Einleitung
For the official iFixit guide, follow this link. This guide has been archived for historical purposes.
This will be a helpful guide on how to try and fix your water damaged iPhone.
Was du brauchst
Einführungsvideo
2. Next take it apart like the sim card and let that dry out for like 24 hours.
3. If it doesn't help then try the rice method by putting the phone in the rice as well as the sim card.
5.If that doesn't help your battery is probably damaged and you can replace it or just get a whole new phone.
Try to turn on the phone to see if it works if not then your screen is probably damaged if you don't see anything come on.
If you can fix the screen and get it replaced but it wont hold a charge then the battery is probably damaged and you will have to try and get a new one.
Once you put a new battery put the screws back in may sure it's in correctly and try to power non your phone and it should work.
Now once it's all done put the phone back together and it should be back in full functioning mode
2 weitere Nutzer:innen haben diese Anleitung absolviert.
