schritt 1, Bild 2 von 3 iPhone 5 Display Assembly Replacement, Safety Precautions and Replacement Preparations: Schritt 1, Bild 3 von 3
    • If your display is cracked, keep your eyes and skin protected. Wear Safety glasses to protect your eyes and wear latex or nitrile gloves to protect hands from shrapnel (Make sure you are not allergic to the material of the gloves.).
    • Laying clear packing tape over the broken glass until the whole screen is covered. Doing this can prevent any injuries or glass from being scattered on the table.
  2. iPhone 5 Display Assembly Replacement, Display Assembly Screws Removal: Schritt 2, Bild 1 von 2 iPhone 5 Display Assembly Replacement, Display Assembly Screws Removal: Schritt 2, Bild 2 von 2
    • Before removing the Display assembly, be sure to power off your phone. This can prevent power shortages.
    • Take the 5-Point Pentalobe screwdriver to remove two 3.6 mm Pentalobe screws next to the Lighting Connector (Charging Port).
  3. iPhone 5 Display Assembly Replacement, Display Assembly Removal Part I: Schritt 3, Bild 1 von 1
    • An X-acto blade will be used for this step. Take immense caution when using the blade. Always cut away from you.
    • Extend the blade 2mm from closed position.
    • Place blade between the display assembly and the phone housing.
    • Push down between the display assembly and the phone housing until you see a gap. Once you see the gap, pry up using the blade to keep the gap.
  4. iPhone 5 Display Assembly Replacement, Display Assembly Removal Part II: Schritt 4, Bild 1 von 1
    • Now that there is a fixed gap, use your plastic pry tool to pry around the display assembly, to separate the screen from the phone.
    • If you hear clicks, that means the display bezel is un-clipping from the phone, which is good.
  5. iPhone 5 Display Assembly Replacement, Display Assembly Removal Part III: Schritt 5, Bild 1 von 1
    • Gently lift the display assembly away from the phone, and make a 90 degree angle with respect to the horizontal.
  6. iPhone 5 Display Assembly Replacement, Connector Protective Plate Removal: Schritt 6, Bild 1 von 1
    • Locate the Connector Protective plate, it is at the top right of the phone. Along the side of the power button.
    • Take your #000 Phillips head screwdriver to unscrew three Phillip screws holding the Connector Protective plate to the logic board.
    • Once all the Phillips screws and removed, remove the Connector Protective Plate from the phone.
  7. iPhone 5 Display Assembly Replacement, Disconnecting Display Assembly Cables: Schritt 7, Bild 1 von 2 iPhone 5 Display Assembly Replacement, Disconnecting Display Assembly Cables: Schritt 7, Bild 2 von 2
    • Locate three cables that link from the back of the display assembly to the logic board.
    • Slowly, remove each cable with pliers.
  8. iPhone 5 Display Assembly Replacement, Display Assembly Full Removal: Schritt 8, Bild 1 von 1
    • Now that the three cables are disconnected, remove the old Display Assembly and store it safely.
  9. iPhone 5 Display Assembly Replacement, Clean the Internals: Schritt 9, Bild 1 von 1
    • Using compressed air specifically for electronics, blow away any dust and trash from the phone.
  10. iPhone 5 Display Assembly Replacement, Reverse: Schritt 10, Bild 1 von 1
    • Perform everything in reverse with the new Display Assembly.
Abschluss
13 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 9
Insgesamt: 2,784
