Zum Hauptinhalt wechseln
iPhone 6 Pentalobe Screws Replacement
Was du brauchst
  1. iPhone 6 Pentalobe Screws Replacement, Pentalobe Screws: Schritt 1, Bild 1 von 1
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.6 mm-long P2 Pentalobe screws next to the Lightning connector.
Abschluss
100 weitere Nutzer:innen haben diese Anleitung absolviert.
8 Kommentare
What size screwdriver do I need to remove these screws?
ronrola - Antwort
P2 Pentalobe Screwdriver
sbrown9615 -
really? follow these steps in reverse to reinstall? it already is laughably short...
beautron7 - Antwort
also how is this moderate difficulty?
beautron7 - Antwort
I have the correct screwdriver, but after taking out the original pentalobe screws, they will not screw back into the iPhone. Really bizarre. Do these screws get easily stripped?
dcs Bu - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 24
Letzte 30 Tage: 122
Insgesamt: 64,467
