Einleitung
Follow the steps in this guide to replace the volume control button covers in your iPhone 6s Plus.
You can also use this guide to replace the volume button bracket and the mute switch bracket, both removed in this step.
Was du brauchst
Power off your iPhone before beginning disassembly.
Remove the two 3.4 mm Pentalobe screws on either side of the Lightning port.
In diesem Schritt verwendetes Werkzeug:Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
Pull the blue handle forwards to lock the arms.
Turn the handle clockwise 360 degrees or until the cups start to stretch.
Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
Skip the next three steps.
If you don't have an Anti-Clamp, follow the next three steps to use a suction handle.
Apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
The safest place to pry from is the notch in the front panel above the headphone jack.
While still maintaining pressure on the suction cup, insert the flat tip of a spudger into the gap, directly above the headphone jack.
While firmly pulling up on the suction cup, slide the edge of the spudger under the bottom left corner of the display.
Slide the tip of the spudger up the left side of the phone, between the front panel and the rear case.
Insert the flat tip of the spudger under the right edge of the display.
Slide the spudger up the right side.
Use a plastic opening tool to hold down the rear case while pulling up the suction cup to open the phone.
Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge.
Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
In diesem Schritt verwendetes Werkzeug:Magnetic Project Mat$19.95
Remove two Phillips screws securing the battery connector bracket to the logic board, of the following lengths:
One 2.9 mm screw
One 2.3 mm screw
Use a spudger or a clean fingernail to disconnect the battery connector by prying it straight up off the logic board.
Bend the connector back to ensure it doesn't make contact and power the iPhone on while you're working on it.
Remove the following Phillips screws:
Three 1.3 mm screws
One 1.6 mm screw
One 3.0 mm screw
Use a plastic opening tool to disconnect the front-facing camera and sensor cable connector.
Use a plastic opening tool to disconnect the digitizer cable by prying it straight up from its socket on the logic board.
Disconnect the home button/fingerprint sensor cable by prying it straight up from its socket on the logic board.
Use tweezers, or your fingers, to peel up the black pull tab on one of the adhesive strips.
Pull the strip out slowly and steadily at a low angle. Give it plenty of time to stretch and un-stick from under the battery.
Repeat the process for the remaining stretch release adhesive strips.
If you're still having trouble removing the battery, apply a few drops of high concentration (90% or higher) isopropyl alcohol under the edge of the battery in the area of the broken adhesive strip(s).
Tilt the phone up so the isopropyl alcohol can flow toward the adhesive strip.
Hold for 1–2 minutes to allow the isopropyl alcohol to weaken the adhesive.
Use an opening pick or the flat end of a spudger to slowly pry up the battery.
Remove the battery.
Adhere the battery, disconnect it, and continue reassembling your device.
Remove the two 2.7 mm Phillips screws over the audio control cable bracket.
Remove the circular sticker covering the third screw securing the cellular antenna to the rear case.
Remove the following three Phillips screws:
One 2.7 mm screw
One 1.7 mm screw
One 1.3 mm screw
Lift, but do not remove, the cellular antenna to reveal the third screw securing the audio control cable to the rear case.
Use the flat end of a spudger to peel the volume control flex cable off the rear case.
Gently nudge the volume control button covers out of their slots in the rear case.
11 weitere Nutzer:innen haben diese Anleitung absolviert.
