Zum Hauptinhalt wechseln
iPhone 5c Screen Replacement
Was du brauchst
  1. iPhone 5c Screen Replacement, Taking out bottom screws: Schritt 1, Bild 1 von 1
    • Take out the pentolope screws from the bottom of the iPhone next to the speakers.
  2. iPhone 5c Screen Replacement, Pulling up screen: Schritt 2, Bild 1 von 1
    • Get suction cup and pull up.
    • Note: Use a guitar pick and pry up to lift screen easily.
  3. iPhone 5c Screen Replacement, Unplugging battery: Schritt 3, Bild 1 von 2 iPhone 5c Screen Replacement, Unplugging battery: Schritt 3, Bild 2 von 2
    • Unplug battery take out Phillips head screws on the cover and unplug the battery.
  4. iPhone 5c Screen Replacement, Removing shield and cables: Schritt 4, Bild 1 von 3 iPhone 5c Screen Replacement, Removing shield and cables: Schritt 4, Bild 2 von 3 iPhone 5c Screen Replacement, Removing shield and cables: Schritt 4, Bild 3 von 3
    • Take off screen cables by removing the shield with four Phillips head screws
  5. iPhone 5c Screen Replacement, Remove front facing camera and microphone: Schritt 5, Bild 1 von 1
    • Remove camera and micro bracket with its two Phillips head screws.
    • Note: small sticker needs to be pulled up from front facing camera.
  6. iPhone 5c Screen Replacement, Removing screen back plate: Schritt 6, Bild 1 von 1
    • Remove back plate with six Phillips head screws.
  7. iPhone 5c Screen Replacement, Removing home button: Schritt 7, Bild 1 von 2 iPhone 5c Screen Replacement, Removing home button: Schritt 7, Bild 2 von 2
    • Remove home button bracket and take out the home button. (You may need to use a guitar pick to loosen home button adhesive).
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
ncstate8910
259 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 2
Letzten 7 Tage: 16
Letzten 30 Tage: 57
Insgesamt: 853
