Was du brauchst
Disconnect battery before screen removal by removing 2 screws from shield. Once shield is removed, disconnect battery using nylon spudger. (DO NOT USE METAL TOOLS)
Remove four screws from shield covering display assembly connectors. Lift connectors using nylon spudger.
Swap all parts from old display assembly to new assembly. Do not remove all at once, replace components one at a time. To reassemble your device, follow these instructions in reverse order.
57 weitere Nutzer:innen haben diese Anleitung absolviert.
