Einleitung
Prereq only for logic board.
Was du brauchst
Remove the following screws securing the rear-facing camera bracket to the rear case:
One 1.7 mm Phillips #00 screw
One 2.3 mm Phillips #00 screw
Use the flat end of a spudger to disconnect the rear-facing camera connector from its socket on the logic board.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
