Einleitung
Prereq only, battery removed.
Was du brauchst
Pry the vibrator connector cable up from its socket on the logic board with the flat end of a spudger.
Use the tip of a spudger to disconnect the interconnect antenna cable from its socket on the logic board.
Remove the two 2.5 mm Phillips #00 screws securing the vibrator to the rear case.
Fast fertig!
Abschluss
