Zum Hauptinhalt wechseln
Einleitung
You can find an updated version of this guide here.
  1. Power off your iPhone before beginning disassembly.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm Pentalobe screws surrounding the Lightning connector.
    • If you don't have an iSclack, use a single suction cup to lift the front panel:
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is pressed securely onto the screen to get a tight seal.
  2. There is a notch on the underside of the display just above the headphone jack that is the safest place to begin prying the phone open. Pull up on the suction cup to slightly separate the front panel assembly from the rear case. Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices and is held down with adhesive.
    • There is a notch on the underside of the display just above the headphone jack that is the safest place to begin prying the phone open.
    • Pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices and is held down with adhesive.
    • Once a small gap has been opened, insert the flat end of a spudger above the headphone jack.
  3. Twist the spudger to open the gap more and break it free from the adhesive. Keep pulling up on the suction cup while twisting the spudger.
    • Twist the spudger to open the gap more and break it free from the adhesive.
    • Keep pulling up on the suction cup while twisting the spudger.
  4. Use the edge of a spudger to slice through the adhesive on either side of the phone. Use the edge of a spudger to slice through the adhesive on either side of the phone.
    • Use the edge of a spudger to slice through the adhesive on either side of the phone.
  5. iPhone Akku Fix Kits
    Nur $29.99
    Buy Now
    Nur $29.99
    Buy Now
  6. Use the edge of a spudger to slice through the adhesive on either side of the phone. Use the edge of a spudger to slice through the adhesive on either side of the phone.
  7. Use the suction cup to open the display, breaking the last of the adhesive. Don't open the display more than 90 degrees, as it is still connected at the top by three cables that may break if stretched. Don't open the display more than 90 degrees, as it is still connected at the top by three cables that may break if stretched.
    • Use the suction cup to open the display, breaking the last of the adhesive.
    • Don't open the display more than 90 degrees, as it is still connected at the top by three cables that may break if stretched.
  8. Lean the display against something to keep it propped up while you're working on the phone.
    • Lean the display against something to keep it propped up while you're working on the phone.
  9. Remove the following screws from the battery connector bracket:
    • Remove the following screws from the battery connector bracket:
    • One 3.0 mm Phillips #00 screw
    • One 2.3 mm Phillips #00 screw
  10. Remove the metal battery connector bracket from the iPhone.
    • Remove the metal battery connector bracket from the iPhone.
  11. Use the flat end of a spudger to disconnect the battery connector from the logic board. Push the connector to the side to ensure it doesn't accidentally make contact and power on the phone while you're working on it. Push the connector to the side to ensure it doesn't accidentally make contact and power on the phone while you're working on it.
    • Use the flat end of a spudger to disconnect the battery connector from the logic board.
    • Push the connector to the side to ensure it doesn't accidentally make contact and power on the phone while you're working on it.
  12. Use tweezers to peel up the edges of the two adhesive strips at the bottom of the battery. Use tweezers to peel up the edges of the two adhesive strips at the bottom of the battery. Use tweezers to peel up the edges of the two adhesive strips at the bottom of the battery.
    • Use tweezers to peel up the edges of the two adhesive strips at the bottom of the battery.
  13. Grab the ends of the two adhesive strips and hold them together. Try to keep the strips flat and wide.
    • Grab the ends of the two adhesive strips and hold them together. Try to keep the strips flat and wide.
  14. Slowly and gently pull the two strips up and away from the phone. The strips will stretch to many times the length of the battery—keep pulling until they come out from between the battery and the rear case. The strips will stretch to many times the length of the battery—keep pulling until they come out from between the battery and the rear case.
    • Slowly and gently pull the two strips up and away from the phone.
    • The strips will stretch to many times the length of the battery—keep pulling until they come out from between the battery and the rear case.
  15. Remove the battery from the rear case.
    • Remove the battery from the rear case.
    • When installing the battery, refer to this guide to replace your battery's adhesive strips.
Abschluss
73 weitere Nutzer haben diese Anleitung absolviert.
Sam Goldheart
371.391 Reputation
541 Anleitungen geschrieben
iFixit Mitglied von iFixit
Community
101 Mitglieder
8.732 Anleitungen geschrieben
Quickkkkkkkkkkk Question. How do I go about replacing that adhesive you had me slice?
Doc Brown - Antwort
I need to buy the 6s replacement battery itself as well as the tools. Do you sell that as well as the display?
2ndwindranch - Antwort
i remember i get my battery repair kit and adhesive for less than 25$ from this seller on amazon https://www.amazon.com/dp/B01LKN9AUG
exdany9 -
Please do a video. Lets see how fast you guys can change the 6s battery.
klactwiggy - Antwort
nice very repair mizan.....
mohsen m - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 2
Letzte 7 Tage: 46
Letzte 30 Tage: 221
Insgesamt: 66,089
